Old 06-13-2023, 10:53 AM   #43
Racecomp Engineering
Yeah there are certainly better and worse ABS and TCS and stability control systems. OR...adjustable TCS systems (i think the GR Cup cars, certain Lotus Elise/Exige models, lots of racecars, etc.)
Early Subaru ABS systems weren't very good...to the point were Subaru would swap out the control unit for you on the 2002-2003 WRX. It was terrible on bumpy pavement or snow. Bad enough that they'd replace it for free is pretty bad.
We're a long way from there but the point is not all of these systems are the same!
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
GrandSport (06-13-2023)
Old 06-13-2023, 11:18 AM   #44
RACECAR go brrr!
Custom Switch Panels!
RACECAR go brrr!'s Avatar
Drives: 2015 Subaru BRZ Series.Blue
Originally Posted by Arthur-A View Post
So, has anyone tracked the car with ABS fuse removed and can confirm that it affects the brake bias?
I used the TracBox to disable ABS in the car for autocross, and only made it halfway around the course before turning it back on. Crazy aggressive front bias that made it WAY too easy to lock a front tire, especially if I was trying to add ANY amount of steering input under braking.
Order your own custom Toyobaru switch panel at www.racecargobrrr.com!
RACECAR go brrr! is offline   Reply With Quote
The Following 2 Users Say Thank You to RACECAR go brrr! For This Useful Post:
Arthur-A (06-13-2023), ZDan (06-13-2023)
Old 06-13-2023, 01:27 PM   #45
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Thanks everyone for your input! I've got another question, that notorious "ice mode", does it occur even when thw pedal dance is performed?
Arthur-A is offline   Reply With Quote
Old 06-13-2023, 02:04 PM   #46
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It can happen still. I just don't know anyone that has actually had it happen personally. I believe it is hard coded into the ABS module. Someone may be able to correct me on this.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Old 06-13-2023, 03:52 PM   #47
strat61caster
strat61caster's Avatar
Yes I have hit ice mode in pedal dance. I could repeat it easily and had it happen several times over a autox run, I started braking less stabby and it basically evaporated. Ice mode without pedal dance I’ve only experienced 2-3x in the nearly decade I’ve been driving this car, only once at a hairy autox finish.
It’ll depend on why you’re hitting ice mode whether it’ll help or not. Bad technique? Might get worse. Weird track things, you might find it easier to modulate and stay out of ice mode.
ineedyourdiddly
Old 06-13-2023, 05:18 PM   #48
RedReplicant
Drives: None
There are two forms of what some people call ice mode.
1. Lift a wheel on the brakes and ABS will shut off immediately, I haven't had this happen in the BRZ but I have in a Miata.
2. High, hard pedal and car doesn't slow as expected unless you get off the brakes entirely and go back on them. Some cars are worse in the effect than others, ours are not that bad whereas something like a Corvette will kill you. This is more or less caused by getting into ABS regulation on initial brake application and having the unit go into a feedback loop where it won't give you full braking pressure. ABS units are (generally, there are outliers) more concerned with keeping the car stabilized than providing maximum decel rate. Once you know how to trigger and reproduce it at will you can pretty easily work around it.
And yeah, I can reproduce it pedal danced too.
Originally Posted by ML View Post
I'll likely be ditching the pedal box and going back to the stock 86 pedal setup with a MK60 next year and standalone ecu TC strategy. I rode in a boosted miata with it and crazy how well it works.
If you decide to do this drop me a PM, we have a Discord for MK60 Motorsports ABS in other cars. MK60E5 the way.
RedReplicant is offline   Reply With Quote
The Following 4 Users Say Thank You to RedReplicant For This Useful Post:
Arthur-A (06-13-2023), CSG Mike (06-13-2023), GrandSport (06-13-2023), strat61caster (06-13-2023)
Old 06-13-2023, 06:06 PM   #49
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
2. High, hard pedal and car doesn't slow as expected unless you get off the brakes entirely and go back on them. Some cars are worse in the effect than others, ours are not that bad whereas something like a Corvette will kill you. This is more or less caused by getting into ABS regulation on initial brake application and having the unit go into a feedback loop where it won't give you full braking pressure. ABS units are (generally, there are outliers) more concerned with keeping the car stabilized than providing maximum decel rate. Once you know how to trigger and it and reproduce it at will you can pretty easily work around it.
Corvette had it bad. At least my C7 did. Not that happened frequently- it just locked up really bad with almost no brake power.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
The Following User Says Thank You to GrandSport For This Useful Post:
RedReplicant (06-13-2023)
Dashboard fuse box - mini fuse removal airrick Electronics | Audio | NAV | Infotainment 0 10-25-2019 06:05 PM
Removed createluck Wheels and Tires 6 02-02-2016 12:37 PM
REMOVED Chimera Audio/Visual, Electronics, Infotainment, NAV 1 06-28-2014 11:48 AM
removed Fast_Freddy DIY (Do-It-Yourself) Guides 11 11-02-2013 07:46 PM
