Old 07-17-2014, 02:44 PM   #43
Whitesoul
What are your guys preference on an Air Filter? I'm looking into buying my own soon!
Whitesoul is offline   Reply With Quote
Old 07-19-2014, 06:39 AM   #44
belgt86
belgt86's Avatar
Drives:
Cosworth dry filter
belgt86 is offline   Reply With Quote
Old 08-31-2014, 01:01 AM   #45
Flow
Drives: DGMBRZ
bump for tomorrow = aFe dry filter
Flow is offline   Reply With Quote
Old 01-21-2015, 07:54 PM   #46
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
I know this is an old thread but I can confirm that it's normal to see the edge of the air filter
I've never touched the air box since I bought the car new and this is from the factory
Young_makaveli is offline   Reply With Quote
Old 06-17-2015, 11:43 PM   #47
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I had mine sitting incorrectly for a while until I saw this thread and checked it. I bought a Wix air filter that has the rubber/plastic around the edges so it fits better than stock and I got mine to noticeably snap into place and seal all around. You can feel it when its sealed and you can see the two sides of the air box are aligned parallel with each other then its in correctly. Thanks again for this helpful post.
DandoX is offline   Reply With Quote
Old 07-13-2015, 05:33 PM   #48
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Thank you, I can rest easy now.
On a side note does anyone know if the K&N filter comes already oiled? or does oil need to be applied on first install?
Spacemane969 is offline   Reply With Quote
Old 07-13-2015, 07:44 PM   #49
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
It comes already oiled.
Cliu91 is offline   Reply With Quote
Old 08-14-2015, 05:58 PM   #50
DCdesign2000
DCdesign2000's Avatar
Drives: Civic Hyb, RS6, BRZ SeriesBlue
Has there been discussion or similar comparisons on the OEM Engine Air filter vs Mann-Hummel MA 1026 vs MAHLE Original LX 1286?
Thanks!
DCdesign2000 is offline   Reply With Quote
Old 08-27-2015, 03:44 PM   #51
mixedjuice
Drives: 2015 BRZ - sold & 2014 Legacy Sport
Very thankful for this DIY - most appreciated by all BRZ owners.
mixedjuice is offline   Reply With Quote
Old 11-03-2015, 10:07 PM   #52
Selvedge
I'm not saying I recommend doing it this way, but you can angle up the rear of the airbox and you don't have to unbolt anything. It's still really difficult and I probably would've saved more time if I unbolted everything, but I didn't have my tools handy.
Selvedge is offline   Reply With Quote
Old 12-25-2015, 03:29 PM   #53
lupindub
Drives: Scion FR-S
Edit: Deleted because I did not realize how much the air intake thing can bend. Embarrassed to say it took me 2.5 hours to do a freaking air filter change.
lupindub is offline   Reply With Quote
Old 12-25-2015, 03:32 PM   #54
swarb
Originally Posted by lupindub View Post
Okay i'm not sure what i'm doing wrong but whenever im trying to remove the "snorkel" part of the filter, the part I circled in red seems to bend like crazy and is not coming off.
Remove parts around it. Remove sound tube and remove the elbow from the throttle body and pull the whole intake out.
I believe you have to pull the bumper off to remove the snorkel.
Old 04-04-2016, 08:17 PM   #55
EssJay
Drives: '16 FR-S Halo White
I can't really tell if I need to do this your way. I didn't have tools at the time so I simply opened the top clips, loosened the engine-side of the 2 halves of the box, and fussed with it until I figured out how it fits and resecured all 4 points.
Is there any part of the installation that is impossible without doing it your way or am I ok?
EssJay is offline   Reply With Quote
Old 06-08-2016, 05:01 AM   #56
Br1gz
Drives: Black GT86
I'm in the same boat. I feel like I did it properly but my OCD keeps kicking in and I can't help but think something is off. Is it possible to install the k&n air filter without removing any bolts?
Br1gz is offline   Reply With Quote
DIY Cabin Air Filter Inspection/Replacement F1point4 DIY (Do-It-Yourself) Guides 137 08-12-2023 06:32 PM
Trd drop in filter Vino Engine, Exhaust, Bolt-Ons 3 04-14-2013 11:08 AM
FS: K&N Drop-in Filter DookDookDGM Engine, Exhaust, Bolt-Ons 4 01-19-2013 01:45 AM
Best drop-in replacement speakers RYU Electronics | Audio | NAV | Infotainment 4 10-10-2012 02:15 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
