| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
2 wheel member
Drives: JZA80, 997.1, Taco
I remember the older Toyotas were like that as well, on the bottom.
#44 |
professional smartass
Drives: 16 speed mountain bike...
I like changing the oil on my mountaineer. I just drive it up so the front wheels are on top of the curb and that gives me plenty of room to work under it.
#45 | |
H. Badger Cares About Him
Drives: BMW 335i coupe w/ man.6 spd
#46 |
Also a lot af the cap wrenches come with a nut welded into them that matches the socket for the oil plug....
#47 |
Drives: 1996 RAV4
Some newer Toyotas still have the filter on the bottom. '03 RAV4 I have kept the filter on the underside. Oil spills aren't much of a problem... plastic bags work wonders. And no need for a wrench.
#48 |
Drives: Lexus IS-F
I still love how nice and low that motor sits!
#49 | |
Drives: N/A
There is a tag on the photos BTW. lol didn't see.
![]() I can't help but imagine the amount of work it would take to move it lower and farther back . The block excluding the intake sits below the tires, amazing.That rear suspension looks pretty low and that diff looks small. It might be the perspective but I have to wonder what mm width it is. That 2010 engine they are displaying must be for the AWD Subaru's since the intake faces back instead of to the front like the Coupe. Right? Oh and and carbed boxer .Edit: And it appears that our photographer wears shiny shoes and a suit.
#50 |
will rain on your parade.
Drives: 2007 Mini Cooper, 1996 Mazda MX-5
I'm still left wondering how close this car really comes to showing the internals of the actual production BRZ. Anyone notice that the concept still has rear-mounted front brake calipers while the mule has forward-mounted ones? Hmm.....
#51 |
Drives: '06 AM V8V Coupe
As far as the engine goes, it appears to have no variable valve lift/duration control whatsoever, as there isn't any extra height to accomodate rockers, so I certainly hope this isn't it...
#52 |
Drives: Put Put
Mm... I hate to appear bothersome, but what does that mean if they have no variable valve lift/duration control? How does this compare to one that does? Thanks!
#53 |
So variable valve lift just means the cam lobe profile is essentially switchable, not just phasing where they change when it opens and when it closes but still using the same cam lobe, just changing its rotational position relative to the crankshaft. The most advanced variable lift systems control lift and duration together, allowing a huge decrease in pumping loss and thus a huge increase in fuel economy. On the performance side, what they allow is greater power because the lift and duration can be rpm optimized.
I am fairly sure any variable lift system uses some sort of intermediate rocker to create that effect, and this usually adds some height (Valvematic ZR engine for example, is 34mm taller over the regular dual VVTi ZR without lift control IIRC) over the intake valves. But this engine looks to be the same size as the previous one, so the only extra space you get to stick something like this in there is however much they trimmed off the stroke length, which is probably not very much. |
#54 |
Drives: Subaru Legacy
I like chrome and polished alloy but that is too much shiney lol.
My GF likes shiney things tho Nice to see those new pics.
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
#55 |
Drives: '91 MR2
That's very interesting. Which will it be?
Tada-san: Oh so cooler than the concept.
#56 |
compared to other subaru models (which?) the engine from brz is mounted 120mm lower and 240mm closer to centre of suspension
![]() -> http://www.atzonline.de/Aktuell/Nach...t-den-BRZ.html |
| Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 856 | 06-14-2018 02:53 PM |
| New Toyota FT-86 concept pics (non-press photos and closeups). You'll love these. | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 136 | 04-20-2014 07:00 PM |
| First Look of FT-86 II Concept @ Frankfurt | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 72 | 09-13-2011 11:26 AM |
| Subaru BRZ Dimensions and More Teasers Released Ahead of Frankfurt | BRZman | BRZ First-Gen (2012+) — General Topics | 48 | 09-03-2011 11:32 PM |
| Frankfurt Motorshow 2011 predictions | ft86cbx | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 07-10-2011 12:23 PM |
