Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > GR86 General Topics (2nd Gen 2022+ Toyota 86)
GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86
Old 09-07-2023, 05:02 PM   #43
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Originally Posted by ruturaj001 View Post
Might be best to evaluate using pressure sensor. Then consider pressure at different temperature and RPM with and without an oil cooler, and if it actually reaches 300F.
(I have a pressure sensor, no pressure problems)
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is offline   Reply With Quote
Old 09-07-2023, 06:09 PM   #44
ruturaj001
Drives: BRZ 2023
Originally Posted by Ansix Auto View Post
With the stock configuration, we would hit 130*C by the second lap but it would stabilize there. You can't use a thicker viscosity to compensate for the higher pressure losses of the JR dual oil cooler. The best compromise would be to choose an air to oil cooler with less pressure drop. That's something we're developing.
Out of curiosity, What was the pressure at 130C without oil cooler?
ruturaj001 is offline   Reply With Quote
Old 09-07-2023, 06:37 PM   #45
ruturaj001
Drives: BRZ 2023
Originally Posted by terboboost View Post
Heavily track the car (drifting), but also summer street car, using M1 0W-40. HKS is thermostat, so gets up to temp quickly, and I usually peak around 240*F (measured at sandwich plate) although I have seen higher. Pre-turbo I was getting up to 250F, so I just did cooler at the same time as turbo.
That's where I'm sorta coming from. Its not hard to ensure an oil cooler isn't leaking or having vulnerable lines. So with that said...seems oil temps of 220-240 are highly preferred (although not necessary) compared to 280-300F.
With FI it would be crazy, I wouldn't like 280-300 either but how many would hit it on NA?
What pressure do you see at 240? Also is this 1st gen or 2nd gen?
Old 09-07-2023, 06:51 PM   #46
terboboost
terboboost's Avatar
I have an alarm set for >30psi over 3000 rpm, and it doesn't trip the alarm. But that's all I can really say as I havn't logged it.
and sorry, this is on a 1st gen. My bad.
The Following User Says Thank You to terboboost For This Useful Post:
ruturaj001 (09-07-2023)
Old 09-07-2023, 06:51 PM   #47
Ansix Auto
FT86Club Official Vendor
Drives: 2023 BRZ
Sorry, we didn't have a pressure sensor when it was the stock configuration so we can't tell you the pressure at 130*C.
Check out our GR86 and BRZ products!
https://ansixauto.com/subaru/
Ansix Auto is offline   Reply With Quote
The Following User Says Thank You to Ansix Auto For This Useful Post:
Old 09-14-2023, 03:11 AM   #48
wizzo
Drives: 2014 Toyota 86
How are you able to delete the the factory heat exchanger with your JR oil cooler sandwich plate?
wizzo is offline   Reply With Quote
Old 09-14-2023, 06:23 PM   #49
Ansix Auto
Drives: 2023 BRZ
You need the center fitting Subaru 15018AA090. The fitting that came with the JR cooler needed modifying too since it was too long. We just sanded it down a little bit because it would tighten before squishing the sandwich plates tight.
We had to shave down the oil fill cap otherwise the hose would touch the airbox. Even with shaving the cap, it's very close to touching.
DocWalt (09-15-2023)
Old 09-14-2023, 09:35 PM   #50
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Being close to the cap is a problem on Gen 1 as well.
2022+ BRZ/GR86 Intake Snorkel - Ansix Auto Ansix Auto Engine, Exhaust, Bolt-Ons 6 08-06-2023 10:08 PM
2022+ BRZ/GR86 CANbus Adapter - Ansix Auto Ansix Auto Audio/Visual, Electronics, Infotainment, NAV 11 07-04-2023 05:01 PM
GR86/BRZ FA24 Oil Pressure Loss Demonstration Stevedave GR86 General Topics (2nd Gen 2022+ Toyota 86) 2 06-28-2023 10:07 AM
2022+ BRZ/GR86 Oil Pan RTV Solution - Ansix Auto Ansix Auto Engine, Exhaust, Bolt-Ons 1 11-28-2022 06:02 PM
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto Ansix Auto Engine, Exhaust, Bolt-Ons 0 11-18-2022 06:15 PM
