Old 12-22-2012, 08:30 PM   #43
Dtronic
Dtronic's Avatar
Drives: 2013 Whiteout FRS
Happened to me once last week. A little over 1000 miles.
I have an auto and it was in the afternoon going home from work. It was around 70F temp wise.
Cranked about 5 seconds and no start. A wtf moment and sat there for 10 seconds or so and tried it again and started after 3 seconds cranking.
Usally starts as soon as I turn the key. Hasn't happened again.
Dtronic is offline   Reply With Quote
Old 12-22-2012, 08:37 PM   #44
_F-R-S_
Drives: 13 whiteout scion frs
Yes mine to!!
_F-R-S_ is offline   Reply With Quote
Old 12-31-2012, 04:49 PM   #45
brz7400
brz7400's Avatar
Drives: Subaru BRZ
2 times in 2 weeks now, push button start cranks the engine on it's own for about 6 secs or more before it fired up. both times have been cold, but is ~50 degrees really that cold? both times trying to start about 1 hour after last shut off. never had CEL, so maybe just need to get that reflash/recall thing that came in the mail?...
brz7400 is offline   Reply With Quote
Old 01-07-2013, 11:21 AM   #46
WRXGuy1
WRXGuy1's Avatar
Drives: 2013 WRB BRZ Premium 6MT
Mine has done this maybe 2-3 times as well, it's totally random. I'll just go to start it and it will crank but never start, the second time it starts fine.
2013 BRZ Premium WRB MT - Picked up 5/31/12
WRXGuy1 is offline   Reply With Quote
Old 01-09-2013, 10:42 AM   #47
dj petey
dj petey's Avatar
Happens to me too. Maybe about 3 times so far. The car has 2500 miles on it. It seems too prevalent among members for it to be driver error. Has anyone reported this to their dealer yet?
dj petey is offline   Reply With Quote
Old 01-10-2013, 12:03 AM   #48
Hotdawwgman
Used Car King
Hotdawwgman's Avatar
Drives: 13 White M/T BRZ
Well this kinda happened to me twice in the past 2 days... Go to start the car, clutch is to the floor, hit the start button and nothing. Key light flashes. Today I tried for 10 minutes and nothing until I took the key fob and threw into the little cubby. On the 3 attempt with the fob in the cubby it finally started.... It's kinda embarrassing... Any body have that happen?
Hotdawwgman is offline   Reply With Quote
Old 01-10-2013, 12:53 AM   #49
B L U E S L A T E
Drives: BMW E84
So based on all the comments above, this is fairly a common issue?
Is there perhaps a TSB or recall issued for this matter?
B L U E S L A T E is offline   Reply With Quote
Old 01-10-2013, 02:42 PM   #50
YW-Slayer
Drives: 2013 BRZ (MT, WRB), 2005 Legacy B4
Just had it happen to me. Didn't drive the car for only 6 days and it's only 15 deg Celsius! Would just click once or twice and stop.
It happened a few months back but I blamed it on leaving my Blackvue with the extra battery plugged in (which it was this time too). That was worse, as I hadn't driven it for 7 days and the alarm wouldn't even unlock the car. I think unplugging the Blackvue when parked for more than 2 days may be the way to go from now on.
YW-Slayer is offline   Reply With Quote
Old 01-10-2013, 02:57 PM   #51
Blackforge
Drives: 2013 Subaru BRZ Limited - CBS
Mine is driven every day. Today has been the warmest day we've had in a few weeks at least (60s in Fahrenheit). Push start took about 5 seconds to start. I had one other hesitation on start a few months ago, but not quite like this. Hit 6900 miles on the way to work this morning.
Blackforge is offline   Reply With Quote
Old 01-10-2013, 07:07 PM   #52
KGFRS86
SoCal Asphalt FR-S Owner
KGFRS86's Avatar
Drives: 13' Asphalt FR-S
I haven't had to turn the key twice but lately (it's been cold-ish) sometimes after work (8 hours since driven) when I turn the key I can hear the starter (or something) click twice and then the engine spurs to life from a low rumble to high rumble.
That might be a bad description, but yes it's happening to me too...Automatic Transmission
KGFRS86 is offline   Reply With Quote
Old 01-10-2013, 11:05 PM   #53
YW-Slayer
Tried to start it again this morning, no dice. Going to do the cables later.
I should clarify that I have an MT BRZ with push-button start. The lights go on, and I can even switch the headlights on, but the starter refuses to go past the first "click", unless I push the button 2-3 times, in which case it clicks the same number of times. Nothing happens (although lights are on) if I try and start it again. I then have to abort the process using the button.
I suspect what may have happened is that the Blackvue and its aux-battery has drained the battery due to the following:
1. I usually ask my friend (as it's parked much nearer to her) to start the car every few days. She started it every other day this week.
2. The Blackvue starts up and runs in parking mode once the car is started. This continues for some time after the engine has been stopped, using the Blackvue's aux battery. Then the Blackvue's aux battery draws power from the car.
3. I assume that the car, once started, only idled for 2-5 minutes. The charge passed to the car's battery during this time was not enough to compensate for the drain on the battery caused by the Blackvue aux battery, which was in turn caused by the Blackvue running in parking mode for several hours.
Hence the moral of the story appears to be that I should unplug the Blackvue when I park it in this lot. This shouldn't be a major problem given that it's indoor, covered, very safe, and next to an (old) Rolls-Royce.
Old 01-10-2013, 11:12 PM   #54
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
This has kinda happend to me. I have manual. I try to start engine and it goes the starting sound..... but doesn't start until an extra few seconds of holding the keey..
It sorta sounds like what it sounds like when the battery is Dying or DEAD.
I wonder if it is.
Chinadian is offline   Reply With Quote
Old 01-10-2013, 11:14 PM   #55
Chinadian
Chinadian's Avatar
PS: my car has had like all the defects that this car could have
1) Day 1 - CEL, garage for 1 month
2) Just noticed condensation in fog lights
3) THis weird start engine issue
4) My windsheild wipers need to be replaced
Old 01-11-2013, 12:31 AM   #56
chate
Pharmasaurus Magnificus
chate's Avatar
FRS/Manual takes a while to start when cold sometimes
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85
2015 Nissan GTR
chate is offline   Reply With Quote
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 01:32 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 03:28 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
