Old 04-26-2013, 01:08 AM   #43
sid325
Drives: Ultramarine FR-S 6MT
I'm curious if the 9" would offer an improvement?
**Just ordered both, for $16ish delivered what the heck...
sid325 is offline   Reply With Quote
Old 04-26-2013, 03:16 AM   #44
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Probably would. I don't notice the long antenna. Against all the red, it doesn't draw the eye at all.
Old 06-26-2013, 02:09 AM   #45
tedddee
Drives: 03 imprz rs, 13 brz
[ame="http://www.amazon.com/Kuryakyn-Function-Flexible-Antenna-Mount/dp/B0022ZWNKG/ref=zg_bs_172533_39"]Amazon.com: Kuryakyn Dual Function Flexible Antenna Tour Pak Mount 865: Automotive[/ame]
Wonder if these would be the same thread? Looks like it's a bit better quality.
tedddee is offline   Reply With Quote
Old 06-26-2013, 03:17 AM   #46
HooverFish
HooverFish's Avatar
Drives: 2013 FR-S Ultramarine Automatic
That one from the ebay store is pretty much exactly like the one I had on my '05 tC and it was OEM...
HooverFish is offline   Reply With Quote
Old 06-30-2013, 08:59 PM   #47
#288
Drives: Argento Scion FR-S
Until a better solution (subjective) is found I'm sticking with the antenna from my daughters Mazda2. Just Whip it.
#288 is offline   Reply With Quote
Old 09-07-2014, 07:03 PM   #48
Zinger
Drives: 2014 Scion FR-S
Originally Posted by WRM View Post
While the total length of the antenna is 18", you will notice that the wire is wrapped around the mast. How long would it be if it wasn't wrapped, I don't know. I do know that it picks up FM better than the stock antenna, at least in Los Angeles.
If you type "18 inch fuba antenna" in ebay the first seller should be "raderra". It was only $10.99 with free shipping. The antenna fits just like OEM.
Just double checking. Is this the one you are talking about - http://www.ebay.com/itm/370553878635? It doesn't list as being compatible, but is the only 18" FUBA Antenna I could find. Thanks!
Zinger is offline   Reply With Quote
Old 09-13-2014, 02:10 PM   #49
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
I just got a fuba for Subaru off eBay and it works awesome. I have mounted it under the rear deck as I am shaving the stock antenna hole. It still gets hd channels and works awesome. (PW JDM cf rear deck not stock)
Jman1759 is offline   Reply With Quote
Old 10-20-2014, 07:07 AM   #50
navanodd
Drives: 2013 BRZ Sport-tech WRB
Installed the eBay 18" antenna yesterday. Seemed to pick up stronger signal in my underground parking but the true test will be next time I make a road trip back home from Halifax to Sydney.
Once I confirm that it's working properly my plan is to go back to the stock antenna and put the big one in for roadtrips. I've been fine with the FM signal when in the city, just not when travelling.
On a side note, does anyone know why all cars have external antennas or sharkfins now? My Accord back in 2001 had the antenna built into the rear window and it worked amazing. Seems like some backwards progress to me.
navanodd is offline   Reply With Quote
Old 10-30-2014, 11:27 AM   #51
mid_life_crisis
Drives: FR-S 10 #103 AT
The "wire" wrapped around the antenna has nothing to do with reception.
From http://www.theautochannel.com/mania/industry/Transcripts/2000/118.htm
[Why'd They Do That? - Car Antennas]
John McElroy, American Driver
"And, finally tonight, in a segment we like to call “Why’d they do that, I’m going to attempt to explain why all car antennas are not alike. While many antennas are smooth, have you ever noticed how some others look like they have a wire wrapped around them, or have a spiral groove in them? You know what that’s for? It’s to cut down on wind noise and vibration. That spiral shape actually helps the antenna slice through the wind more easily, so it’s quieter. When an antenna is mounted on the front fender, as the wind comes off it, that noise is actually directed right at the driver. These spiral-type antennas direct the noise off to the side of the car. And you know how automotive engineers test these antennas to see how quiet they are? They go outside and swish them around like swords!"
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Chimera (10-30-2014)
Old 06-14-2015, 01:37 PM   #52
ArgentoAtl
ArgentoAtl's Avatar
Drives: Argento manual
FUBA antenna
I have not found a conclusive way to experiment to see if the 18" FUBA antenna could be better than the OEM antenna (largely because my residence is pretty close to the stations I listen to), but yesterday I did the following. I found a very weak FM station by scanning. Then I removed the OEM antenna and the reception disappeared. Then as I was replacing the antenna, and it was still 2 inches away from the car roof, I noticed the reception got pretty good again before I even reattached the antenna. So that suggests to me that the antenna is very important and I decided to order from eBay today. I hope the improvement is real for when I am between cities on the highway.
Brian in Atlanta
ArgentoAtl is offline   Reply With Quote
Old 06-14-2015, 03:30 PM   #53
White64Goat
Just saw one of those Extreme Engineering shows and they were showing the largest suspension bridge in the world and how they wrapped one of those twisted cables on the outside of the suspension cables to stop the wind buffeting and vibration to the suspension cables. How about that....
Old 06-19-2015, 10:39 PM   #54
ArgentoAtl
ArgentoAtl's Avatar
Wink
Brian in Atlanta
I received the FUBA antenna today and was really disappointed because the reception is not even as good as the OEM antenna. I would recommend people keep the OEM.
Old 09-29-2015, 09:21 PM   #55
White64Goat
Installed a 2015 OEM shark fin antenna and it seems a bit better than all the antennas I've experimented with, but still has HD drop out from a station that is only about 30-35 miles away and has a good broadcast antenna.
20$ Shark Fin Antenna srt4_night_rider Cosmetic Modification (Interior/Exterior/Lighting) 13 05-08-2013 02:13 AM
Shark Fin Antenna geb2391 BRZ First-Gen (2012+) — General Topics 15 09-09-2012 10:05 PM
LT Short Antenna now available for the 86/FR-S/BRZ/GT-86 lordtakuban Exterior Parts - The Rest 1 07-25-2012 08:22 AM
Got my Beats Antenna before my car ;( haloterence Cosmetic Modification (Interior/Exterior/Lighting) 3 06-13-2012 09:55 PM
Does anyone else not like where they put the antenna? MrFRsLa Cosmetic Modification (Interior/Exterior/Lighting) 41 06-04-2012 08:27 AM
