#43 |
| The Following 9 Users Say Thank You to CSG Mike For This Useful Post: | Ash_89 (11-05-2021), Brz-123 (11-04-2021), DarkSunrise (11-04-2021), Espi (11-04-2021), glamcem (11-04-2021), Jdmjunkie (11-04-2021), jflogerzi (11-04-2021), Lantanafrs2 (11-04-2021), weederr33 (11-04-2021) |
#44 |
Drives: 2022 BRZ Limited
It looks great
Have you tried running those pads with Ti Shims.. with my '19 SS 1LE I could see a dramatic drop in temps (~40 F IIRC) .. I was worried that if would affect the rotor life (being a heavy car) but it didn't . Most likely because it eliminates the fade and so the pad drag in braking zones. Anyhow, congrats again!
#45 |
Get those TIPS ready guys
![]() CSG Mikes Wallets Tips Appreciated! BTC: 3Ho17Er6avcWr6LNmy6LqFqidwx6pi7RJi ETH: 0x6e225F34A948fA0EAB50E8137a01c4539e6e4204 @CSG Mike
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | CSG Mike (11-04-2021) |
#46 | |
The next weakest point is the rotor, but all this just verifies what we know from the 13-20 cars! This is how my rotors used to look regularly, before I put on a BBK. https://www.instagram.com/p/Bki4Vc_Ay5Q/ |
| The Following User Says Thank You to CSG Mike For This Useful Post: | glamcem (11-05-2021) |
#47 | |
#48 | |
As you may be already aware Motul RBF 600 lowered their dry/wet boiling temp ratings so I switched to Castrol SRF a couple years ago that and shim combined solved most of my fade issues. See below for before (2017 Camaro SS 1LE - same pads and Motul RBF 600 without ti shims) and after (2019 Camaro SS 1LE Castrol SRF and Ti shims) ..of course it's a much heavier, faster car with very sticky tires but same conditions and track. After that I didn't have to see purple calipers after a first event anymore ![]() Are 1st gen and 2nd gen brake system is interchangeable? I am planning to get BBK, coilovers, anti roll bars for now and am not planning to touch the engine so it would be amazing if many of the things are the same so I wouldn't have to wait for them to become available
#49 |
Drives: GR86 2022
Mike, would you have a rough idea if the factory or csg brembos clear the 18in oem wheels?
#50 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Teseo (11-07-2021), villainous_frx (11-05-2021) |
#51 |
@glamcem the reason I use multiple temp stickers, is that the trailing end of the caliper will be significantly hotter than the leading edge; that side has more exposure.
Based on your temp sticker location, your temps may be higher than you realize. 50C spread isn't uncommon across the caliper, especially if you're using the SC3R in wider sizes. |
#52 | |
Using multiple temp stickers make sense, I will try that next time. How about the brake/brake lines compared to Gen 1, are those interchangeable? TIA
#53 |
After an extensive measuring session, we've determined that the rear is dimensionally identical, when it comes to track width, RLCA, etc.
What's different is the rear quarter configuration. The width of the quarter is the same, but due to the new shape and mounts, wheel fitment will be affected. |
#54 |
Drives: Subaru BRZ
How about RUCA?
#55 | |
Drives: 18 Brz (Sold) / 22 BRZ
| The Following User Says Thank You to Stonehorsw For This Useful Post: | timurrrr (11-08-2021) |
#56 |
| Tags |
| nowforitbs |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | BRZ Second-Gen (2022+) — General Topics | 25 | 11-05-2021 12:22 AM |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 5 | 11-02-2021 06:57 PM |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 10:11 AM |
| Mike @ LSD Motorsports | JDMenrique | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 04-06-2013 08:13 PM |
| Mike at Czp | _F-R-S_ | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 12-01-2012 10:01 PM |
