Old 08-25-2012, 02:48 PM   #43
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
Originally Posted by sparks View Post
So it looks to be get this - http://www.ebay.com/itm/US-Store-Wid...item416708d70c
Then talk to SVXdc about an rca to two pins for the 16 pin plug.
Did you end up getting this camera? If so hows the quality?
Furtive is offline   Reply With Quote
Old 08-25-2012, 03:25 PM   #44
Foobar
SLO NO MO
Foobar's Avatar
I have the same camera that I got off Amazon for 12 bucks. I hooked it up to my monitor (not the headunit) and the quality looks good. Only problem is it has distance guide lines, so it's gonna overlap with the headunit since that apparently has them too.
Old 08-26-2012, 02:07 AM   #45
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
do you still have the link to it? I tried looking theres all sorts of options on amazon.
Old 08-27-2012, 09:06 AM   #46
Foobar
SLO NO MO
Foobar's Avatar
Search for license plate camera on Amazon. Everything under $20 is basically the same product being sold by different brands.
Old 08-29-2012, 09:29 AM   #47
sparks
sparks's Avatar
Still waiting on it to arrive. I'll post after the install.
2013 BRZ Preimum #452 - Sterling Silver
sparks is offline   Reply With Quote
Old 08-29-2012, 03:45 PM   #48
sparks
sparks's Avatar
This will be one of the easiest DIY's I've done in years. Add 2 pins, run a video cable, power the camera, mount the camera.
I'll try to remember to "keep is simple stupid" when the write up comes
Old 08-29-2012, 05:02 PM   #49
Foobar
SLO NO MO
Foobar's Avatar
Quick question for you guys that already messed with the wiring - what kind of terminals did Subaru use on the 16 pin harness? Are they Molex Mini50's?
Old 08-29-2012, 05:36 PM   #50
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
I think that would be a question best directed towards SVXdc... The pins I used were not a perfect match for the radio but were close enough that I could make them work.
Flat Black VW is offline   Reply With Quote
Old 08-29-2012, 06:02 PM   #51
Foobar
SLO NO MO
Foobar's Avatar
Gotcha - I sent him an e-mail. Thanks!
By the way, by not a perfect match, do you mean they were too big, too small, did you have to hack it or the harness to make it fit?
Old 08-29-2012, 07:47 PM   #52
Flat Black VW
they were the right size just a little bit different shape then they should have been. I basically just had to push harder than I should have needed to to get them in.
Old 08-29-2012, 07:53 PM   #53
xjohnx
Grip>Slip
xjohnx's Avatar
That tell you enough foobar? Sounds like if you can identify the pin type we should be able to find a source pretty easily, no?
Old 08-29-2012, 08:53 PM   #54
Foobar
SLO NO MO
Foobar's Avatar
There are a few different sizes for Molex Mini-Fit Plus series connectors. Should be able to get the exact connector from mouser.com though.
One of these I assume: http://www.mouser.com/pdfdocs/Molex_...SDatasheet.pdf I'll have to pull the harness out to get a better look I guess. Something for the weekend unless svxdc gets back to me.
Old 08-29-2012, 09:09 PM   #55
xjohnx
Grip>Slip
xjohnx's Avatar
I dont' exactly know what i'm looking for, but i'm ready to buy a bunch of different pins from mouser and have them shipped overnight. If you could provide me with links or part #'s of your top 5 suspects I'll eat the shipping charges and tear it apart on friday to find out.
Old 08-29-2012, 09:24 PM   #56
xcelir8brz
Drives: 2013 BRZ Limited
I second that.
xcelir8brz is offline   Reply With Quote
What will you hang from your rear view mirror? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 148 11-15-2013 02:52 PM
Zoom Engineering Rear View Mirrors Kami Speed Interior Parts (Incl. Lighting) 13 07-17-2012 02:18 PM
Taking rear view mirror off ? JB1 Cosmetic Modification (Interior/Exterior/Lighting) 7 06-21-2012 09:53 AM
Rear view Mirror pic nixeighty6 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 05:10 PM
