#43 |
Do you by chance of pics of the SuperPro FLCA bushings? I have been looking to a solution to replace the whitelines on my car.
#44 |
Short tube EL header like Tomei is least preferred. UEL gives better gains down low and a good tune (there's some remote tuners who will work with you with OFT) will match the upper end gains offered by an EL header. Long tube EL header from ACE or JDL will give you a few extra ponies but fewer and more expensive tuning options out there to maximize.
I pulled my Tomei EL header off, OEM header back on, and flashed back to stock yesterday for my upcoming smog inspection. Driving around town the butt dyno can't tell the difference even with <100 miles on the clock for the ECU to relearn all the fuel trims. I'm in zero rush to put it back on. |
#45 |
Drives: 2013 Raven FR-S
What are you guys liking for ride height? I'm finding 13.25" (hub center to fender) to be the sweet spot for me. But I also daily drive my FRS so I can't get crazy low.
#46 | |
I am hoping the swap to some lighter springs will be a help, and then I have to figure out some other brake pads to try. Last edited by ka-t_240; 01-12-2021 at 01:44 PM. |
#47 | |
Drives: Miata
#48 |
#49 |
#50 |
Drives: 2022 BRZ, Red
#51 |
#52 |
Drives: 2017 BRZ w/PP
wait correct me if im wrong but you can have a FF sensor but you just cant run ethanol right?
#53 |
From what I have always been told in the past, the presence of the sensor / kit is not legal regardless to what fuel is in the tank. Maybe there is some better formal clarifications on this.
#54 | |
"Only sensors equipped from the manufacturer may be used for engine management." edit: I agree that irl having the sensors and running pump gas wouldn't have my panties in a twist, but by the letter of the rulebook it is verboden per the above sentence and the rest of 14.10.F along with the old standby 'if it doesn't say you can, then you can't'. These cars make good gains on E85 due to the high compression ratio, a protest would easily be justifiable and upheld. |
#55 |
What @strat61caster said. No external sensors.
In addition, even if you had a tune for 93 but also had E85 on one of your maps. Even though you weren't running said map you'd still be in non-compliance.
Kyle H. - #89 STX
#56 |
well i guess some locals can protest me if they want. its not like im national competitive
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 01:40 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 11:27 AM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
