Old 09-19-2013, 10:10 AM   #43
fenton
Originally Posted by Fast_Freddy View Post
It sounds like this little ESC is more for short 0-60 bursts than 1/4 mile and that is very weak sauce indeed. How long can this ESC maintain max boost at WOT? 0-60? 0-100? Burnout and 1/4 mile pass?
Hey Fast Freddy, It can maintain boost at WOT for about a minute constant.
During my testing i was able to do 0-240km whilst still developing boost. As a matter of fact i did 2 back to back only slowing down to 0 in between.
1/4mile, half mile will not be a problem AT ALL.
On the street it is 100% impossible to get the system to a point where it will not put you back in the seat.
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (09-19-2013), Fast_Freddy (09-20-2013)
Old 09-19-2013, 10:16 AM   #44
fenton
Originally Posted by Element Tuning View Post
I like the concept but I would love, if even only as an exhibition of what is possible, higher capacity batteries and a bigger motor.
Was the drop in HP gains at high rpm a result of voltage drop and therefore less compressor flow?
Thanks,
Phil Grabow
Power drop is due to the compressor running at a static RPM. This RPM equals 4.5psi boost down low where the engine is inefficient and about 2psi up top where the engine is very efficient.
Old 09-19-2013, 12:22 PM   #45
mid_life_crisis
Drives: FR-S 10 #103 AT
My God, they come out of the woodwork like roaches. Just when you think you've killed the last one, another crawls out.
Old 09-19-2013, 12:55 PM   #46
fenton
Its alright, hes asked a couple questions in the other Phantom thread too.
Im glad to set the record straight for anyone that has questions.
The Following 4 Users Say Thank You to fenton For This Useful Post:
autobrz (10-17-2013), mtimney (09-19-2013), s2d4 (09-19-2013), sw20kosh (09-19-2013)
Old 09-19-2013, 02:55 PM   #47
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Fenton... you and the others testing this product have had the patience of Saints answering the questions and complaints. Thanks for your time and ability to keep things civil.
mtimney is offline   Reply With Quote
The Following 5 Users Say Thank You to mtimney For This Useful Post:
autobrz (10-17-2013), fenton (09-19-2013), Ingen (09-20-2013), s2d4 (09-19-2013), sw20kosh (09-19-2013)
Old 09-19-2013, 08:15 PM   #48
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
Question
Bob,
I have a header, overpipe, front pipe, Cat-back, intake , pulley, FA20Club Ecutek tune and I still need a bit more power.
By assuming an N/A car with all those bolts on is developping lets say about 185-190 WHP already.
If I add this electric supercharger mod on top of that setup do you think I could be looking forward another 20-30 extra WHP like it did to a stock car ?
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 09-19-2013, 08:23 PM   #49
raven1231
Originally Posted by NoFear99 View Post
Bob,
By assuming an N/A car with all those bolts on is developping lets say about 185-190 WHP.
If I add this electric supercharger mod on top of that setup do you think I could be looking for another 20-30 extra WHP like it did to a stock car ?
There is no reason it shouldn't. However anything would just be speculating.
Old 09-19-2013, 08:44 PM   #50
NoFear99
NoFear99's Avatar
Well if that is the case, that means we should be looking forward 215-225 WHP.
We are talking about an FR-S that would make a solid 250-260 crank hp.
With such extra power I'm confident my FR-S could make the 1/4 mile in 13.8 - 14 seconds instead of 15 seconds.
This is what I need for next summer.
Old 09-19-2013, 10:48 PM   #51
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
With a little more technology there's some pretty solid potential. If you could fit a motor with more RPM or more voltage, add a speed controller, and tie that to engine rpm you could hopefully keep 4.5 psi to redline.
That would keep you from having to resort to 7 psi at peak torque, where it could detonate without an IC, to get 4.5 at redline. You could also run a wastegate on the charge side
Element Tuning is offline   Reply With Quote
Old 09-19-2013, 10:57 PM   #52
fenton
Trust me Rob is the man when it comes to this. The sad fact is the energy to create 5 psi at redline is 15 to 20 kW if I remember correctly.
Most people think well just turn that motor a couple 10,000 rpm more and your there. Unfortunately all that increases the motor required, controller required, batteries required and so on. Once you get into those wattages you are talking about cooling every component and the list goes on and on.
