Old 10-22-2013, 06:20 AM   #43
retrosmiths
Drives: Scion FR-S Whiteout
Originally Posted by oilfieldFR-S View Post
At about 3k I hit a dog going 65. Went straight through the plastic grille in the front and smashed up my AC condenser. Ac still works but now the plastic grille won't stay clipped. Probably not gonna fix it.
Did you remove the dead dog?
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 10-22-2013, 09:10 AM   #44
oilfieldFR-S
oilfieldFR-S's Avatar
Drives: Red 2013 scion frs blacked out
Yes the dog is gone.
oilfieldFR-S is offline   Reply With Quote
The Following User Says Thank You to oilfieldFR-S For This Useful Post:
zaptorque (10-22-2013)
Old 10-22-2013, 03:08 PM   #45
neutral
Drifter-Wannabe
Drives: Firestorm MT FR-S
Send a message via AIM to neutral
Originally Posted by BPM View Post
Why did they total the car? It is a brand new car and it looks like that can be repaired way under what they consider totaled. Just curious about the depth of the damage.
Airbags went off, windshield cracked, some accessory engine-bay components were damaged and part of the frame was bent. It doesn't take much to total modern-day cars. They pretty much destroy themselves in an effort to save the occupants.
neutral is offline   Reply With Quote
The Following User Says Thank You to neutral For This Useful Post:
BPM (10-22-2013)
Old 10-22-2013, 03:39 PM   #46
BPM
Drives: A Blue One
Thanks for the response! I super appreciate the info
BPM is offline   Reply With Quote
Old 10-22-2013, 03:42 PM   #47
Chee-Hu
Chee-Hu's Avatar
It was on a windy road in the foothills when I tried dodging an object in the middle of a road after a blind left turn. I chose to go off the road resulting in me hitting an upright plastic reflector leaving a nasty dent on the hood and scratches on the bumper. I got it fixed right away.
Chee-Hu is offline   Reply With Quote
Old 10-22-2013, 03:57 PM   #48
muffinz
Drives: 2013 DGM BRZ Ltd
first: linear dent in the hood (on clear bra section) from a rock kicked up by a truck. No fix.
second: 3 chips on the hood (past the clear bra) and 5 small chips on the windsheild. Another rock kicked up by traffic. This one was so big that I ducked because I thought it was coming thru the windshield. No fix.
third: hooning around in the snow. Finish hooning, try to take a right hand turn at a normal speed, come over the crown of the road and its all ice, slide into the curb at about 2mph, throw the alignment out, scratch wheels. Drive w/ alignment out, destroy bearing. Fixed everything.
fourth: I think maybe a branch got kicked up by my rear tire and it scratched the ass of the bumper pretty bad. No fix.
fifth: someone dinged my door. Dime sized dent. No fix.
*note on incident 3: I took the car to the dealer I bought it from. They said I totally destroyed all my suspension and I needed like $1500 in repairs. (I think they tried to pull this on me bc I'm 24 and didn't think I was an automotive engineer.) I didn't believe them because I knew how gently I collided with the curb. Took the car to another dealership that I had experience with from another car, they said everything was fine, but I needed an alignment. Got the alignment done, problem solved. Also had them replace the bearing that went bad from driving w/ the toe out so much.
muffinz is offline   Reply With Quote
Old 10-22-2013, 04:29 PM   #49
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
That plastic insert is like $45...
zaptorque is offline   Reply With Quote
Old 10-22-2013, 10:20 PM   #50
radroach
Drives: car
Originally Posted by Whiteout_FRS View Post
Well first, I work at a Toyota dealership. Week 2 of ownership a service tech rolled my car into a concrete wall and I had to have the rear bumper replaced. Week 3 another salesperson was backing in a Tundra and ran all over me. Week 6 door dinged twice within 3 inches of each other. And lastly the State was painting road lines without signs up and I now have yellow paint under the fenders on all four corners...
ow.. OW.. ow.. owww
Old 10-22-2013, 10:30 PM   #51
radroach
Drives: car
A tire from an F-150 went shredding off on the highway, its rims molten and sparking against the asphault and a large peice of the tire hit the bumper. I think it bounced off the mustache for the most part, but it took a nice scrape which is pink, doesn't look too bad though!
Old 11-05-2013, 02:13 PM   #52
Thornley
Thornley's Avatar
Drives: Silver FRS
Originally Posted by Ryuu0u View Post
Backing out of my drive way too fast and my 5axis front lip scraped a little. You can't even see it but it still pissed me off a bit.
I know this feeling. No one can see it, but i know it's there.
Thornley is offline   Reply With Quote
Old 11-07-2013, 02:48 AM   #53
Tessball
Tessball's Avatar
1) Hail damage. Was visiting my parents so no garage space to put it in. Ran out with blankets... FAIL. A lot of cursing while I watch hopelessly from window. Planning on getting it fixed after winter.
2)Not sure how but light scratch on driver door should be able to get out. I was staring/stressing about it and using my one hand to rub it, seeing if it indeed was a scratch. However, my keys were in my other hand and lost my footing falling off the curb into my car and putting an actual scratch just above the window. Just ridiculous.
Tessball is offline   Reply With Quote
Old 11-07-2013, 03:11 AM   #54
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
A girl who was texting hit me.. I don't want to talk about it anymore. bye.
Kelbyat07 is offline   Reply With Quote
Old 11-07-2013, 03:22 AM   #55
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
I fell for the old "too close to the (at Whole Foods ) parking lot island, scrape trick." Adding a lip should cover it up...
Wolfking is offline   Reply With Quote
Old 11-07-2013, 04:13 AM   #56
chonfop
Drives: WRB Limited
Was sitting in my car when an asian grandma to my left swings the door into my car. All I could do was cover my face in pain cuz she was just a passenger and there was nothing I could do.
chonfop is offline   Reply With Quote
imissmy86!, whohsntcrashedtheir86yet
CAR DING chjno86 Southern California 27 07-26-2013 02:29 AM
Ding repair? FReSh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 07-07-2013 07:25 PM
Ding and Paint Chips! how to fix it? Tamoor Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 03-17-2013 09:29 AM
Door ding prevention! smbrm Cosmetic Modification (Interior/Exterior/Lighting) 16 01-29-2013 07:22 PM
My First Ding :[ Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 32 10-24-2012 06:21 AM
