Old 04-23-2021, 11:25 AM   #43
B T
I was on it on the way to work. It was early, but I always drive aggressive. I hit a big bump during a pull, so I don’t know if that was part of it, but then it went.
That sounds eerily similar to what happened to my original engine. Cruising along the interstate, felt a small buck and instantly lost the motor. All I could find was maybe I either had a spot of bad gas or the DI clogged and ran lean causing a single large misfire. Sorry to see your engine go buddy. Were you running E85 or normal at the time?
B T is offline   Reply With Quote
Old 04-23-2021, 11:32 AM   #44
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I’m going to call tomorrow.
Keep us informed. I am on the fence with building an FA, but still concerned of their issues, or going with a K swap.
Old 04-23-2021, 12:09 PM   #45
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
E85 exclusively.
Old 04-23-2021, 12:23 PM   #46
B T
Mine started while using E85 from Louisiana and finally detonated a week later on the same fuel. In between, I put some Lucas Upper Cylinder and Fuel Treatment in there and it stopped my issues. I know I was a dumbass for putting that fuel back in my car without the treatment again.
Old 04-23-2021, 01:18 PM   #47
kg17
Drives: 2015 BRZ Crystal White Pearl
So sorry to hear about what happened!
kg17 is offline   Reply With Quote
Old 04-23-2021, 01:51 PM   #48
Irace86.2.0
I just got off the phone with Will from KPower Industries, and he was very helpful. He answered all my questions on the swap, and he said they will hopefully be taking preorders within the next few months for a mid-summer release a month later, assuming no problems. He said there will be a large preorder list because there is a lot of interest, which I am not surprised.
I will most likely be going this route, depending on if they follow through on time. I have nursing school starting in August, but I have a motorcycle, bicycle, wife's Q5 and Uber/Lift to get me through things.
I will break down the engine today and see how bad the damage is.
Old 04-23-2021, 03:18 PM   #49
Lantanafrs2
Drives: 2013 frs red
How is any fa20 worth 43 grand?
Old 04-23-2021, 03:45 PM   #50
tomm.brz
Drives: brz 2017 hksv2
welcome to the club lol
drop the compression a bit and forge )
Old 04-23-2021, 03:46 PM   #51
tomm.brz
Old 04-23-2021, 04:04 PM   #52
Irace86.2.0
I know, right. It is a right of passage.
I'm leaning to do a K24 NA with E85 potentially, and then get through nursing school, and then pull the motor and build it up for boost. If I was considering a FA motor then it would be a FA24 swap, but used motors are not on the market, and I frankly prefer the K24, even though D4S is nice too.
Old 04-23-2021, 04:27 PM   #53
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
LS is always the answer.
Old 04-23-2021, 05:45 PM   #54
pope
has a funny hat
Drives: 2014 BRZ Limited
K20C1 with a custom intake manifold to add port injectors.
pope is offline   Reply With Quote
Old 04-23-2021, 05:53 PM   #55
Here you go @Irace86.2.0. I mean you don't need nursing school really do you?
Plus GM has a $250 rebate on them right now....
Old 04-23-2021, 06:24 PM   #56
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
It probably would have been fine on the 85mm pulley. 75mm pulley puts the car around 400+, so doubling the horsepower on stock internals. I really think the bump had a big thing to do with it. That amount of sudden jarring jerk at 12+ psi at the time was enough probably, but who knows?
At the moment, I suspect you do.
Edit: Actually, I'm being a jerk. Sorry the engine let go. It's funny (not your situation, but the twisted reality) you can extract a lot of horsepower from these things, but like having one's cake and also eating it, you can't use it. I know next to nothing about quantum mechanics but I vaguely remember some property of particles that observing them makes them unfindable. (somebody help me here). In our case the engine can make a whole lot of power, but if you explore that power, the engine vanishes.
I am now convinced that the stock engine is just fast enough for this old man.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Dustin's UltraMarine FR-S (Engine Blew - LS3 Time) DustinS Member's Car Journals 800 04-13-2024 09:23 AM
Engine Blew, any shop recommendations? tian105 Southern California 11 08-16-2020 11:35 PM
Engine blew on 4psi? Causes? soccerk18 Software Tuning 26 08-10-2019 11:18 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
