Old 08-01-2015, 12:07 PM   #43
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Just FYI, I'm not talking about "moisture", I'm talkng about "liquid refrigerant".
Moisture in the system can cause problems, but unless the system has been discharged and/or opened, its pretty much impossible for moisture to ingress.
But the compressor pumps liquid refrigerant to the expansion valve in the evaporator, and then the refrigerant expands and boils off, (that's what creates cooling) and returns to a gas.
But if the low (return) side pressure/temperature is too low, the refrigerant won't completely return to a gas, and any liquid returing to the compressor will destroy the compressor.
The temp and pressure switches cycle the compressor on and off, which both maintains a near-constant evap temp, and protects the compressor.
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
stevesnj (08-01-2015)
Old 08-01-2015, 05:41 PM   #44
Poodles
Drives: 2015 Series.Blue
Originally Posted by FRSBRZGT86FAN View Post
I don't know if its just me but if I go WOT sometimes the cooling just stops and it feels like just warm air blowing out, does anywhere know where that issue comes from?
Normal. A/C clutch is disengaged when over a certain throttle %
Old 08-01-2015, 09:13 PM   #45
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Interesting thanks.
Old 07-29-2017, 04:04 PM   #46
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Older cars used Freon and that will produce a cooler temperature than the environmentally safe R134a that's put in modern cars.
slizoth is offline   Reply With Quote
How Blow Off Valves Work ATSAaron Forced Induction 47 07-16-2014 07:38 PM
**Visconti Tuning Vortech ProCharger Spring Blow-Out Sale** Rich@ViscontiTuning Forced Induction 133 05-10-2013 02:31 PM
XXR 527 18X8.75 35 OFFSET - GOLD FINISH - BLOW-OUT-PRICES!!~!~! MIKE@MRTIRESOLUTIONS Wheels and Tires 1 12-12-2012 01:57 PM
Volk Racing/Gram Lights blow out sale Stav Canada Classifieds 9 11-30-2012 05:40 PM
***CUSCO COILOVERS BLOW OUT PRICING*** genometuning Brakes, Suspension, Chassis 11 10-23-2012 06:54 PM
