Old 06-18-2014, 04:20 PM   #43
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
when i was on v3. never rubbed. not even on track.
theres still room to go lower for all you slammed folks but not a lot.
camber -2.3 front -1.6 rear. .08 (per corner) toe in rear. car was excellent.
the V3's are for sale so if anyone is looking for a mint set look up my threads/pm me asi have other suspension on the car now.
Jive Turkey is offline   Reply With Quote
Old 06-28-2014, 07:43 PM   #44
smellslikecurry
jive were you running rear adjustable control arms and adjustable front sway bar endlinks?
smellslikecurry is offline   Reply With Quote
Old 06-30-2014, 09:49 AM   #45
Jive Turkey
the tuna, no crust.
just rear lca/toe arms
Old 07-29-2014, 06:45 PM   #46
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
Originally Posted by DarrenDriven View Post
Lifted from another topic...
Installation note: When installing these KWs we measured the amount of exposed threads below the lower spring collar to determine where to set the coilovers for future installations.
Front: 3/8" remaining thread = 1 9/16" drop
...12 7/8" distance from fender to center of hub (14 7/16" stock height)
Rear: 2 1/8" remaining thread = 2 1/4" drop
...12 3/8" distance from fender to center of hub (14 5/8" stock height)
Can you install these coilovers at stock ride height. After installing my car sits at around 14.6 inches from the center of the wheel to the fender. Is there any negative effect, if so how much lower should i go from 14.6 inch
vignesh is offline   Reply With Quote
Old 07-29-2014, 06:50 PM   #47
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Originally Posted by Nardi330 View Post
i must get some V3 now. thanks for your info.
Get the Tarmac 2 coilovers they are essentially kw clubsports for a lot less money and a stiffer spring rate.
Rocket.BRZ is offline   Reply With Quote
Old 07-29-2014, 07:27 PM   #48
Malt
Drives: 2015 WRX
That's not exactly accurate. The T2's are bastically V3's with custom valving and stiffer spring rates. The clubsports are a completely different beast.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Tristor (02-28-2018)
Old 08-23-2014, 11:59 PM   #49
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
installed the kw v3's today installation was simple. just a heads up for the less mechanically experienced people out there- make sure you have a spring compressor and a thru-hole ratchet or some way to hold the shock while unbolting the top shock bolt. there are many DIY's and tutorial videos out there but NONE of them explain this process.
anyway rides great on stock kw settings & so far i would recommend these to anyone in the market for a set of good quality coilovers
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 08-24-2014, 05:02 PM   #50
Racecomp Engineering
Our T2s for this chassis are based on KW clubsports, not V3s.
- Andy
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
AreteAuto (11-30-2015), Tristor (02-28-2018)
Old 06-10-2015, 03:12 AM   #51
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
Hi,
Sorry but I have a random question, the rear coilovers do they have a specific side to be installed. I read that was the case with some Tein coilover and I bought my KW V3 second hand.
Thanks!
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
MaXimus is offline   Reply With Quote
Old 06-10-2015, 03:37 PM   #52
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Originally Posted by MaXimus View Post
Hi,
Thanks!
Nope. They are marked the same
2superblus is offline   Reply With Quote
Old 07-06-2015, 06:59 AM   #53
MaXimus
Meh!
MaXimus's Avatar
Thanks!
Old 07-09-2015, 11:42 PM   #54
Zzzquil
Zzzquil's Avatar
Is anyone here maxed out on the lowering height and having problems with the front endlinks rubbing on the control arms? I'm looking at Whitelines front adj. generic endlinks (it has a 190m-215m of play in height) but heard they're very noisy. I have also been looking at hotchkis but I think they might be too long. Can anyone help? I have tried trimming them as much as possible but I still rub when making turns.
Zzzquil is offline   Reply With Quote
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 05:32 PM
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 06:26 PM
Suspension Review: Eibach Sportline Lowering Springs DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 07-23-2019 09:59 PM
Suspension Review: Hotchkis Sport Springs Nitro22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-23-2016 06:01 PM
Suspension / Coilovers ~ How to Choose the Right Setup for YOU Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-24-2015 01:53 PM
