#43 |
#44 | |
As I see it with EcuTek and the tuners, you aren't really buying a static tune. I may be wrong but I think as long as you stick with NA (Gas/e85/Flex) or FI (Gas/e85/Flex) these tuners will support you. You also pay for the added comfort of knowing that these tuners know this car better than we do from the tuning side of things. I guess if you fancy yourself as an experienced tuner you might be a little miffed about the prospect of being doomed to not decide how to tune your car, but I am sure that these tuners will cater to your wants within reason...and I'm sure they will help push your car to the point where it pops as long as there is a contract of sorts stating you accept the consequences of pushing beyond "safe" limits to cover their asses. Ultimately the software to be an EcuTek tuner is available...here's their site: http://www.ecutek.com/Products/ProEC...cion_FR-S.aspx But if $1000 seems steep to have a good tune, then I'm just gonna go out on a limb and guess this is far more than that... |
#45 | |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
http://www.ft86club.com/forums/showp...0&postcount=26
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
| The Following User Says Thank You to seven For This Useful Post: | Cross (09-13-2013) |
#46 |
Drives: SS BRZ LMTD 6MT, 92 Civic hatch RHD
I for one would be glad to pay a premium for a solution that allows me to modify my maps and parameters at will. As long as it has a full feature set to allow for future modifications, boost by gear, electronic boost control, etc.
Open source is always going to lag behind with the features. Im not holding my breath but it would be great if a viable open source solution existed. ECUtek doesnt allow me to change my own parameters at will. Not paying that much for essentially a flash that i have no control over. I know im not the only one holding out for a real viable tuning solution that i can pay for, then have a reputable tuner tune, then freely modify as i see fit at home with my laptop. If it has the features i want, i will pay for it. And i'm sure i'm not the only one. |
#47 |
Grip>Slip
So who's going to be the first person to set up a company, buy the ecutek suite, setup a citrix/terminal server and start renting out ECUTek map tuning access time?
| The Following User Says Thank You to xjohnx For This Useful Post: | Deepseadiver (02-10-2013) |
#48 |
Drives: GT86
| The Following User Says Thank You to ft_sjo For This Useful Post: | Sportsguy83 (01-05-2013) |
#49 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
http://brzedit.com/index.php/2013-01-22-04-55-54
Software has now been released, $1500 for the pro version looks like decent value to me
#50 |
Grip>Slip
i always trust companies with my money when they have email addresses such as brzedit@gmail.com and have yet to produce a video or any other evidence of this working on a BRZ.
| The Following User Says Thank You to xjohnx For This Useful Post: | Sportsguy83 (02-06-2013) |
#51 | |
Sent from my SCH-I535 using Tapatalk 2 |
| The Following User Says Thank You to Yruyur For This Useful Post: | Sportsguy83 (02-06-2013) |
#52 |
Grip>Slip
| The Following 2 Users Say Thank You to xjohnx For This Useful Post: | DriftEightSix (02-08-2013), Yruyur (02-05-2013) |
#53 |
I guess with no open source counterpart the pricing is higher... The pro WRX software is $150. If it is not clear the personal version lets you edit your own maps.
Who wants to be a guinea pig?
#54 |
#55 |
Drives: 2013 Asphalt FR-S
should have my copy of personal today ($499)..
For all the EcuTek guys that are worried about people getting hold of their roms..l don't be. BRZEdit does NOT include a read feature even on the pro version for this reason... Now when ECUFLash comes out with support for the toyobaru... all bets are off. Pro (1500) lets you tune an unlimited number of cars and includes 1 year support Personal (499) lets you tune 1 car lite (199) only lets you install maps and log, this is so tuners with pro can send out maps.
~Namaste~ |
#56 |
Drives: 2013 Raven 6MT FR-S
Here is a list of accessible maps i got from epifan.
