Old 06-27-2020, 02:22 PM   #43
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by solidsnake11 View Post
You know I post on here to help people that want to work on their car and that might not have the financial means to buy everything.
I have about $3500 in my k-swap compared to the $25,000 that most say it cost.
My point is to show others that you don't have to have piles of money to modify cars.
The proper way to fix a cracked header would be throw it away and buy a new one.
Now stop being a wuss and put a turbo on your car.
I know that you are capable of good welds if you choose to prep.
My post was to help others out too. For less than half the price of a coating, someone could apply some header wrap themselves. It will outperform the coating, and if there is a crack then a welder will be able to quickly, easily and cheaply fix the crack. The header wrap can be removed and reapplied. It doesn’t look as pretty as a coating, but it is the better thing to do. Many welders won’t want to weld over a coating. Obviously, there are exceptions. Even if they do, most porous welds on thin walled headers won’t survive repeated heat cycles of metal heating/cooling, expansion/contraction. At best, it is a gamble with their investment.
Old 06-28-2020, 02:19 PM   #44
solidsnake11
Drives: brz
There is a 2jz with a 80mm inducer gt4508 under the hood.
solidsnake11 is offline   Reply With Quote
Anyone looking for Ceramic Coating on their 86? drew935 Northern California 0 07-06-2019 04:33 PM
Thermal Barrier Coating Ceramic Coating for Exhaust and More Dadajair Southern California 2 03-25-2019 10:09 PM
ceramic coating eddiev116 NY / NJ / CT / PA 3 02-06-2015 05:54 PM
Ceramic Coating options or Jet hot coating brzadmir NY / NJ / CT / PA 4 07-10-2013 12:35 PM
