Old 01-21-2012, 01:13 AM   #43
Reflections
Reflections's Avatar
Drives: Subaru
Originally Posted by Dillano609 View Post
Jaw droppingly low I hope, lol
Of course, of course! :O 21k
Reflections is offline   Reply With Quote
Old 01-21-2012, 01:21 AM   #44
devinclfalcons
Drives: Evo X MR
I'm putting my money on 30 mpg combined.
26 city/34 hwy
devinclfalcons is offline   Reply With Quote
Old 01-21-2012, 02:49 PM   #45
MRZ415
Drives: 2015 Subaru WRX
I got a feeling I'll get shitty mpg at first because i'll drive for fun ...
then back to reality then I'll be riding 6th gear once on the freeway.
I get 35mpg in my DIESEL .. so I figure with my driving style
maybe 30mpg hwy in the brz.
MRZ415 is offline   Reply With Quote
Old 01-21-2012, 07:39 PM   #46
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by switchlanez View Post
So the new FB20 engine in the 2012 Impreza is 2 liters and gets 27 city/36 hwy mpg with CVT and 25 city/33 hwy for the 5MT. But it outputs 150 hp on the 2,900 pound Impreza.
The FR-S/BRZ's FA20 is based on the FB20. Also 2 liters but difference is it's been tuned to 200 hp. The D-4S direct injection is supposed to increase hp and fuel efficiency but I think the engine has to run richer (consume more gas) to achieve the huge +50 hp bump and tuning is skewed more towards power than efficiency. The FR-S/BRZ is 200 lbs. so that helps.
200 lbs. lighter but +50 hp? I think it would have the same or worse efficiency numbers than the 2012 Impreza. Also, CVT makes a difference which our car won't have. And Impreza's 5MT is geared for fuel efficiency; our 6MT should be geared for some mix of performance/fuel efficiency.
Errr...the engine only runs rich near max load and idle. And direct injection reduces the amount of fuel you need because it improves combustion efficiency and reduces cylinder temperature. In addition, the long duration cams reduce pumping loss, and the direct injection makes up for the lack of charge motion due to high lift. If anything, the FA20 should be the more efficient engine at every point.
Anyways, CVT would help in the city, but would hurt on the highway because it has high frictional losses. The manual transmission doesn't have a very tall 6th gear so it won't cruise near max. efficiency, although based on my calculations it should be able to pull a respectable 40+ mpg at 60mph. The auto has very tall 6th gear so it could hit 50mpg. Also you have to remember, rolling resistance is a very small force compared to aerodynamic drag. The Impreza is much bigger dimensionally, and will have more drag.
EPA highway != highway cruise mpg. EPA highway test includes lots of slowing down, speeding up, etc. I dunno about other people, but on the highway I almost never need the brake, and I certainly do not slow down to <45mph very often.
Old 01-21-2012, 09:51 PM   #47
devinclfalcons
Drives: Evo X MR
I didn't know that it was already known that the auto has a taller 6th gear... Wonder how much difference it will make?
I doubt either will get more than 40 mpg... High 30's at best at optimum conditions...
Old 01-21-2012, 10:02 PM   #48
serialk11r
It makes a huge difference actually. The Civic Si has a super short 6th gear and it can do high 30s cruising. Typically cruising gear places the engine in the 20% full BMEP range, where efficiency is horrendous. Just by changing the gear, you can typically reduce fuel consumption 30% under steady state cruise, although it reduces the extra power available.
If the Civic Si was geared a bit longer, it could do >>40mpg. Any modern, small car is capable of 45mpg on the highway or better if the highest gear is at the right ratio. Engine mechanical efficiency these days is pretty high, combustion efficiency is good, so what's left is pumping loss due to suboptimal operating conditions.
FYI, the brochure released says auto is 4.100 final drive, 0.582 6th gear, while manual is 3.727 final drive, 0.767 6th gear. That puts 60mph at around 2350rpm for the manual, 1960-70 rpm for the auto (quite remarkable, my mom's 3.5L Honda Pilot has this cruising rpm!). The auto would probably be somewhere around 80-90% peak efficiency, while the manual would be at 70% of peak efficiency or so. The mpgs an automaker can pick up by making 5th/6th gears taller is by far the easiest mpg they can pick up, as it costs no money whatsoever.
See my posts in this thread.
http://www.ft86club.com/forums/showp...8&postcount=60
The only downside is you can't be lazy and expect great passing power in 6th. IMO 2000rpm at 60 is a good gearing, more than enough torque to go up the steepest grades, efficiency nearing 10% of peak.
Old 01-21-2012, 10:24 PM   #49
devinclfalcons
Drives: Evo X MR
If the auto can get 3 mpg more than the manual on the highway, I will have to go with it over the manual. I have a 90 mile round trip to work and that could be a lot of money saved in gas...
Old 01-21-2012, 10:26 PM   #50
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
my car idles at 2800 at 60... i wouldnt sweat it... i still get 35mpg average highway..
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 01-21-2012, 10:41 PM   #51
serialk11r
Well the auto probably costs more too, you'd have to be driving for quite a while to save that money back. Using 2 gallons a day vs. 1.8-1.9 gallons a day is not much of a cost difference. Not to mention, city mpg is probably worse. Unless you wanted an auto in the first place.
And also beware that I am doing calculations for 60mph cruising. As you go faster the gap closes due to higher torque requirement. So at 70-80 the difference might shrink quite a lot.
Personally I'm hoping they revise the ratios and drop 6th gear rpms a little more. It's free mpg numbers that they are choosing to not pick up for whatever reason. Lotus used retardedly short 6th gear, which killed their mpgs as well.
Old 01-22-2012, 10:44 AM   #52
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I predict 28 mpg combined. It's suppose to require super unleaded right?
tripjammer is offline   Reply With Quote
Old 01-22-2012, 12:04 PM   #53
suprachica79
Drives: free Hyundai, 2006 Kawasaki ZX6R
I got you beat! 150 mile round trip and I'm still going with manual, I think it'd end up equal or still a bit better in manual.
suprachica79 is offline   Reply With Quote
Old 01-22-2012, 01:17 PM   #54
ryude
Drives: Volkswagen GTI
Assuming the auto is $1000 more than the manual, the auto gets 3mpg more, and the gas price never increases (unlikely). It would take 18 years to make up the extra $1000. That's not taking into account the extra maintenance that autos require over a manual.
ryude is offline   Reply With Quote
Old 01-22-2012, 01:18 PM   #55
suprachica79
Thanks for doing the math, I didn't feel like it
Old 01-22-2012, 05:08 PM   #56
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I like the way this serialk11r person thinks.
