#43 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
They are not different between A/T and M/T in Canada and USA.
41110-30A03 - A/T without LSD (Not used in Canada or USA only in Japan and other overseas markets on low-spec cars) 41110-18021 - A/T and M/T with LSD (Used for Canada and USA) Both are 4.10:1 and externally look the same, but that LSD makes a difference. .Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
#44 | |
Drives: Scion FR-S A/T, Whiteout
#45 |
Drives: Sc10n FRS "DCLXIV"
Subbed
Killer build good sir. Interest is piqued!!
Sc10n FRS #0664
#46 |
Drives: GT86
This might be useful:
![]() Apparently they're all slippers. The first one is about 40% more expensive than the others though. Not sure why, perhaps they're not all slippers! |
#47 |
Sooo I noticed Weir Performance also offers a 5.71. Naturally, I had to investigate.
M/T, 6th gear, 4.556 final drive: 62.88 mph @ 3000 rpm A/T, 6th gear, 5.29 final drive: 71.36 mph @ 3000 rpm A/T, 6th gear, 5.71 final drive: 66.12 mph @ 3000 rpm Even with the shortest gear ratio they offer, the A/T still cruises at a lower rpm than the M/T with 4.556. Now I'm even more conflicted as to what ratio I want. Can any of you guys with the manual and a 4.556 comment on the noise or loss in mpg? Are there any differential integrity concerns that come with such a short final drive? Other than burning through my tires at an alarming rate? ![]() I'm leaving for my trip tomorrow so I probably won't be on the boards much (that's a lie, I'll probably be lurking the whole time) so don't think I just disappeared without following through on the project. As soon as I get back and make up my mind on the gearing, I'll update with my progress. Last edited by PantsDants; 08-28-2013 at 02:30 AM. |
#48 |
That last one pulls up on www.lexuspartsnow.com as an IS250 carrier but I don't know if that's a LSD or not. Good info either way.
#49 | |
degrees
Drives: 6MT BRZ
The only true fix there is a manual gearbox.
![]() Quote:
Haven't noticed a considerable loss in MPG on the highway. Maybe -0.5 to -1 MPG? Shorter gears will certainly impact city mileage unless you short shift (but that's no fun). Differential integrity? No. The 4.556 is a factory ratio and this is a low-torque platform. You won't put down enough torque NA for it to be a concern. Tires will let loose more easily. Your rate of alarm here is an unknown as the result will vary with your right foot and tire adhesion.
#50 | |
My concerns about diff problems stem from the fact that I'm planning on going suuuper short. I'm fairly certain the 5.29 and 5.71 were made by Toyota for use in the Suzuki Samurai, of all things, and I don't think that had a Torsen.
#51 |
Drives: 2013 Raven 86
#52 |
http://weirperformance.com/finaldrivegears.html
Look under Supra 1986.5-92- ALL. |
#53 |
Oh my goodness this thread is full of win. OP I can't wait to see your results since I'm really wanting to do a FD modification at some point and I also have an AT - I have same conundrum you face, I keep wondering how aggressive I want it to be.
#54 | ||
degrees
Drives: 6MT BRZ
Have you plotted out the 5.71? It looks WAY too short, even with an auto trans. To closely match a 6MT with 4.67 in gears 1-2-3 you'd need a 4.9. You might only be focused on gears 4-5-6 and missing how short the first three will become. Don't overlook that as it's a major place where a final drive matters. Realize that the 6AT in this car will have tall 4-5-6 gears no matter what you do. You either need a 6MT if you want all 6 gears spaced shorter or different auto gears. Shortening the first three too much just to shorten the last three means could mean you'll end up with a street car that's undriveable. You truly would be roasting tires and alarming yourself with a 5.71. Here is a direct comparison of a 6AT + 4.9 (red) with a 6MT + 4.67 (blue): http://www.teammfactory.com/gearcalc...ission+1+%26+2 Take note of what happens at 4th gear. You can't fix that plot with a final drive. You need different transmission gears. Quote:
#55 |
Thanks again @37. I didn't realize there was such a gap between 1-2-3 and 4-5-6 on the auto. I definitely don't want to go that short after all. I'll play around with the gear calculator some more, but looks like my original idea of 4.88 or 5.29 might be the way to go, as you suggested.
#56 | |
Vtec Jesus
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Final Fantasy | jay4prez | Off-Topic Lounge [WARNING: NO POLITICS] | 66 | 08-25-2013 10:31 PM |
| Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 12:08 AM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 08:39 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 01:21 PM |
