| DIY (Do-It-Yourself) Guides For all DIYs. |
#43 |
The most important thing to do when you change pads or rotors is to press the brake a few times in the driveway before you drive off.
If the pedal doesn't feel firm, you have messed something up. Even if you haven't messed something up you will need one or two presses for the pistons to get to the right spot. Just my two cents, bleeding the brake lines is terribly simple compared to the rest of the brake change. If you aren't in a hurry you can just gravity bleed them. |
#44 |
Drives: 2014 Subaru BRZ Limited MTblue
pads and rotors for the track
Nice write up! I decided to swap pads AND rotors for track. I keep my street pads and rotors just for that. To keep things in order, I marked all pads and rotors with marking paint to put parts in the same place each time. When swapping back after track days, I measure my pads and rotors before stowing.
(Centric OE replacement rotors, Carbotech XP8 front and rear.) |
#45 |
Drives: 2013 GBS BRZ Limited
Thanks for the write up! Simplest brake pad swap I've done on any car
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
#46 |
Drives: 2016 Subaru BRZ
One thing not mentioned but I have seen cause problems in the past on other cars (and might here on Toybarus, so this is both a statement and question about BRZ / FT86) when replacing pads on a street car is that as the pads wear the piston stays protruded somewhat and does not retract all the way into the caliper. And the sides of the piston pick up dirt and may even rust or pit where exposed or even under the rubber seal boot.
The problem happens when you push the piston all the way back into the caliper without CLEANING it and the 'trash' stuck to the exposed part of the piston and possible pits on the piston end up going through the seal, sometimes damaging it and causing leaks a while later. This will not happen on a car being tracked and having frequent brake work but can happen on a DD where it might have been a couple of years since the pistons were 100% cycled in and out. Maybe the piston seal will scrape the crud off before it rides thru and maybe it will not... sure a lot easier to check n clean and prevent the problem. Something to check when you do a brake job so that you don't end up rebuilding your calipers. Voice of experience as I worked my way through college working at a gas station and 'fixing' other mechanics screw ups on brakes, etc. Nastiest brake job EVER... replacing the rotors on the Jaguar XJ-S coupes inboard rear brake setup. Rotors are not on the wheels but are either side of the differential to reduce unsprung weight! Book was WAY wrong on chargeable time.
Edelbrock SC kit w/ ECUtek tune, Oil Cooler, UEL catted header, Perrin 2.5 Overpipe n Catted midpipe, 3.0 Catback resonated (all exhst ceramic coated), TRD short shifter, MTEC clutch n trans springs, Trans: Pentosin MTF2, Diff: Motul 75W90, Whiteline trans bushing, 3/4" clutch slave cyl., Ferodo DS2500 pads w/Motul 600 fluid, 17x8 wheels n 235/45ZR-17 tires
#47 |
E-brake / parking break
Are there drum brakes on any 86's?
#48 |
pessimistic skeptic
#49 |
Drives: 2013 BRZ, 6MT, WR Blue
Hey, all. Thanks to OP for the write up. I'm changing my rear pads. Left was completely smooth, removed lower bolt, loosened up bolt, and caliper rotated right off. I cannot remove the right, even with both bolts removed. The piston is pressing down and won't release. I tried a fair amount of force and bleeding fluid, but it's on there. Once I got off the highway driving home from the track yesterday (i.e., when the exhaust wasn't as loud), I could hear the brake on that side "dragging" a bit. By that point I was 3 miles from home so I finished the drive, but between that and this, it's like the piston's just not properly releasing. Any ideas?
#50 | |
Noob
Drives: FR-S Mammogram
#51 |
Yup probably overheated and seized.
#52 |
#53 |
Yeah I gotta get in and take a look at my back brakes, it sure feels like one is dragging. A little bit warmer weather and it will be time to dig in.
#54 | |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
Instagram: Gabe.it.the.ole.college.try |
| Tags |
| brake pads, pad change |
| Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! | Mike@CZP | Brakes, Suspension, Chassis | 348 | 06-01-2018 12:29 PM |
| which brake pads? | NESW20 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 165 | 02-25-2018 02:07 AM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| brake pads | Dpark27 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 09-07-2012 07:58 PM |