Interestingly enough, there is no MAP Sensor scaling. Not good news for the boosted crowd. I'd still run MAF with my tune, but i'd like to be able to put a decent MAP sensor on the car to see boost. Accel Pedal - Torque Request Drive By Wire Accel Pedal - Torque Request (Sport Mode) Drive By Wire Advance Multiplier Increment Ignition Timing \ Learning AF Sensor Atm Pressure Comp Sensors \ AF Sensors AF Sensor Heater duty cycle A Sensors \ AF Sensors AF Sensor Heater duty cycle B Sensors \ AF Sensors AF Sensor Heater Power On delay Sensors \ AF Sensors AF Sensor Heater protection Sensors \ AF Sensors AFR Max Correction Fueling \ AF Correction AFR Min Correction Fueling \ AF Correction AFR Sensor Heater Limit Sensors \ AF Sensors Air Intake Temp Sensor Scaling Sensors Air Temp vs Air Flow Comp Engine Load Calc Engine Load A Engine Load Calc Engine Load B Engine Load Calculated Torque A Drive By Wire \ Calculated Torque Calculated Torque B Drive By Wire \ Calculated Torque Catalyst Warm-up (Idle) Catalyst Catalyst Warm-up (Moving) Catalyst Closed Loop AFR Adjustment A Fueling \ Closed Loop Closed Loop AFR Adjustment B Fueling \ Closed Loop Closed Loop Delay (Maximum Engine Load) Fueling \ Closed Loop Closed Loop Maximum Vehicle Speed Fueling \ Closed Loop Closed Loop Min Coolant Temp Fueling \ Closed Loop Closed Loop Throttle Delay Fueling \ Closed Loop Closed Loop to Open Delay Periods Fueling \ Closed Loop Coolant Temp Sensor Scaling Sensors Cranking Fuel Map Trim Fueling \ Cranking Cranking Injector Pulse Width Fueling \ Cranking Cranking Throttle Trim Fueling \ Cranking Delayed Closed Loop Engine Load Timer Fueling \ Closed Loop DI Quantity Maximum Allowed Injection Control DI Quantity Minimum Allowed Injection Control DTC Table Diagnostic Trouble Codes Engine Cranking Enrichment Fueling \ Cranking Engine Load Limit A Engine Load Engine Load Limit B Engine Load Engine Load Multiplier Engine Load Front O2 Sensor Scaling A Sensors Front O2 Sensor Scaling B Sensors Fuel Cut Resume Manifold Pressure Limiters Fuel Injection Ratio ECT Switch Threshold A Injection Control Fuel Injection Ratio ECT Switch Threshold B Injection Control Fuel Map Fueling Fuel Multiplier Display Offset Other \ Gauge GDI Firing Angle (Cold-Idle) Injection Control GDI Firing Angle (HL cold) Injection Control GDI Firing Angle (HL hot) Injection Control GDI Firing Angle (LL cold) Injection Control GDI Firing Angle (LL hot) Injection Control GDI Flow Rate Fueling \ Injector Scaling GDI Pressure Multiplier A Injection Control GDI Pressure Multiplier B Injection Control GDI Pressure Target A Fueling GDI Pressure Target B Fueling Gear Detection Thresholds A Other \ Gearing Gear Detection Thresholds B Other \ Gearing Idle Air Flow vs Coolant Temp Idle Control Idle Control A Idle Control Idle Control B Idle Control Idle Engine Load vs Coolant Temp Idle Control Idle Target A Idle Control \ Targets Idle Target B Idle Control \ Targets Idle Target C Idle Control \ Targets Idle Target D Idle Control \ Targets Idle Target E Idle Control \ Targets Idle Target F Idle Control \ Targets Idle Target G Idle Control \ Targets Idle Target H Idle Control \ Targets Idle Target I Idle Control \ Targets Ignition Advance Ignition Timing Ignition Base (Normal) Ignition Timing Ignition Base (Safe) Ignition Timing Ignition Compensation A Ignition Timing Ignition Compensation B Ignition Timing Ignition Compensation C Ignition