Old 09-01-2021, 01:05 AM   #43
FrickingReallySlow
Drives: 2015 FR-S
I'm very curious about the diff bushing thing so I'll remove that and see if the vibration goes away
Nice let us know the results!
FrickingReallySlow is offline   Reply With Quote
Old 09-01-2021, 11:21 AM   #44
billstock67
Drives: 2017 Toyota 86
Originally Posted by VerusEric View Post
That is correct, we will no longer be producing them.
I believe your issue to be specific to your vehicle. I have personally not heard of a balance issue to date from our units, let alone two units back to back. Like others in this thread stated, it can be a variety of things.
Thanks,
Eric
Would you suspect trans / differential - mount / bushing inserts to be a possible factor?
billstock67 is offline   Reply With Quote
Old 09-01-2021, 05:33 PM   #45
gpvecchi
gpvecchi's Avatar
Stiffer bushing can only amplify a vibration issue. If there's no vibration with stock shaft, the culprit is the new driveshaft. With soft bushing the vibration is less noticeable, but it's there.
gpvecchi is offline   Reply With Quote
Old 09-01-2021, 05:35 PM   #46
StraightOuttaCanadaEh
Wes
Yes but the bushings make a huge difference, especially if there is more than one type at the same time. I spent a couple hours researching this today across multiple platforms and pretty much all say that once you remove diff and/or subframe bushing *inserts*, the vibration either goes away or is drastically lessened.
I'm going to try removing the diff inserts (KDT925) next week and will report back. Hopefully it helps
Instagram: @gt86ws
Old 09-01-2021, 06:31 PM   #47
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Stock diff bushings did not help me. I am running solid subframe mounts though so that isn’t helping.
Old 09-01-2021, 07:50 PM   #48
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
I honestly have no idea; I just know how many units we have sold and how few complaints we have seen from vibration. To have two units have seriously bad vibrations at only 80 MPH, I think it's more vehicle-related than component-related.
VerusEric is offline   Reply With Quote
Old 09-01-2021, 08:36 PM   #49
Wes
Yeah apparently they raise the subframe and change the angle, which results in vibration, according to all these forums I read through anyway. Are you also having vibration at 80 mph?
Instagram: @gt86ws
Old 09-01-2021, 08:51 PM   #50
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am running stock height settings with the solid mounts.
Mine is at about 105mph with mild resonance on decel around 65.
Old 09-01-2021, 11:13 PM   #51
brzlegend
Drives: brz
Originally Posted by dragoontwo View Post
@VerusEric Can you give any information on why you transitioned to CV joint on the driveshaft?
Angles no longer have to line up with cv's
U joint driveshafts rotate in an elliptical with different velocity in a single rotation and the yokes have to be in phase.
CV= constant velocity
brzlegend is offline   Reply With Quote
Old 09-02-2021, 08:48 AM   #52
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I understand the differences between the yoke types. I was asking if he could give any info as to why the company made the switch. He answered likely with as much info as he could put out for the company.
dragoontwo is offline   Reply With Quote
Old 09-09-2021, 03:30 PM   #53
Wes
Took out the Whiteline diff bushings (KDT925) and briefly took the car up to 140 km/h (86 mph) and the vibration was vastly reduced. Gotta try it again for a bit longer, as this was only for a few seconds. Will update tonight
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
FrickingReallySlow (09-09-2021), NoHaveMSG (09-09-2021)
Old 09-09-2021, 06:18 PM   #54
FrickingReallySlow
Drives: 2015 FR-S
Take the 407etr at night. I don't feel anything even at 105mph (all OEM mounts/bushing) but most likely will at a higher critical speed. 2 piece stock driveshaft will be good to the speed limiter
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
StraightOuttaCanadaEh (09-09-2021)
Old 09-09-2021, 06:24 PM   #55
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Glad to hear it helped for you. I still have too much other shit bolted to my car I think is not helping.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 09-09-2021, 07:12 PM   #56
Wes
Keep in mind I also have:
-whiteline subframe inserts
-perrin trans mount insert
-whiteline shifter bushing
-perrin engine mounts
Instagram: @gt86ws
SOLD Please Remove. (Dallas, TX) Driveshaft Shop Carbon Fiber 6MT Driveshaft Brzzee Transmission and Driveline 1 09-14-2018 10:22 AM
Driveshaft Shop Carbon Fiber Driveshaft (MT) $650 [SOLD] acj47 Transmission and Driveline 2 10-25-2017 06:07 PM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 03:27 PM
