Old 09-04-2012, 10:27 PM   #43
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Originally Posted by Turbowned View Post
I'm running a Cusco in my MR2. No idea how well it's working, but it looks purdy! You could always powdercoat the can if it's too blingy for your tastes. I feel like this part doesn't have to be too fancy to work, I.E. the Crawford one looks like overkill on an otherwise stock car.
It isn't just the bling factor. That set up seems to be nothing more than an empty can with some fittings. I am going FI so function is my priority.
Apex Chase is offline   Reply With Quote
Old 09-04-2012, 10:34 PM   #44
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I like the design of the Saikou Michi because it's internally baffled. Plus the input is on the top of the can and the vent is at the top too. The only way you'll get blow by is if the can fill up to the top. Here's how they are designed. http://www.saikoumichi.com/OCC_explanation.htm
JimmyMac is offline   Reply With Quote
Old 09-04-2012, 11:22 PM   #45
gmookher
I think the Moroso is identical, and pretty cheap, so i ordered one today, will keep you all posted, comes in Thursday
gmookher is offline   Reply With Quote
Old 09-05-2012, 02:10 AM   #46
Visconti
Drives: 05 STi
Originally Posted by JoeBoxer View Post
Has anybody running one actually had any accumulation in the can?
Crawfords Performance today told me that after a long track session they checked they're can/lines and saw oil
John
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
JoeBoxer (09-05-2012)
Old 09-05-2012, 02:26 AM   #47
Mo707
Mo707's Avatar
I like the location of the Cusco; it's pretty out-of-the-way:
Was this easy to instal?
Mo707 is offline   Reply With Quote
Old 09-05-2012, 03:26 AM   #48
Nardi330
Nardi330's Avatar
Drives: 86
to mount the oil catch can, it took me 10 minutes. took longer to run the hoses, 45 mins max if u have all the clamps (depends on if you want to vent it out or connect it back to intake).
Nardi330 is offline   Reply With Quote
Old 09-05-2012, 03:37 AM   #49
JimmyMac
JimmyMac's Avatar
One other note to add, if you are running turbo and catch a lot of gunk, make sure you run hose rated for oil use. If you don't, it will deteriorate very quickly. It may even collapse on you as well. I would consider the hoses a maintenance item in some cases.
Old 09-05-2012, 06:06 PM   #50
gmookher
I would double can a turbo, but thats me
Old 09-05-2012, 06:34 PM   #51
dabocx
dabocx's Avatar
Drives: Scion FRS
Well now i feel bad about not having one of these and going the track >_>
dabocx is offline   Reply With Quote
Old 09-05-2012, 06:56 PM   #52
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
that cusco unit above and crawford's are full of win.
VSGTS14 is offline   Reply With Quote
Old 09-05-2012, 07:16 PM   #53
Mo707
Mo707's Avatar
Is there a DIY for the installation?
Old 09-06-2012, 01:27 PM   #54
gmookher
I added a moroso, reused some piping from the removed sound generator that I removed earlier:
will report back after this weekend's auto-x event if I am able to catch any oil!
The Following User Says Thank You to gmookher For This Useful Post:
ATL BRZ (09-12-2012)
Old 09-06-2012, 02:17 PM   #55
Turbowned
Turbowned's Avatar
Ooh, that Moroso is a nice piece!
Old 09-06-2012, 09:45 PM   #56
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
I'm test fitting one of our STI baffled catch cans, just to check places to fit it, and if we want to stick with that design. Not a finished piece, in other words.
AVOturboworld is offline   Reply With Quote
The Following User Says Thank You to AVOturboworld For This Useful Post:
Apex Chase (09-06-2012)
blow by, carbon build up, catch can, crawford catch can, radium catch can, saikou michi
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 04:07 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 11:58 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 01:30 PM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 04:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 04:55 PM
