Old 02-18-2013, 10:48 PM   #43
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
From memory, there's plenty of space down there, worse case a small hole and slit in the vertical panel between the frame rail and metal underpan. 100% sure there's space on the pass side, and should be space on the drivers said also.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ayau (02-18-2013)
Old 02-19-2013, 07:14 PM   #44
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by ayau View Post
Where does the external reservoir hose go through? Hopefully you don't have to cut a hole in the fender guards.
Nope, slide right in near the brake hard line, no mods required.
mines13 is offline   Reply With Quote
The Following User Says Thank You to mines13 For This Useful Post:
ayau (02-19-2013)
Old 02-19-2013, 07:15 PM   #45
mines13
mines13's Avatar
Super busy with supercharger stuff and being down a coworker. (wedding) Yes, every R1/R2 is dyno tested before they ship to the customer. These things ride extremely well on the street, even with 400lb springs front and rear. a single click on rebound or compression makes a massive difference. Pretty sweet, I am still working on dialing them in. Went to a 255 tire and they are much less communicative then my 225's were... I'll post more later.
CSG Mike (02-19-2013)
Old 02-19-2013, 08:33 PM   #46
ayau
Drives: Some rust bucket
I'd be interested in seeing a race between the Tein SRC and the Eibach R2.
@CSG Mike
Old 02-19-2013, 08:38 PM   #47
@CSG Mike
You trying to spark a fire?
Old 02-19-2013, 11:39 PM   #48
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
lol Eibach multipro R2 vs Tein SRC vs KW clubsport that ought to be interesting
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
The Following User Says Thank You to brianlo622 For This Useful Post:
TAP Auto Parts (05-13-2013)
Old 02-20-2013, 12:03 AM   #49
Hanakuso
that's exactly what I want to see as well. Plus the RCE Tarmac
Hanakuso is offline   Reply With Quote
Old 02-20-2013, 12:59 AM   #50
mines13
mines13's Avatar
Well Mike is gonna be faster then most people on stock dampers then most would be with any of the whiz bang fancy stuff... That said, If I had to wager a guess, I would say that he would dig the R2's in this application. Super plush and oh so easy to tune and customize for spring rate and valving.
Old 02-20-2013, 02:00 AM   #51
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Same car, same driver, same tires, swap the coils and run laps = problem solved
temperatures and stuff change too much though and too much set up required you can't go wrong with any of the above mentioned coilovers.
JoeBoxer is offline   Reply With Quote
Old 02-20-2013, 02:31 AM   #52
If you guys supply the cars, I'll supply the tires. I'm down to do a back-to-back test!
In consideration of time, I'd ask that each car be set up to what the manufacturer believes to be ideal for damping, as well as alignment.
I'm thinking the spec tire should be 225 RS3. We can draw straws to see which car goes first.
If you want to make it double blind, make the cars identical colors, and blindfold me until I'm in the car, so that I don't know what suspension I'm driving on (although I'll probably be able to guess once I start driving).
Anthonytpt (05-15-2013)
Old 02-20-2013, 02:32 AM   #53
ayau
Someone supply a car for Mike! Can we wager bets on which setup will be faster?
Old 02-20-2013, 02:46 AM   #54
RYU
RYU's Avatar
Drives: really slow...
Actually I'd like to also see an r1 vs r2 time attack!
RYU is offline   Reply With Quote
Old 02-20-2013, 02:52 AM   #55
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
If we both ever end up at the same track I'm game
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-20-2013, 02:53 AM   #56
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Assuming spec alignment... Whoever set the dampers up better. Assuming mike can tune them to his liking... Who the hell knows.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Eibach Multipro R1 and front and rear sway bar installed Pekingduck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 12-30-2013 11:59 AM
AST's at buttonwillow raceway Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 07-02-2013 04:16 PM
◙◙◙ [NY Local] SPECIAL on Eibach Sportlines Installed | Real Auto Dynamics ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 48 06-07-2013 03:19 PM
Buttonwillow Track Day Heads-Up sv_dave Southern California 3 09-08-2012 10:20 AM
