Old 05-30-2013, 11:23 AM   #43
Opposed
Drives: 2013 Asphalt FR-S
Originally Posted by xjohnx View Post
Mods - Please don't lock this thread. There's a lot of good info in here. If need be, deal with people on a one off basis.
I agree. So to us with E85 in our tanks is it in our best interest to switch back to pump gas until we get more info and answers? I have a 1/4 tank left. So its either that or fill back up with E85 and play Russian roulette...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 05-30-2013, 12:11 PM   #44
Visconti
Drives: 05 STi
I think we all need more data.
Considering Dons filter looks just fine I wouldn't be super concerned.
If we can get some ethanol users to crack the filters open that would be great.
Not sure what part numbers are or items that need to be purchase to replace the filter or if it can easily be done
John
Visconti is offline   Reply With Quote
Old 05-30-2013, 12:30 PM   #45
xjohnx
Grip>Slip
xjohnx's Avatar
John
Please correct me if I'm wrong, but it's my understanding that this filter cannot be bought separately, it's part of the fuel pump assembly linked above, $285.
Old 05-30-2013, 12:31 PM   #46
mad_sb
Looks like it's a bit more than that. $269 ($359 list) is what I'm seeing (assuming we're talking about assembly 14, part # 42021CA000)
http://www.buysubarupartsnow.com/par...em/fuel-supply
THat is if you get the whole assembly with pump etc, you can buy just the top and filter section as part number 42052D for 150. We looked it up on the other thread that got locked
Old 05-30-2013, 12:43 PM   #47
xxscaxx
Drives: 2013 SWP BRZ
beat me to it - 42052D can be purchased separate from the whole assembly, which is the price I listed.
xxscaxx is offline   Reply With Quote
Old 05-30-2013, 12:55 PM   #48
xjohnx
Grip>Slip
xjohnx's Avatar
Do you have a link to any site that sells it?
I see the image on some obscure Russian site where it indicates the part number on some russian site, but when I search that part # on Subaru parts websites it doesn't come back as valid (nor does it look like a full part number, most subaru part #'s i've seen are 9 or 10 digits). Perhaps this is the OEM's internal part number for that part? Then again, maybe I'm wrong and it is available separately, just not seeing it on anywhere.
Old 05-30-2013, 01:06 PM   #49
xxscaxx
That number is more than likely the short version of it. I hit up my friend to get me the whole part number, if applicable.
You may have to order it direct through Subaru.
Old 05-30-2013, 01:25 PM   #50
xxscaxx
Here is the number he just sent me. Same as on that site.
42052CA110
search this number here, actually cheaper. 106.65 list.
https://www.subarugenuineparts.com/oe_parts_cat.html
OP - I'd add this to the first post
Old 05-30-2013, 01:58 PM   #51
xjohnx
Grip>Slip
xjohnx's Avatar
42052CA110
Awesome, great find!
Old 05-30-2013, 01:58 PM   #52
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I posted this yesterday and got no attention (aside from @Hawaiian) so I'll post again.
it is very possible the fuel canister is similar to other Subaru's (e.g. WRX/STI). That would help a lot as there are ton's of these cars with a lot of miles on E85.....
Edit: Looks very similar, although not exactly the same:
http://www.iwsti.com/forums/2-5-lite...ll-gr-gvf.html
Old 05-30-2013, 02:37 PM   #53
mad_sb
Perhaps that could be used for part of a return style conversion, but since we are returnless stock... I don't think we can scavenge much from that assembly.
Old 05-30-2013, 02:53 PM   #54
Sportsguy83
Drives: Limited BRZ
My point is more along the lines if WRX/STI uses the same filter, maybe it was more than E85 that caused the filter failure since there are TONS of these cars actively using E85 for a bunch of miles and different drive conditions with little to no issues.
Old 05-30-2013, 03:10 PM   #55
mad_sb
werd looks like a larger filter body on the wrx model, I'm sure someone has one laying around they could cut open and compaire the materials.
Old 05-30-2013, 03:28 PM   #56
xjohnx
Grip>Slip
xjohnx's Avatar
@Visconti has an STi on E85, no? I wonder if he's got one of these laying around?
e85, filter degradation
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 12:15 PM
“saddle-shaped” fuel tank ft86Fan Engine, Exhaust, Transmission 13 06-26-2012 04:22 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
