Old 10-15-2013, 12:14 PM   #43
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Anyone still having fitment issues with the PLM Overpipe?
I just ordered one and hope to install it this weekend. With any luck I can perform the "push up while tightening" install method and end up with good clearance and no rattles. I'm beginning to think that is critical to any cat-forward exhaust install.
Old 10-16-2013, 02:34 AM   #44
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
No fitment issues. Use the push up and tighten method you'll be fine. I did have a bolt missing when I checked mine yesterday. Maybe use thread locker.
Sent from my iPhone using Tapatalk - now Free
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 10-18-2013, 01:35 PM   #45
ATL BRZ
ATL BRZ's Avatar
Received my PLM OP today. This thing is really light!
More pics and initial review in my build thread.
Installing it this weekend.
Old 10-20-2013, 03:19 PM   #46
ATL BRZ
ATL BRZ's Avatar
Installed mine yesterday along with a JDL UEL header.
This pic was taken AFTER installing 5mm thick washers inbetween the body and all the swaybar mounting bracket bolts. I have a bigger Racecomp hollow front sway bar and wanted as much clearance at possible, so I effectively lowered the sway bar assembly just a tad.
I noticed today that it's hitting the frame and making noise when taking a sharp left turn under load and when accelerating from a stop on an incline. It's quiet otherwise. I had someone else push up on it as much as possible with a long pry bar while I tightened it down and I still ended up with maybe 1cm of clearance from the frame.
Any ideas on how to get more frame clearance? I'm considering stiffer engine mounts to help.
Old 10-20-2013, 06:00 PM   #47
Tim_Asphalt_FRS
Is it fast? No.
Stiffer engine mounts would probably help. Also a thinner solid sway bar instead of the hollow one. Whiteline are solid.
Old 10-20-2013, 08:17 PM   #48
ATL BRZ
ATL BRZ's Avatar
I have no issues with swaybar clearance. Only the frame.
Old 10-21-2013, 12:27 AM   #49
Tim_Asphalt_FRS
Is it fast? No.
Hmmm. Maybe it's the header that changes the angle of the pipe. I still have stock header.
Old 10-29-2013, 08:27 AM   #50
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
I see a lot of talk about the over pipe, but what about the front pipe?
pixel67 is offline   Reply With Quote
Old 10-29-2013, 10:14 AM   #51
MAPerformance
Drives: Asphalt FRS
What about it? There is a ton of front pipe talk on this forum. Lots of good info out there. PM me if you have other questions.
MAPerformance is offline   Reply With Quote
Old 10-29-2013, 04:02 PM   #52
sw20kosh
Drives: 2013 Black FR-S
Nope. I tested this OP with 3 headers and they all rattled on the frame. It is a poor design.
I ended up using home depot exhaust vent insulation (the one that has adhesive on one side and foil on the other) on the frame where the OP is hitting. I used 3 layers of this insulation which cushions the OP when it tries to hit the frame. No more rattles.
@Tim_Asphalt_FRS
Old 10-29-2013, 04:08 PM   #53
Tim_Asphalt_FRS
Is it fast? No.
@Tim_Asphalt_FRS
Glad you fixed it. I wonder why you guys have rattle issues and I don't?
Old 10-29-2013, 04:12 PM   #54
ATL BRZ
ATL BRZ's Avatar
My OP rattle seems to have mended itself a little bit after a weekend of track abuse. Maybe it got hot enough that when it contacted the frame it dented the pipe and made clearance on its own!
It's not making contact nearly as often as before last weekend. I will try applying a few layers of metal tape to the frame next time I'm under there.
Old 10-29-2013, 04:18 PM   #55
forzajuve
Drives: Ultramarine 86 - 6MT
If someone is looking for some gains in overall sound and loudness of exhaust I think it is a decent and inexpensive, muffler delete option - I think their track pipe is a decent way to go. In fact I expect to order their track pipe in the next few days so I can joyfully drive it around California not being quiet
Plus, it is only $75 + shipping on ft86speedfactory.com.
If you want a tip too, you can buy generic ones that will fit into most size pipes. Just google it up
forzajuve is offline   Reply With Quote
Old 11-15-2013, 12:39 PM   #56
wrussi
wrussi's Avatar
Drives: 2013 frs
just ordered mine. this will go along with a nameless catted front pipe and a revworks header. we'll see if mine hits the frame...
wrussi is offline   Reply With Quote
Agency Power Front/Over pipe (Combo pipe) - Cheap! seven Engine, Exhaust, Bolt-Ons 12 03-09-2013 01:40 AM
FA20CLUB Over Pipe Front Pipe & Cold Air Intake Now Ready FA20Club.com Engine, Exhaust, Transmission 171 02-27-2013 09:44 AM
Will a resonated front pipe make alot less noise than test pipe? Mike86 Engine, Exhaust, Transmission 8 01-26-2013 07:24 PM
Agency Power over-pipe/front pipe combo question... seven Engine, Exhaust, Transmission 11 01-13-2013 12:14 PM
