Old 08-17-2013, 04:53 PM   #43
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Definitely install the pump first and make sure it is working prior to doing all the other stuff.
Old 08-17-2013, 09:44 PM   #44
Ross
Drives: 85 corolla gts
Every one has there own opinions on oil. I find factory filters are great filters and very hard to beat. Also I have been using Amsoil signature series on most the force induction applications I do and have been pleased. It is easy to get your hands on and works well. On older motors I will also use Rotella (not recommended on the newer motors do to the tighter clearances)
Ross is offline   Reply With Quote
Old 08-18-2013, 12:10 AM   #45
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
wen i got my headers from him i needed new bolts to the overpipe since OEM ones are welded onto headers
lbroskee is offline   Reply With Quote
Old 08-18-2013, 12:37 AM   #46
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by charged86 View Post
You wus. I did my injectors in Dynosty's parking after driving there for two hours the fuel boiled on the head. Boy was that fucking stupid of me
you almost visconti'd yourself!
put a fire extinguisher on the parts list, just in case.
Old 08-18-2013, 12:41 AM   #47
bakerr6
Drives: 2013 raven black fr-s
gloves, safety goggles, magnetic pickup
are you pulling the oil pan? If not, you may wanta magnet also for any metal shavings.
Another thing to consider, I would make sure you contact your tuner the day you are tuning it, and see if the local shop would have an opening if you needed to have access to some other parts (I found this out the hard way when the silicon couplers on my mustang kept blowing off because the IC piping wasn't flared at all when I ordered them that way).
bakerr6 is offline   Reply With Quote
Old 08-18-2013, 12:53 AM   #48
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
TiVo anything you had planned on watching that week
Old 08-18-2013, 01:09 AM   #49
Dan@AWD
Drives: 2013 Argento FR-S
Rallysportdirect sells the disconnect tool for fairly cheap, I got one in prep for my S/C install, works like a charm.
http://www.rallysportdirect.com/Comp...isconnect-Tool
Helped immensely, I just added it to an order of some other things I was getting ahead of time so I wasn't paying the shipping on a 2oz piece of molded plastic.
Company23 Fuel Line Disconnect Tool on Ebay w/ free shipping
Dan@AWD is offline   Reply With Quote
The Following User Says Thank You to Dan@AWD For This Useful Post:
Sportsguy83 (08-18-2013)
Old 08-28-2013, 09:26 AM   #50
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Port fuel injector o-rings, seals & grommets, vacuum manifold, manual boost controller, air/oil separator (catch can) ordered.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Quick and dirty guide to track prepping your car CSG Mike Tracking / Autocross / HPDE / Drifting 166 04-05-2022 01:12 PM
Where to install amp in FRS? mit_peid Electronics | Audio | NAV | Infotainment 10 03-24-2013 01:01 PM
KW V3 on my car install ft86me DIY (Do-It-Yourself) Guides 0 03-12-2013 09:36 PM
prepping for winter Celica00 Scion FR-S / Toyota 86 GT86 General Forum 24 09-27-2012 08:17 AM
Prepping for rear spoiler install? zooki Cosmetic Modification (Interior/Exterior/Lighting) 2 09-02-2012 03:56 PM
