#43 | |
GreddyBRZ meets GreddyFRS
Drives: SSM Limited BRZ
(A) White = LF Speaker amplified out (black line means -) [PIN 1 and 5] Grey = RF Speaker amplified out (black line means -) [ PIN 2 and 6] (B) Green = Left speaker signal input from HU [PIN 3 and 9] Purple = Right Speaker signal in from HU [PIN 4 and 10]
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club Tuesday Night Irvine DJ Meet Thread Irvine FR-S & BRZ Car Meet(FaceBook) |
#44 |
Drives: FR-S 10 #103 AT
Not knowing if (B) is amplified from the HU or line level (probably amplified), I would try (B) first. If it doesn't produce any real volume, you haven't hurt anything. You can always still connect (A) with the gains down and see what happens if (B) isn't loud enough.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
| The Following User Says Thank You to mid_life_crisis For This Useful Post: | DNAPoPo (08-22-2013) |
#45 |
head of infinite swagger
Drives: 2013 FR-S 6MT
You definitely want to tap (B), I use (B) for the speaker level inputs on my amp. (A) is the powered signal going to the door speakers.
(B) is coming from the HU, (A) has been "amped" by the factory trunk amp and no one is really sure if that amp has any crossovers or filters or other sound shaping built in.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater 2000 Silverstone M5 6MT - SOLD 2013 Ultramarine FR-S 6MT - Car Journal - SOLD 2004 AlpineWhite M3 6MT - SOLD |
| The Following User Says Thank You to f0rge For This Useful Post: | DNAPoPo (08-22-2013) |
#46 | |
SW5 Driver
Drives: Asphalt FRS
#47 | |
#48 |
Drives: 2013 BRZ Limited AT
I'll just do a YouTube video tonight showing my setup. I recently moved my wires from the HU to the amp and it works fine. I'm using posi-taps.
| The Following User Says Thank You to kuhlka For This Useful Post: | DNAPoPo (08-22-2013) |
#49 | |
Waited 5 years for this
Drives: '18 MX-5 Club
It's already been answered and f0rge explained it well. I used signal wires. PIN 3, 4, 9, 10. |
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | DNAPoPo (08-23-2013) |
#51 |
[ame]http://youtu.be/ma5s8GLOd7w[/ame]
| The Following 5 Users Say Thank You to kuhlka For This Useful Post: | Agent 86 (02-11-2016), DNAPoPo (08-23-2013), hmong337 (07-27-2014), housecat (12-17-2014), Shankenstein (09-10-2013) |
#52 |
I'll do better videos after I move. I have garbage lighting in my dinky garage. Where I'm moving I'll have access to a full pneumatic lift and TONS of tools.
| The Following User Says Thank You to kuhlka For This Useful Post: | DNAPoPo (08-23-2013) |
#53 |
Drives: BRZ DGM Limited
Thanks for the video..doesn't look too bad to do
#54 |
The only annoying part is running the positive lead. I'll flop my back seat down, get a shop light, and do a better video when I'm all moved next weekend. I still need to shorten some of the wires and eventually get a custom enclosure for the driver's side corner.
#55 |
Drives: limited brz
:happy0180: this post helped my life in so many ways!
#56 |
Drives: FR-S | 335i | S13
I will be using this write up to install an AMP for my speakers and sub. I'll take some pictures to share.
Perks of the job: My battery is in the back. (May need to upgrade the size haha)
| Wideband LC-1 wiring. | MattF | Forced Induction | 9 | 07-09-2013 10:33 AM |
| Wiring a sub in a BRZ | Shizuma | Electronics | Audio | NAV | Infotainment | 22 | 06-08-2013 02:02 PM |
| So is there a DIY yet for BRZ headlight wiring for the FR-S? | seven | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-25-2012 10:24 PM |
| x940bt wiring help | encity5 | Electronics | Audio | NAV | Infotainment | 10 | 08-31-2012 05:08 PM |
| Is foglight wiring in the car? | FastLap | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-27-2012 12:54 AM |
