Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
01-01-2013, 12:44 AM | #43 |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
10k on my car.. Not a problem, and I broke it in how I regularly drive.. I've never cared about what a manufacture wrote in some book.. I've been a ASE auto tech for 15 years working on engines since I was 13.. I'm 35 now.. I've broken in every engine the way I've drove the vehicle.. Had 150k on my xterra with not a problem.. But everyone has their own believes
01-01-2013, 07:06 PM | #44 | |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
01-01-2013, 07:22 PM | #45 | |
This motor takes time to loosen up , like 5000 to really see top end power, it improves over time |
01-01-2013, 07:56 PM | #46 | |
Drives: 2005 S2000
This whole topic is widely debated, but many reputable engine builders "break in" engines by running them hard with lots of high RPM engine braking to seat the rings. I wouldn't be worried about the engine, but as mentioned, you should be taking it easy on the clutch/tranny/diff until the initial break in period is over. And for whatever it's worth, most clutch/tranny manufacturers recommend 500 miles of easy driving. |
01-01-2013, 08:14 PM | #47 | |
AIM4APX
Drives: 2013 WRB BRZ Limited
I haven't seen any real evidence on either side to convince me aside from anecdotal evidence. Because of that I default to mfg suggestion. /shrug.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
01-02-2013, 04:59 AM | #48 |
Drives: Toyota 86, Pearl White, Manual
Got my car with 26km on the clock and actually asked whether there was a breakin period. They assured me there wasnt. Didnt go crazy but have taken it to between 6k and 6.5k on a couple of occasions. Then discovered this forum and read the manual so now taking it a bit easier until I get to the recommended mileage... So I will have done both... and who knows what the staff did to the car when they went to go put in my 1/4 tank of fuel...
01-04-2013, 02:33 PM | #49 |
Drives: 13' DGM Built FBM BRZ
I am just going to stick with the 1k period.. My first new car, I am 23 paying it alone so I wont take any risks and finding someone to fix it will be $$ so better safe than sorry.
01-04-2013, 03:12 PM | #50 | |
Drives: Scion FR-S
Sent from my HTC One X using Tapatalk 2 |
01-04-2013, 11:37 PM | #51 |
Drives: GT3
Break the car in as you want to drive it. Don't worry about it, I have built many many engines including race ones. The best ones are driven properly from day one!
01-07-2013, 09:14 AM | #52 |
Drives: 2013 Firestorm FR-S
So I've read all the break in threads and I still haven't seen a logical arguement for keeping the engine under 4,000rpm for the first 1,000 miles (i.e. a soft break in).
Now I realize that the manual recommends a soft break in (and I understand why people would choose to follow this), but I haven't seen an engineering/technical justification (I've seen plenty of arguements for a more robust break in procedure). I've even searched the web in general for technical arguements for a soft break in but found nothing. Making sure the engine is warmed up and no holding a constant speed for the first 500-1000 makes good sense, but not exceeding 4,000rpm is still a mystery to me. I'm not suggesting the sportbike approach, but driving between 0 and 6,000rpm for the first 500-1,000mi just seems like a good way to make sure everything is properly broken in and heat cycled. Last edited by brillo; 01-07-2013 at 04:52 PM. |
01-07-2013, 10:11 AM | #53 |
The main thing to watch early on is bedding in the clutch nicely on a MT, dont do burnouts and such right away
01-07-2013, 04:52 PM | #54 |
I don't do burnouts period.
I plan to break the car in by driving as I would normally and avoiding cruise control without racing or thrashing the engine til after 500mi. I'm always relatively gentle on cars for the first 500mi to lets materials heat cycle, clutches break in, etc.....but I'm not going to stress over keeping the car under 4,000 rpm. My Perrin flash goes on right after I pass the 500mi point. |
01-07-2013, 04:55 PM | #55 |
Team ScioNRG President
Drives: 2017 WRB BRZ
FWIW i just changed the oil at 4800miles
Usually on a brand new engine I find small pieces of metal from the motor breaking in. However, there was next to nothing in the drain pan. Needless to say I was very impressed. I have no problems changing the oil at 7500miles in the future.
2017 Subaru WRB Limited BRZ w/ PP |
01-07-2013, 05:17 PM | #56 |
Drives: t
I kept mine @ low revs, and got a CEL in 300 miles.. it never went away.. Even with swapped cam sprockets, ecu replacements, etc.. I will not be doing this on my replacement car..
Similar Threads | ||||
ECU reset after Break-In | paros28 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 02-19-2013 05:41 PM |
Break in | ipothas | Issues | Warranty | Recalls / TSB | 11 | 10-21-2012 04:41 PM |
End of break-in! Now where do we go play? MTL | QC-FRS | CANADA | 3 | 06-29-2012 10:05 PM |
How did you break in your engine? | WolfsFang | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-05-2012 01:12 AM |
Break-in question | Baldeagle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 03-31-2012 02:28 PM |
