Old 11-05-2012, 05:23 PM   #43
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Originally Posted by Flat Black VW View Post
glad to see it worked for you! Looking forward to getting mine on there.
Any rubbing issues while driving?
None, first thing I did on the test fit was do some circles with the steering turned to full lock each way.
Originally Posted by dsgerbc View Post
Yeah, a close-up of clearance between the wheel and brake caliper and between the inner lip and a steering joint would be awesome.
I can do that sometime this week perhaps. It's not close enough to be alarming tho. Not close at all.
Originally Posted by Ingen View Post
So if 15x6 fits, we can maybe run Konig Heliums?
11 lb wheels for autocross here I come!
On second thought, maybe I'll let someone else do it first and see how it goes
If the offset is ok, +38 works for a 15x6
You'll have an awfully large sidewall then. Not to mention a smaller contact patch, not sure if I'd want that for auto-x.
seven is offline   Reply With Quote
Old 11-25-2012, 07:01 PM   #44
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Finally ordered some winter tires for these wheels and the lug adapters. Should have them on here in a week or so!
Flat Black VW is offline   Reply With Quote
Old 12-05-2012, 07:44 AM   #45
Silp3
Silp3's Avatar
Any updates? I have the opportunity to pick up 4 VW steel wheels with brand new 205/60/16 Winterforce tires for short money. I really don't want to pass it up.
I really don't want to run incorrect lugs. Couldn't I just use VW lugs as an alternative? I guess I am not understanding properly, but would like to figure this out asap.
Thanks guys
Silp3 is offline   Reply With Quote
Old 01-27-2013, 03:21 AM   #46
seven
Tells it like it is
seven's Avatar
Thanks guys
I posted saying I did this and bought the adaptors linked elsewhere in this thread, worked fine.
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT
2015 Mazda 3i-T/Tech
Old 03-16-2013, 02:19 PM   #47
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
Sweet I've been looking for a set of 15" wheels so I can get some gravel rally tires and run rallycross. Does anyone know if all rims of this size will work. I've seen 15" Volks (stupid expensive) and I've heard others that will not fit
RazBRZ is offline   Reply With Quote
Old 07-02-2013, 03:31 AM   #48
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
I was curious if the forged 5 TT 18s would fit. Probably 5x120 if I had to guess, but they're a really eccentric wheel, so kinda want to see them on the car
zohare is offline   Reply With Quote
Old 07-20-2013, 07:29 PM   #49
Ash_frs
Drives: 2013 FR-S firestorm (MT)
I have a set of these at home! what size tire are you running on these to match the stock 17'' wheel radius?
Ash_frs is offline   Reply With Quote
Old 07-21-2013, 06:08 PM   #50
PeterB
PeterB's Avatar
Drives: Subaru BRZ Limited WRB
I don’t see any confirmation that 15” rims work for BRZ/FRS. Many people reported problems and 15" VW AVUS Wheels discussed here do not seem to be confirmed as good. My guess is that these are not safe (assuming they can even be put on). Let me know if you know more about it.
PeterB is offline   Reply With Quote
Old 07-21-2013, 10:26 PM   #51
Turbo Den
Drives: FRS, IS300, 911sc
Read page 2 of this thread.
And you will see the pic too.
Turbo Den is offline   Reply With Quote
The Following User Says Thank You to Turbo Den For This Useful Post:
PeterB (07-23-2013)
Old 07-21-2013, 11:26 PM   #52
Flat Black VW
I ran them as my winter wheels for about 5 months. No clearance issues or need for spacers. Only thing needed were washers to go from conical to ball seat lugs.
The Following User Says Thank You to Flat Black VW For This Useful Post:
PeterB (07-23-2013)
Old 09-18-2013, 03:55 PM   #53
markmatley
Shipping to Hawaii?...
markmatley's Avatar
Drives: '13 Asphalt FR-S
Originally Posted by seven View Post
Pic of mine installed, they were plasti-dipped black with silver metalizer. Sadly its to overcast to see it very well. They look like a dark charcoal metallic. Camera phone quality too :-/
Not to dredge up old topic, but whats the size on those tires? 225/45?
~Matt
Efimia (asphalt FRS)
markmatley is offline   Reply With Quote
Old 09-18-2013, 03:58 PM   #54
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
da hell would you put 225 on a 6" rim
those are 205x60/65 by the look of it
Old 09-18-2013, 04:14 PM   #55
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Sorry I just cant understand this thread. I thought the twins' OEM rims r ugly enough until I saw these. BTW those tires make it looks like a rally car.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-19-2013, 06:48 PM   #56
markmatley
markmatley's Avatar
Thanks for the helpful comment. Wish the op of that post would chime in.
~Matt
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 04:07 PM
Got some new wheels for my DGM BRZ / "DATBRZ" DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-11-2012 01:06 PM
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS BestWheelDeals Wheels and Tires 2 09-07-2012 10:26 PM
"What kind of wheels are these?" MEGATHREAD switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-04-2012 12:03 AM
How harsh is the ride on 18" vs 17" wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-18-2012 04:08 PM
