Old 07-02-2013, 02:57 PM   #43
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Tromatic View Post
Since it was built by Subaru, I'm going with nothing. I have yet to see any Toyota stamped parts in my FR-S. Who cares?
Toyota left some of it's identity (T) behind in the gauge cluster, dash panels and in the rear!
This was a joint venture between Toyota (exterior design with Subaru changing the front for their BRZ) and Subaru's chassis, drivetrain and boxer platform. Toyota utilized Subaru's FHI plant for production and both are essentially the same car with different spring rates.
Old 07-02-2013, 03:04 PM   #44
s0sl0w
Proud of Boxer
It's pretty simple really.
Trans, diff, fuel injection, styling, and spirit are toyota.
The motor, engineering, chassis, suspension, interior and everything else is Subaru in addition to being built by Subaru.
Probably one of the few real joint effort cars out there. As a Subaru guy I tend to think of it as more a Subaru but the truth is without either manufacturer this car wouldn't exist as it does. The biggest reason it does exist as it does is because Toyota wanted a new car and didn't want to dedicate the resources that would be required for them to make it (engineering teams/R&D and most importantly, a new factory).
s0sl0w is offline   Reply With Quote
Old 07-02-2013, 03:27 PM   #45
supragoods
Drives: Ravenfire
Thus which is being address by Krang also annoys Krang!
supragoods is offline   Reply With Quote
Old 07-02-2013, 03:30 PM   #46
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Just to be clear, since I noticed you said this in other threads too, the drivetrain is more Toyota than Subaru. The transmissions, differential, and even driveshafts, and axles/bearings are Toyota sourced. Not to mention the TRAC and VSC logic come from Toyota/Lexus RWD vehicles. But obviously the engine is more Subaru than Toyota.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 07-02-2013, 03:35 PM   #47
strat61caster
strat61caster's Avatar
Originally Posted by phenoyz View Post
Because very few motors that actually roll out of the factory will have exactly 268 hp. There are procedures set in place for measuring the power of a mass produced engine to account for the variability in the manufacturing process. Sure the engineers have a great level of control but it isn't worth the extra money to engineer up to 270 hp and why would they limit it to 265hp just for the pretty number?
And 198 hp is for Europe, I believe they had to "detune" a bit to meet emissions or handle the fuel better.
Edit: I tried to do some research on the GTR because I know there was some controversy there but it looks like the engine was tested and rated for 480hp at the crank but many tests put the actual cars closer to 520hp with some being at (or slightly below) where it's rated, might have something to do with evolving tinkering with ECU and manufacturing processes during initial production.
ineedyourdiddly
Old 07-02-2013, 03:51 PM   #48
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
This is the Chicken Dinner right here... Discussion sealed and delivered.
CO>CA Cartel
Norkoastal is offline   Reply With Quote
The Following User Says Thank You to Norkoastal For This Useful Post:
s0sl0w (07-02-2013)
Old 07-02-2013, 06:55 PM   #49
RRnold
2 wheel member
RRnold's Avatar
Yeah that's right since Subaru doesn't have much as far as rwd parts are concerned.
The Following User Says Thank You to RRnold For This Useful Post:
OICU812 (07-03-2013)
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 08:55 PM
Not a Toyota, Not a Subaru QFry Northwest 15 09-09-2012 01:35 PM
Toyota FR-86 vs. Subaru BRZ Levi Scion FR-S / Toyota 86 GT86 General Forum 12 08-30-2011 06:04 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