Timing Ignition Compensation D Ignition Timing Ignition Compensation E Ignition Timing Ignition Retard (Clutch Down) Ignition Timing Ignition Timing Comp vs Air Intake Temp (Threshold) Ignition Timing Ignition Timing Compensation vs Air Intake Temp Ignition Timing Initial Advance Multiplier Ignition Timing \ Learning Injector Flow Scaling Fueling \ Injector Scaling Injector Minimum Open time Fueling \ Injector Scaling Injectory Battery Offset Fueling \ Injector Scaling Knock Detection RPM Range Ignition Timing \ Knock Control Knock Retard Decrement Ignition Timing \ Knock Control Knock Retard Igntion Correction RPM Range Ignition Timing \ Knock Control Knock Retard Increment Ignition Timing \ Knock Control Knock Retard Minimum Engine Load Ignition Timing \ Knock Control Knock Sensor Scaling Sensors MAF Sensor Scaling Sensors Mass Air Flow Limit A Limiters Minimum Open Loop AFR Fueling \ Closed Loop Minimum PI Quantity Injection Control Missfire Detection Diagnostic Trouble Codes Open Loop Delay Threshold (Load) Fueling \ Closed Loop Open Loop Delay Threshold (Throttle) Fueling \ Closed Loop Open Loop Fuel Throttle Enrichment A Fueling \ Enrichment Open Loop Fuel Throttle Enrichment B Fueling \ Enrichment Open Loop Gear Threshold A Fueling \ Closed Loop Open Loop Gear Threshold B Fueling \ Closed Loop Open Loop Stationary RPM Threshold Fueling \ Closed Loop Open Loop Throttle Threshold (Manual) Fueling \ Closed Loop Open Loop Throttle Threshold A Fueling \ Closed Loop Open Loop Throttle Threshold B Fueling \ Closed Loop PI Manifold Relative Pressure Comp Injection Control Radiator Fan Control - Vehicle Speed Fan Control Radiator Fan Coolant Temp Threshold A Fan Control Radiator Fan Coolant Temp Threshold B Fan Control Rev Limit A Limiters Rev Limit B Limiters Solenoid Control Other \ Solenoid Solenoid Duty Other \ Solenoid Throttle Angle - Torque Request Drive By Wire Throttle Delta Fuel Comp (Delta) A Fueling \ Enrichment Throttle Delta Fuel Comp (Delta) B Fueling \ Enrichment Throttle Delta Fuel Comp Threshold A Fueling \ Enrichment Throttle Delta Fuel Comp Threshold B Fueling \ Enrichment Throttle Delta Fuel Comp vs Coolant Fueling \ Enrichment Total Injection Ratio GDI port (Cold) Injection Control Total Injection Ratio GDI port (Hot) Injection Control Total Injection Ratio GDI port (Warm) Injection Control Unkn Temp Scalling (Fuel?) Sensors VVT Exhaust Angle (Base) Variable Valve Timing VVT Exhaust Angle (Normal) Variable Valve Timing VVT Exhaust Angle (Safe) Variable Valve Timing VVT Exhaust Duty Correction A Variable Valve Timing \ OCV VVT Exhaust Duty Correction B Variable Valve Timing \ OCV VVT Exhaust Duty Correction C Variable Valve Timing \ OCV VVT Exhaust Duty Correction D Variable Valve Timing \ OCV VVT Intake Angle (Base) Variable Valve Timing VVT Intake Angle (Normal) Variable Valve Timing VVT Intake Angle (Safe) Variable Valve Timing VVT Intake Duty Correction A Variable Valve Timing \ OCV VVT Intake Duty Correction B Variable Valve Timing \ OCV VVT Intake Duty Correction C Variable Valve Timing \ OCV VVT Intake Duty Correction D Variable Valve Timing \ OCV Warm-up Fuel Enrichment (Idle) Fueling \ Enrichment Warm-up Fuel Enrichment (Moving) Fueling \ Enrichment Wide Open Throttle Torque Limits Drive By Wire \ Calculated Torque |
| The Following 2 Users Say Thank You to Z0rr0 For This Useful Post: | Deepseadiver (02-10-2013), Shankenstein (02-06-2013) |
