Old 09-05-2016, 05:45 AM   #43
DHitHim
Drives: 2015 CWP Limited BRZ
Originally Posted by Sportsguy83 View Post
My purge valve is connected and all lines in place like stock. Just disconnected the electric connector and connected it to the EBCS, nothing else.
Do I plug the ebc to that unplugged teal connector in the picture above? do I leave the other connected that was plugged to that alone and left unplugged?
DHitHim is offline   Reply With Quote
Old 09-05-2016, 08:19 AM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes
Sent from my Nexus 6P using Tapatalk
The Following User Says Thank You to Sportsguy83 For This Useful Post:
DHitHim (09-05-2016)
Old 09-05-2016, 01:36 PM   #45
Shady195
Drives: '13 10 Series FRS #1203
Glad I saw this
Switching from OFT to ECUTek for my SBD Turbo kit and going to go with the grimmspeed EBCS
Wasn't sure where to hook it up.
One more question, will disabling that CEL also trip another readiness monitor? NYS allows one failed one which is already unready because of the turbo kit and removal of the CATs
Shady195 is offline   Reply With Quote
Old 09-05-2016, 03:32 PM   #46
denso
Drives: 86
Theoretically Im able to use any kind of 2 or 3 port boost solenoids am I right? Im currently on wg pressure (internal) and want to increase the boost. I got an Audi 3 port solenoid laying around. Am I able to use this with ECUtek custom maps? @Sportsguy83
denso is offline   Reply With Quote
Old 09-07-2016, 09:44 AM   #47
Sportsguy83
Drives: Limited BRZ
Originally Posted by Shady195 View Post
Glad I saw this
I believe it does trip the readiness monitor but I'm not 1000% sure as there are no emission testing in FL and I only payed attention some years ago once.
Theoretically yes, but be careful about what calibration that EBCS has. Talk to your tuner about it.
denso (09-18-2016)
Old 09-29-2016, 02:27 PM   #48
Amputechture
Drives: 2014 BRZ
Hey David,
If I'm trying to verify if my 3 port is bogus, should I be able to just unplug the solenoid from the pigtail harness and leave all of the vac routing as is...or do I need to unplug the ebcs AND route my hoses as if I'm running strictly off of wastegate? Thanks in advance.
Amputechture is offline   Reply With Quote
