Old 09-13-2011, 05:17 PM   #43
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
I4 FF cars are nightmare to oil change! That's why I love boxer engine. Even the older model it was on the bottom, so I don't have to twist my arm or make much mess.
I remember the older Toyotas were like that as well, on the bottom.
Old 09-13-2011, 05:30 PM   #44
Random_Art
professional smartass
Random_Art's Avatar
Drives: 16 speed mountain bike...
I like changing the oil on my mountaineer. I just drive it up so the front wheels are on top of the curb and that gives me plenty of room to work under it.
Goodbye Celica, you served me well.
http://artsofrandomness.blogspot.com/
Random_Art is offline   Reply With Quote
Old 09-13-2011, 05:45 PM   #45
Nemesis
H. Badger Cares About Him
Nemesis's Avatar
Drives: BMW 335i coupe w/ man.6 spd
Originally Posted by Cinthetyk View Post
Perhaps I'm old-fashioned, but I rather like the oil filter being next to the drain plug on my RS. Having said that, I don't mean that the new design is bad; it's just different than what I am used to. If there is any benefit other than accessibility, someone please let me know.
The cool part about it being on top is that for someone working from home can easily get to the filter without making a mess. When it's on top gravity causes it to drain back into the engine rather then on your hand as you screw it off. Also it's easier to remove(cap wrench needed) with no over tightening issues requiring a screwdriver and a hammer...lol
Nemesis is offline   Reply With Quote
Old 09-13-2011, 05:48 PM   #46
Nemesis
Nemesis's Avatar
Also a lot af the cap wrenches come with a nut welded into them that matches the socket for the oil plug....
Old 09-13-2011, 06:32 PM   #47
djohnson
Drives: 1996 RAV4
Some newer Toyotas still have the filter on the bottom. '03 RAV4 I have kept the filter on the underside. Oil spills aren't much of a problem... plastic bags work wonders. And no need for a wrench.
djohnson is offline   Reply With Quote
Old 09-13-2011, 06:34 PM   #48
Type[R]+
Type[R]+'s Avatar
Drives: Lexus IS-F
I still love how nice and low that motor sits!
Type[R]+ is offline   Reply With Quote
Old 09-13-2011, 09:14 PM   #49
Allch Chcar
Drives: N/A
There is a tag on the photos BTW. lol didn't see.
Originally Posted by MatadorRacing_F1 View Post
Achieving that would make me very happy. Providing of course it's under 2750lbs.
230PS would do it at that weight but I am hoping they hit a lower curb weight
I can't help but imagine the amount of work it would take to move it lower and farther back . The block excluding the intake sits below the tires, amazing.
That rear suspension looks pretty low and that diff looks small. It might be the perspective but I have to wonder what mm width it is.
That 2010 engine they are displaying must be for the AWD Subaru's since the intake faces back instead of to the front like the Coupe. Right?
Oh and and carbed boxer .
Edit:
And it appears that our photographer wears shiny shoes and a suit.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 09-13-2011, 11:25 PM   #50
Sabastian
will rain on your parade.
Drives: 2007 Mini Cooper, 1996 Mazda MX-5
I'm still left wondering how close this car really comes to showing the internals of the actual production BRZ. Anyone notice that the concept still has rear-mounted front brake calipers while the mule has forward-mounted ones? Hmm.....
Sabastian is offline   Reply With Quote
Old 09-14-2011, 12:05 AM   #51
serialk11r
Drives: '06 AM V8V Coupe
As far as the engine goes, it appears to have no variable valve lift/duration control whatsoever, as there isn't any extra height to accomodate rockers, so I certainly hope this isn't it...
Old 09-14-2011, 12:47 AM   #52
Buggy51
Drives: Put Put
Mm... I hate to appear bothersome, but what does that mean if they have no variable valve lift/duration control? How does this compare to one that does? Thanks!
Buggy51 is offline   Reply With Quote
Old 09-14-2011, 12:51 AM   #53
serialk11r
So variable valve lift just means the cam lobe profile is essentially switchable, not just phasing where they change when it opens and when it closes but still using the same cam lobe, just changing its rotational position relative to the crankshaft. The most advanced variable lift systems control lift and duration together, allowing a huge decrease in pumping loss and thus a huge increase in fuel economy. On the performance side, what they allow is greater power because the lift and duration can be rpm optimized.
I am fairly sure any variable lift system uses some sort of intermediate rocker to create that effect, and this usually adds some height (Valvematic ZR engine for example, is 34mm taller over the regular dual VVTi ZR without lift control IIRC) over the intake valves. But this engine looks to be the same size as the previous one, so the only extra space you get to stick something like this in there is however much they trimmed off the stroke length, which is probably not very much.
Old 09-14-2011, 12:51 AM   #54
[es vi: eks]
Drives: Subaru Legacy
I like chrome and polished alloy but that is too much shiney lol.
My GF likes shiney things tho
Nice to see those new pics.
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
[es vi: eks] is offline   Reply With Quote
Old 09-14-2011, 03:37 AM   #55
Fly Guy
Fly Guy's Avatar
Drives: '91 MR2
That's very interesting. Which will it be?
Tada-san: Oh so cooler than the concept.
Fly Guy is offline   Reply With Quote
Old 09-14-2011, 05:11 AM   #56
Harinjo
Harinjo's Avatar
compared to other subaru models (which?) the engine from brz is mounted 120mm lower and 240mm closer to centre of suspension
-> http://www.atzonline.de/Aktuell/Nach...t-den-BRZ.html
Harinjo is offline   Reply With Quote
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
New Toyota FT-86 concept pics (non-press photos and closeups). You'll love these. Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 136 04-20-2014 07:00 PM
First Look of FT-86 II Concept @ Frankfurt ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 72 09-13-2011 11:26 AM
Subaru BRZ Dimensions and More Teasers Released Ahead of Frankfurt BRZman BRZ First-Gen (2012+) — General Topics 48 09-03-2011 11:32 PM
Frankfurt Motorshow 2011 predictions ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 16 07-10-2011 12:23 PM
