Old 12-27-2013, 10:43 AM   #43
Aufire23
Did anyone notice a slight wobble in their OEM pulley? My Perrin has been on for 4000 miles but it still has a slight wobble at the bolt to the crank, it may just be an optical illusion.
Aufire23 is offline   Reply With Quote
Old 12-27-2013, 10:47 AM   #44
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Watch the grooves where the belt goes as it turns. You may be seeing things.
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out
2003 Nissan Sentra SE-R Spec-V - Traded for next car
2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss.
1997 Mazda Miata - Current
thejevans is offline   Reply With Quote
Old 12-27-2013, 11:37 AM   #45
Aufire23
Everything lines up, maybe it's time for an eye exam.
Old 12-27-2013, 11:59 AM   #46
thejevans
thejevans's Avatar
I think the issue is that the head of the bolt isn't perfectly round so it distorts what you see.
Old 12-27-2013, 12:06 PM   #47
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Yeah I know what you're talking about, but look at the pulley itself, shouldn't be wobbling. My bolt looks like that too but my pulley doesn't wobble one bit
Old 03-07-2014, 06:32 AM   #48
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Originally Posted by Gani21 View Post
Anyone ever do this on an automatic
Originally Posted by Gopherboy6956 View Post
Should be the exact same process.
I bought a light weight pulley set (3 pieces) and when I had to take off the camshaft pulley, I noticed that, even in park with E Brake up, the pulley still spins freely, causing me to not loosen the bolt. For AT guys, you need to pick up a Camshaft Pulley Stabilizer tool to hold the OEM camshaft pulley in place.
Here is a picture of "Schley Products, Inc Universal Camshaft Pulley Holding Tool" for what AT people will need to stabilizer the camshaft pulley for removal. You can find this at Sears or Advanced Auto.
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 03-15-2014, 02:25 AM   #49
Hmongfrs
Drives: Red
Just got done installing my circuit werks pulley kit and yes that crank pulley spacer scared the s*** out of me....pulled the stock pulley out slowly and the spacer came out with it, right when I saw it, I was like f*** what did I just do..first thing pop in my mind was to put back in since I didn't pull it out all the way...luckly it went straight in and sit flush, installed everything, start the car pulley no wobble no leaks no nothing...
Hmongfrs is offline   Reply With Quote
Old 04-16-2014, 01:21 PM   #50
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Just a small tip for everyone: use a few extensions to pull of the original pulley like @Gopherboy6956 suggested, then use a sharpie to mark the timing cover and the crankshaft pulley spacer. it makes reinstalling the spacer a piece of cake.
supramkivtt2jz is offline   Reply With Quote
Old 05-05-2014, 03:18 PM   #51
johnnyfast11
Drives: none yet
do i need to get an o-ring if the seal did not come out at all??? thanks.
i dont think so but please let me know if its recommended to take it off and replace.
johnnyfast11 is offline   Reply With Quote
Old 05-05-2014, 04:09 PM   #52
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Yes. If you can see it, you need to replace it.
it will 'probably' be fine, but not worth a potential leak for a $2 o-ring.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 05-30-2014, 01:13 PM   #53
johnnyfast11
Drives: none yet
praise to OP and others on the installation tips.
I used something to hold the sleeve in before sliding out the oem pulley. That was my biggest concern. and it was a success.
cheers.
and thanks again to all that contributed to this thread.
Old 10-07-2014, 09:06 PM   #54
07jazzrs5gt86
Drives: Firestorm 86
http://wardmuscatellsubaruparts.com/...&siteid=216475
Seems like this is the correct o ring i need but just want to make sure so when i go to the dealer tmr i can pick up the right part
Also it should be the same part number for the frs?
07jazzrs5gt86 is offline   Reply With Quote
Old 12-25-2014, 01:27 PM   #55
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Ok, so, just installed my Raceseng crank pulley. Couldn't have been easier, honestly. What I ended up doing with the crankshaft pulley spacer was to almost take the bolt all the way out, and then held the bolt with my thumbs and slipped the pulley off. Then, held the pulley with one hand, undid the last thread of the bolt with my other hand and popped it out. Everything stayed put that should've. Checked position of the O-ring, popped the new pulley on, hand tightened the bolt, torqued it, put the belt back on and put the intake back in. Piece of cake.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 05-06-2015, 09:36 PM   #56
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Just saw this thread and thought I'd double check things. I installed the Perrin crank pulley a couple weeks ago. In that time, I've driven it a little hard on the street, back and forth to work for 2 weeks, and even had a track day at Road America where I essentially put it through hell. Tonight, I figured I'd better check on this since it's the first I've heard of it. I didn't run into any apparent issues with it during install and thought nothing of it.
The pulley doesn't appear to be wobbling AT ALL. I looked at a straight edge on it in several different positions and watched as close as I could. No indication of it wobbling whatsoever. The bolt, however, I can't honestly tell if there is a slight wobble or not. It's sitting flush against the pulley, which the pulley itself isn't wobbling...so I'm guessing I don't have to worry about the bolt head and how it looks.
I have no leaks, it ran like a champ at very high rpm for 20min sessions at a time, and the pulley itself doesn't wobble.
Your thoughts?
Apex_BRZ is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Kartboy crank pulley Turn in Concepts Engine, Exhaust, Bolt-Ons 5 05-22-2013 10:51 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
