Old 02-24-2013, 12:23 AM   #43
blkwrxwag
Drives: DS FRS
Are the stock lugs ok with a 3mm spacer?
blkwrxwag is offline   Reply With Quote
Old 02-24-2013, 12:44 AM   #44
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
Originally Posted by feldy View Post
Ok so here are pics of my 17x9 +35 Rpf1's with Toyo R1R's 245/35/17 Stock height for now. Will be on RCE yellow springs here in the next month. Camber is set at -2degrees currently.
do you have the camber bolt ? or can you adjust rear camber i believe you cant on stock? if you can thats cool and if it is how do you do it? i didnt see any rear camber adjustment when it was on a lift. i know whiteline sells the camber bolt adjustment bolt set?
DanoFA20 is offline   Reply With Quote
Old 02-24-2013, 08:22 AM   #45
Captain Insano
No adjustability in rear. People commonly are getting whiteline solution or LCAs with camber adjustability for the rear. I have SPC LCAs.
Old 03-09-2013, 03:27 PM   #46
wgnzlz
wgnzlz's Avatar
Drives: 2013 WRB BRZ Limted
Homemade center caps. Cost me $11.53 including the paint.
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
wgnzlz is offline   Reply With Quote
Old 03-15-2013, 04:24 PM   #47
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Help, 17x9 +35 or +45 RPF1?
With coilovers there is room to add camber. 1.5 degrees and I reckon they fit spot on. They didn't before. The +35s would poke a bit too much for me.
86•BRZ is offline   Reply With Quote
The Following User Says Thank You to 86•BRZ For This Useful Post:
karma003 (10-13-2013)
Old 03-16-2013, 11:05 PM   #48
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
here is a shot of the clearance (17x9 +45) 1.5 degrees camber adjusted via the clevis bolts not the camber top
plenty of room!
The Following 3 Users Say Thank You to 86•BRZ For This Useful Post:
adprokid (04-13-2013), Amadeus (03-17-2013), karma003 (10-13-2013)
Old 04-13-2013, 09:57 PM   #49
keen as
keen as's Avatar
Drives: 86 GT MT
plenty of room!
Probably a basic question.
I'm considering RPF1 17x8 +35.
1 inch less width is 1/2 inch less width on outside tyre (and the other half inch on inside tyre), and the 10mm more poke... does that mean the fit to the outside of the guards will be the approximately the same as your pics? I.e no more poke?
Thanks.
keen as is offline   Reply With Quote
Old 04-13-2013, 10:14 PM   #50
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
yep, they would be 2mm less poke than these which is just about perfect.
It would still poke a little without any negative camber
speak to josh @86drift for wheels if you're in sydney
keen as (04-22-2013)
Old 04-23-2013, 05:43 PM   #51
Goya
Goya's Avatar
Drives: 2013 SWP BRZ
do you have a picture for reference what the +45 look like on stock suspension as far as poke or lack there of?
cause im thinking that getting the +45 with maybe a spacer to dial in the offset that works
Goya is offline   Reply With Quote
Old 04-24-2013, 03:14 AM   #52
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
not really sorry, this was a crop of the car in the background of a shot:
the bottom line is that even with the +45, they poke out and look a bit odd.
With lowering and some camber it now looks like it is supposed to be there.
you can't make the +45 look like it fits, spacers will only make it look worse.
just get the 17x8 +45, at least for the front.
Old 04-24-2013, 11:42 AM   #53
Goya
Goya's Avatar
But I want them so bad!!!!!
I thought you were the +45 advocate? ha
Thats not really that much poke, especially if i get some springs im sure it would bring it in a tad...not really willing to do coilovers
Old 04-24-2013, 04:35 PM   #54
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
I am. +45 look better in my opinion than +35. It's just very tight.
+35 look silly on std suspension with the poke. Camber can fix this to some degree
+45 almost look great. It's just a tight fit that will depend on the tyre and there is no room left to add camber if you desire unless you went whiteline com c strut tops. Remember camber is not just for looks, a little can be beneficial if you desire.
Old 04-28-2013, 06:18 PM   #55
keen as
keen as's Avatar
Drives: 86 GT MT
Thanks for the last few posts.
Your tyres/suspension setup looks perfect.
I will not get adjustable suspension for a while. After your advice, I'll look at getting 17x8 +45, and use camber bolts in the front.
Old 04-29-2013, 04:22 AM   #56
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
9s for the rear?
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 06:23 PM
