| Engine Swaps Discussion of engine swaps. |
#43 | |
Drives: 2017 BRZ 3.0L swap
Quick update.... pretty cold here still in canada so not much work done but I am planning for spring summer2024.. Bought a low mileage EZ30 this engine will replace the cheap high mileage one I got in there now the goal was to get the concept come to live 2023 which I got it started and idling I will rebuild the old one with time and use it to mockup the supercharger mount .Next is mod the exhaust header to add clearance its too low right now.. should not take much time. -Build a radiator shroud to direct air in the rad ....the temps from testing get very hot so will have to make sure temps are in check dont want more then 100 degree celcius -I found a good tuner that will be remote road tune it so I can finally drive it this spring then finish on dyno. -bluetooth adapter with digital dash Should be able to complete these this year for 2025..-After tuned properly and all bugs removed will start the design of the Roots type Supercharger with water meth injection utilising my previous experience with superchargers
EvolBRZ--
2017 subaru BRZ Swapped EZ30 2017 subaru Outback (EZ36) my stock daily |
| The Following User Says Thank You to Evolbrz For This Useful Post: | Nick Dugdale (08-08-2024) |
#44 |
Drives: 2015 Subaru BRZ
Thanks for the update! What size / brand radiator are you running for the EZ30? I see a few out there with two outlets on top but are ~$650. Worth it? Radiator from KOBE
I have also considered the forced induction route with a Rotrex super charger unit. Considering fabbing up my own mounting brackets to accommodate the super charger. For now its a factory JDM EZ30R on E85. The sub frame can be notched to fit the custom EZ headers over top. There is a video on youtube with a guy notching the subframe for the over pipe section.
"The vision manifests the reality." NASA TT5 Silver 2015 Subaru BRZ Limited
| The Following User Says Thank You to Nick Dugdale For This Useful Post: | Evolbrz (02-21-2024) |
#45 | |
EvolBRZ--
| The Following User Says Thank You to Evolbrz For This Useful Post: | Nick Dugdale (03-14-2024) |
#46 |
Excellent! Keep us posted on your progress. Very interested to see the car out at Canadian Tire raceway if you can make it out.
You still have plans to run a SC on the motor? Cheers!
| 08+ STI Brembo swap use 2017 BRZ Rotors? | SockMonkey | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 19 | 08-22-2024 05:57 PM |
| 2017 new BRZ spoiler swap? | Zhangy | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 10-18-2021 04:33 PM |
| Greetings Earthlings - 2017 86 Bumper Swap! | SquadRon | Scion FR-S / Toyota 86 GT86 General Forum | 70 | 10-26-2018 05:04 AM |
| 2017 diff swap | JOE APO | Engine, Exhaust, Transmission | 97 | 11-18-2017 09:32 PM |
| 2017 BRZ spoiler swap? | rmar93 | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-15-2017 10:23 PM |
