06-01-2013, 10:09 PM | #43 |
Professional Smartass
Drives: White Out FRS
I can't even get the application to open. I can install it, and move the necessary file, but it refuses to open. Windows XP SP3 VMWare on a mac.
For anyone that has a working VM could you be so kind to just PM me the file? I have been trying to get this piece of shit software to work for months and it seems impossible. Last edited by post_break; 06-01-2013 at 10:26 PM. |
06-02-2013, 03:08 AM | #44 | |
Drives: Brz WRB - Europe LHD
Diagnostic tools are preferable to run them on proper environment. This tools need, usually, much stability. Therefore accessing to car's core without stability can generate serious damages. A freeze while you are customizing some options can lock car system or units with no solution. I know that several tools for BMW as IDIS runs very well on WMware but a hard work to get it 100% compliant was made. The Techstream solution was not built to operate in emulation env., although it runs.
06-02-2013, 05:50 AM | #45 | |
/dev/null
Drives: Uphill
I dug out the old, tiny Asus Eee with XP for this, it works fine.
If you're stuck with Win 7, take note of this: Quote:
06-02-2013, 10:42 AM | #46 | |
Here is a link to the package that worked for me: https://skydrive.live.com/?cid=75C93...49501E9A%21126 Found it thanks to a Tundra forum. The MVCI MSI driver worked like a charm. For anyone having issues try this build, I can verify it works with Windows 7 32 bit in a virtual machine. |
The Following User Says Thank You to post_break For This Useful Post: | euroshowoff (08-29-2013) |
06-26-2013, 03:19 AM | #47 |
Software will not install
I'm running windows 7 and both links after downloading, will not install???
07-26-2013, 07:04 PM | #48 |
Drives: Subaru BRZ
Version 8.20.019 Software
Last Updated: 07/23/2013 Anyone got it?? Really want this latest version |
08-10-2013, 05:10 PM | #49 | |
Drives: FR-S 10 series
Yeah and by the way, my MINI-VCI cable came with the program in a mini-cd. 25$ in ebay |
08-10-2013, 11:55 PM | #50 | |
Socal Valley 86 Member
Drives: 2000 Toyota Tacoma SR5 & Scion FRS
Sent from my SPH-L710 using Tapatalk 4 |
08-11-2013, 02:16 AM | #51 | |
Drives: Subaru BRZ
I have been running ver. 8.00.034 with no problems and I have a Gulf spec BRZ. Latest version is Techstream 8.20.019, It is available on www.auto-professionals.co.uk but for some reason I have lost my account with them so cant download it!! I remember struggling to get it to work with my ebay cable but there is setting in the app where you change the cable you using from a mongoose to MVCI (as long as you have installed the drivers that came with your cable) and then worked fine. |
08-11-2013, 08:15 AM | #52 |
Drives: FR-S 6MT
08-11-2013, 09:58 AM | #53 | |
Best i can do. Dont have a computer nearby. Just search toyota mini VCI TIS techstream J2534 OBD2 diagnostic scanner+ software Free shipping |
The Following User Says Thank You to Pablitomarrero For This Useful Post: | Migero86 (08-21-2013) |
08-12-2013, 02:53 PM | #54 |
update to post #1 . Ver. 8.10 WITH MCI DRIVERS AND INSTALL GUIDE
this is the CD version you buy in ebay.....
08-12-2013, 02:59 PM | #55 | |
08-12-2013, 03:34 PM | #56 |
The Following User Says Thank You to Pablitomarrero For This Useful Post: | Trap63 (08-12-2013) |
Similar Threads | ||||
TPMS Tools | developer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 10-04-2021 01:28 PM |
anyone with a shop or tools | Tylub | Southern California | 0 | 05-14-2013 11:03 AM |
Tools? | Gost | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-03-2013 03:46 PM |
Tools for DIY maintenance? | F1point4 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 08-08-2012 07:47 PM |
