Old 06-01-2013, 10:09 PM   #43
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I can't even get the application to open. I can install it, and move the necessary file, but it refuses to open. Windows XP SP3 VMWare on a mac.
For anyone that has a working VM could you be so kind to just PM me the file? I have been trying to get this piece of shit software to work for months and it seems impossible.
post_break is offline   Reply With Quote
Old 06-02-2013, 03:08 AM   #44
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
I never tried to run it on emulation environment, the pics you see in first post are "screen capture" of my "wireless lan remote desktop connection" of a basic HP win7 32bit laptop.
Diagnostic tools are preferable to run them on proper environment. This tools need, usually, much stability. Therefore accessing to car's core without stability can generate serious damages. A freeze while you are customizing some options can lock car system or units with no solution.
I know that several tools for BMW as IDIS runs very well on WMware but a hard work to get it 100% compliant was made. The Techstream solution was not built to operate in emulation env., although it runs.
Trap63 is offline   Reply With Quote
Old 06-02-2013, 05:50 AM   #45
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I dug out the old, tiny Asus Eee with XP for this, it works fine.
If you're stuck with Win 7, take note of this:
Originally Posted by michaelahess View Post
Cheap ebay cable works fine. I've been using this nearly since I got the car last July. All my laptops are win7 64bit so I just run xp mode and install the software in the vm. You can use any vm software, and then just find a copy of win xp if you don't already have one.
Old 06-02-2013, 10:42 AM   #46
post_break
post_break's Avatar
I finally got it to work last night on my 7th virtual machine for the day. It's TIS 7.10.03 but it recognized the FRS and it didn't nag about registration. All the settings worked and I was able to adjust various things.
Here is a link to the package that worked for me: https://skydrive.live.com/?cid=75C93...49501E9A%21126
Found it thanks to a Tundra forum. The MVCI MSI driver worked like a charm. For anyone having issues try this build, I can verify it works with Windows 7 32 bit in a virtual machine.
The Following User Says Thank You to post_break For This Useful Post:
euroshowoff (08-29-2013)
Old 06-26-2013, 03:19 AM   #47
Aaron_blatherwick
Software will not install
I'm running windows 7 and both links after downloading, will not install???
Aaron_blatherwick is offline   Reply With Quote
Old 07-26-2013, 07:04 PM   #48
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Version 8.20.019 Software
Last Updated: 07/23/2013
Anyone got it??
Really want this latest version
ahaghshenas is offline   Reply With Quote
Old 08-10-2013, 05:10 PM   #49
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
I can confirm this as well. Didn't even ask for registration, I just exchanged the main menu file provided with the one that comes on the file. No issues, works fine
Yeah and by the way, my MINI-VCI cable came with the program in a mini-cd. 25$ in ebay
Pablitomarrero is offline   Reply With Quote
Old 08-10-2013, 11:55 PM   #50
niceguy21
Socal Valley 86 Member
niceguy21's Avatar
Drives: 2000 Toyota Tacoma SR5 & Scion FRS
You think you can provide a link to the ebay seller? That's would be awsome!
Sent from my SPH-L710 using Tapatalk 4
niceguy21 is offline   Reply With Quote
Old 08-11-2013, 02:16 AM   #51
ahaghshenas
Drives: Subaru BRZ
I have been running ver. 8.00.034 with no problems and I have a Gulf spec BRZ.
Latest version is Techstream 8.20.019, It is available on www.auto-professionals.co.uk but for some reason I have lost my account with them so cant download it!!
I remember struggling to get it to work with my ebay cable but there is setting in the app where you change the cable you using from a mongoose to MVCI (as long as you have installed the drivers that came with your cable) and then worked fine.
Old 08-11-2013, 08:15 AM   #52
Mikem53
Drives: FR-S 6MT
Got mine on amazon for $25. Search on mini vci. Screw ebay
Mikem53 is offline   Reply With Quote
Old 08-11-2013, 09:58 AM   #53
Pablitomarrero
Best i can do. Dont have a computer nearby. Just search toyota mini VCI TIS techstream J2534 OBD2 diagnostic scanner+ software
Free shipping
The Following User Says Thank You to Pablitomarrero For This Useful Post:
Migero86 (08-21-2013)
Old 08-12-2013, 02:53 PM   #54
Trap63
Trap63's Avatar
update to post #1 . Ver. 8.10 WITH MCI DRIVERS AND INSTALL GUIDE
this is the CD version you buy in ebay.....
Old 08-12-2013, 02:59 PM   #55
niceguy21
niceguy21's Avatar
Attachment 47595
Free shipping
Thanks! ill give it a look later on today
Old 08-12-2013, 03:34 PM   #56
Pablitomarrero
yep, thats what i got
Trap63 (08-12-2013)
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 01:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
