Old 04-20-2013, 06:48 PM   #43
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Added to my build thread's first post:
Grimmspeed Oil Cap & Battery Tie Down installed. Alcantara w/ red stitch radio and airbag surround from Redline Goods. I'll do JPM Coachworks next time as I had to install it myself and I couldn't get it perfectly lined up or looking quite like it should.
stockysnail is offline   Reply With Quote
Old 04-20-2013, 06:51 PM   #44
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
What's your input on the yellow shocks?
TRD_07 is offline   Reply With Quote
Old 04-21-2013, 09:50 PM   #45
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
i have my redline goods dash piece on it's way in. how did you go about the stereo surround? They told me it involves some cutting... where/how did you cut it to fit right? everything clip together ok once it was all wrapped or did you have to force it down with the added thickness?
abutterman is offline   Reply With Quote
Old 04-21-2013, 10:17 PM   #46
Lonewolf
Lonewolf's Avatar
Drives: Moped
I'm really curious to see what you will put down on that same dyno with a header and a tune...Quite the build so far....
Old 04-21-2013, 10:59 PM   #47
stockysnail
Just the tip
I had to force it a little. I cut the 4 corners back so it would wrap to the back side. I trimmed if there was too much excess that was folding over the back but kept enough so that it still folded so it would go on better. I was a little worried about cutting but just do a little at a time and it should turn out ok. The hardest part is getting the stitches to line up on the individual piece, then to the 2nd piece. I couldn't get mine to line up perfectly. Smells a little too so don't install it in the car for a couple days, otherwise the car will smell like spray on glue.
Old 04-21-2013, 11:00 PM   #48
stockysnail
Just the tip
Me too. As soon as I find a new job and they release a header I'll dyno it again, with and without a tune. I'm leaning towards getting a tune on the dyno with BRZedit locally.
Old 04-21-2013, 11:35 PM   #49
abutterman
abutterman's Avatar
Ok cool thats what i figured. I already i stalled their shift boot and ebrake boot and went with leather all around. I used a tube of industrial adhesive on the ebrake that luckily had no oders and i just let it dry a few ours and it was good to go
Old 04-29-2013, 12:45 AM   #50
stockysnail
Just the tip
New in my car's (Lil Red) build thread:
Added OEM splash guards (mud flaps) to the car and also painted my wheels logo red.
Clutch pedal travel mod.
Rear Koni Yellow shocks and rear RCE Yellow springs installed (still waiting on front Koni's).
Old 04-29-2013, 11:10 PM   #51
stockysnail
Just the tip
Perrin crank pulley, yes I got red believe it or not , added to build thread with impressions. Since Everyone else seems to be getting the Perrin crank pulley I figured I'd join the crowd today.
Old 05-06-2013, 09:38 PM   #52
stockysnail
Just the tip
Fn'A 4th brake light kit/rear fog light (kit 2) installed and added to first post.
Old 05-09-2013, 03:53 AM   #53
NickFRS
Drives: 2013 Asphalt FRS
I'll make sure to text you the dyno results of the header josh!
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-26-2013, 11:39 AM   #54
stockysnail
Just the tip
JDL UEL headers ordered!
Old 05-29-2013, 01:33 AM   #55
stockysnail
Just the tip
Ordered the following to be installed when they arrive:
-Greddy red short lug nuts
-BRZedit dyno tune at PRE (when headers arrive and are installed)
-Prova Wide-View Rear View Mirror Yellow
-Prova Yellow Wide-View Door Mirrors
-Lamin-X Headlight Covers Yellow
Old 05-29-2013, 01:35 AM   #56
stockysnail
Just the tip
Perrin engine mounts were ordered too. I almost forgot. I'll put them in when I put the headers in as it's an easier install that way.
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
No Limit's DGM BRZ limited build thread No Limit Motorsport Member's Car Journals 10 05-10-2013 12:09 PM
Jdmitr BRZ Limited journal/build thread jdmitr Member's Car Journals 18 10-01-2012 12:50 AM
SD: Lightning Red BRZ Limited 6MT tastefully modded epson1 Cars for Sale/Trade 2 09-24-2012 12:56 PM