Can you imagine the batteries required for even a 30 second shot, times what we have now by 5 and your trunk is half full.
Short answer is yes absolutely its possible but you are talking about more money than most of the turbo kits and at that point the costs outweigh the benefits of non parasitic boost.
As tech evolves the price to performance will continue to improve.
I see you said IF you had better technology, which is good, whereas a lot if people just say crank it up. Lol
Sent from my HTC One using Tapatalk 4
The Following User Says Thank You to fenton For This Useful Post:
Old 09-20-2013, 12:13 AM   #53
Element Tuning
This would also add a ton of money but the motor could power a supercharger with a gearbox. That would require more torque but less rpm. But yes as you stated the price of the batteries would sky rocket since I would imagine lipo would be needed and when not controlled correctly burst into fire. Eek!
Anyways cool idea and solid low-midrange gain.
The Following 2 Users Say Thank You to Element Tuning For This Useful Post:
DAEMANO (09-20-2013), fenton (09-20-2013)
Old 09-20-2013, 12:17 AM   #54
Fast_Freddy
Drives: Passat
Of course they will, but they need to be properly designed for the FI system. You can't bolt on a set of headers designed for an NA vehicle and expect the car to show improvement. The real problem is that you can't tune around incorrectly matched headers. They will be fighting your efforts the whole time.
For mild boost (electrocharger anyone?) I would expect that the stock system with its narrow tubing would work quite well, keeping the exhaust velocity up and enhancing scavenging. You might see an improvement with high flow cats but the rest of the exhaust should be fine.
: lol:
"Here comes the big one. The system usage is designed around a single pull and upon throttle switch activation, not in a volley of consecutive back to back ones. Anyone catch my WOT mentions? There's nothing sinister about any of the previous references, only that it's just that – Wide Open Throttle. Notice that I didn't say it would be great for DRAG and or DRIFT applications? That's because this system will not activate in partial throttle, at all. This is where the Phantom ESC differs, and slight adjustment in driving styles are needed.
Think about this real quick – you're in the burnout box ready to rumble. You launch, floor it, hit rev limit and grab second. At which point in time, the recharge isn't going to be full when you go wide open in that gear. Additionally, with each successive gear change, the rate of 'recharge' that the batteries provide will be diminished and your IATs build up, producing less than optimal results. It's still better than stock, all things said. Same issues apply with drifting."
[I @Drift-Office[/I]
You guys aren't exactly in agreement here and I have to say that IMO @Drift-Office is unbiased.
Fast_Freddy is offline   Reply With Quote
The Following User Says Thank You to Fast_Freddy For This Useful Post:
fenton (09-20-2013)
Old 09-20-2013, 12:43 AM   #55
fenton
Bob had the prelim kit with only 1 recharger
All the testers have the double recharge now and it makes a dramatic difference on how quickly the system comes back to full.
Either way I appreciate Bob's opinions on the kit and your interest as well.
Time will tell how this kits evolves but there has already been a lot of advancements even in the last 3 months.
I believe ThaTruth is planning some drag time in the future at which point we will see more proven results over the dynos.
Old 09-20-2013, 12:53 AM   #56
Fast_Freddy
Drives: Passat
Thanks Fenton. I do follow the Phantom threads but missed the fact that Drift-Office had tested an older version. I know that this is far from a drag car but look forward to 1/4 miles results to more accurately quantify the actual performance enhancement provided by this ESC.
Still interested and watching...
The Following 2 Users Say Thank You to Fast_Freddy For This Useful Post:
fenton (09-20-2013), raven1231 (09-20-2013)
Drift-Office : HKS EL Header Tuned! Drift-Office Engine, Exhaust, Transmission 84 05-05-2014 12:34 AM
Drift-Office : Borla UEL Header... TUNED. Drift-Office Engine, Exhaust, Transmission 41 10-26-2013 11:54 AM
Drift-Office : Vortech / HKS EL / Perrin / Greddy Installed & Tuned! Drift-Office Forced Induction 8 09-03-2013 06:20 PM
Drift-Office : Vortech / Perrin Combo Installed & Tuned! Drift-Office Forced Induction 44 08-06-2013 06:37 PM
Got my stock BRZ tuned at Drift Office over the weekend... edocura Engine, Exhaust, Transmission 46 05-23-2013 08:05 AM
