| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
Sort of a combination of a few depending on age.
| The Following User Says Thank You to Tcoat For This Useful Post: | villainous_frx (11-04-2021) |
#44 |
Drives: Red 2019 Subaru BRZ
If you want to baby shift, its up to you. I shift that way because it brings the RPM to just the right place, for a seamless and smooth shift.
Forget 50 Willys, my 87 Sammy needs to be shifted that way too.
#45 | |
Drives: 2017 BRZ PP, 2004 WRX
Just quoting you so you might actually read this, OP. The stock gearbox fluid isn't the best. Don't get me wrong - it works and it's what the car came with, but there is better stuff out there. Amsoil, Motul, etc. Even on a 2020 like your profile says, might be worth changing. With that said, gearboxes don't warm up by sitting. So you're SOL for getting it warm before pulling out. It's not even really shifting that does it, but driving. When you're moving, things are going on in there, heating it up. Low tech solution, but my neighbors used to put a hot work light on under their oil pan before starting their car on super cold days in the winter. Not saying it's going to make a huge difference, but will probably help. You can actually set it all up the night before and plug it from your garage or through a window the morning of. Kinda like a low-tech engine block heater. I do feel your pain though. 1-2 is not the best even for me and I store the car inside and only use it in the spring-fall. Rarely sees even 35-40 degrees F. Downshifting when moving to 1st always doesn't feel the best, so that's just a quirk of the car. I try to only upshift to 2nd if I'm going to actually stay in 2nd or up if at all possible. If I'm seeing up ahead I'm going to be slowing down again soon, I'll just hit 3k in 1st and hold it, moving slow, but not doing necessary up and downshifts.
#46 |
Drives: '15 BRZ RA
I have a '15 and I had a '21 model too. Both required a bit of effort when shifting 1-2 in cold, but after ~10 minutes that transmission oil temperature was normal the shifting feel was much better.
#47 |
not playing cards
I find it interesting how some bristle at any suggestion of mechanical sympathy. A machine is a machine is a machine. It's possible to operate the derailleur of a bicycle while pedaling with full force but, with the chain scraping and popping across the sprockets, it sure feels awful.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (11-07-2021) |
#48 | |
Drives: 2020 BRZ Final Edition, 1999 MX5 NB
My father works at Audi and every time he enters my BRZ he says "jesus I can't balieve this thing had cost this much money". And while I don't really agree with that, sometimes you do really wonder what the hell were they thinking... I mean it's not like you absolutely need it but then again what you paid vs what you got is... questionable. Lets put it that way. It's really hard to see *this* value in *this* car. If it wasn't my poster car for years I would maybe even care. But since it was I'm just coping with fact that my dream has some twists I did not predict and now I have to learn how to live with that
#49 | |
Drives: '15 BRZ RA
#50 |
Drives: 17 Asphalt 86
When temps are down around 0c or colder letting the car warm up a couple minutes before setting off helps with the first few shifts.
Typically I'll toss the lunchbox in the trunk, start it and go back inside to finish up making my coffee. |
| Cold Air Intake on Edelbrock Supercharger for extra whine | TokyoDrift | Forced Induction | 9 | 07-09-2023 05:14 PM |
| 2018 cold shifting | konahic | BRZ First-Gen (2012+) — General Topics | 29 | 02-28-2020 06:09 PM |
| Transmission shifting when cold? | jpilone | Engine, Exhaust, Transmission | 112 | 02-22-2018 04:48 AM |
| Down shifting into 2nd gear when cold | Flame9020 | Issues | Warranty | Recalls / TSB | 27 | 12-22-2016 05:24 PM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 03:22 PM |
