Old 06-08-2011, 06:52 PM   #43
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by Maxim View Post
You can always improve on things. Part of being a car-guy.... :happy0180: You would probably be unhappy if the car weighed 2900lbs...you'd either avoid it or look for ways to lighten it. Why not do the same for a 2750lb car? Bring it down to 2600lbs.
If the car weighed like 2200lbs (which is the next-gen Miata's target weight, BTW), I think I'd be ok with leaving it alone haha. Come to think of it, depending on when this thing actually gets released, I may have a real hard decision between a next-gen Miata and an FR-S. Hurry the F up Toyota!
On/off ramps are fun....but a true drivers road, like the dragon's tail, is infinitely more-so. I plan on the occasional trackday, plus frequent pleasure drives on surrounding roads. Finding a twisty, deserted road on a Sunday afternoon is one of my favorite things to do.
True but it seems as though you want to lighten it but not lighten it.
When I had my '94 GSR, I lightened it! Those cars were about 2700 lbs and I never weighed it but towards the end of its life cycle, I eventually gutted it. At times, I sort of see a slight resemblance from the Integra to this FRS, minus the RWD vs FWD. 170hp 4 cyl 1.8L, 8k redline, 2700 lbs etc
-removed the ABS motor
-removed the entire AC unit
-moved the battery to the rear
-removed the cruise control motor
-removed the lower part of the air box for an AEM units (couldn't drive it in the rain b/c it'll suck up water and they didn't have the bypass valve yet)
-removed the rear seats, plastic trimming, carpet and sound deadening material
-removed the spare tire and jack
-had a straight pipe (HKS dummy cat)
-had a full Trust exhaust (before they went to Greddy)
-removed/shaved the power antenna, side molding and rear wing
btw, I love twisties too!
Old 06-08-2011, 08:24 PM   #44
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
I don't think you're reading the same posts I'm writing. Nowhere have I mentioned adding anything. I've re-read my own posts and am completely unable to see where you got that from.
Aren't you the one that mentioned you wanted a sub w/ built in amp for the car? Doesn't sound like a weight diet to me. If anything you want all the creature comforts.
tranzformer is offline   Reply With Quote
Old 06-08-2011, 08:34 PM   #45
tranzformer
Drives: Zoom Zoom
You mean the road with a 30mph speed limit and a local cop/state highway patrol officer every 1/2-1mile. Yeah I wouldn't count that a true drivers road any more since you can't really enjoy it any longer.
+1.
Originally Posted by Merlin View Post
I see where this is going. I plan to auto-x this car in the stock class, maybe G-stock. More likely D-stock.
Reducing weight can gain performance everywhere.
First, aftermarket cat-back,
Double adjustable aluminum shocks.
Remove everything that is not bolted down, spare tire and jack.
Empty water in the windshield wiper washer container.
Empty radiator overflow container.
Half filled master cylinder, half fill radiator.
Turn brake rotor down, sand brake pads down.
Hollow front sway bar.
Update/backdate parts from lesser model.
Of course there is more, but you get the gesture.
1/2 filling fluids just doesn't seem practical for a vehicle that will also be used as a DD. Also sanding brake pads down and hollowing out the sway bars to save weight is a piss poor manner to reduce weight at the risk of safety and longevity of car parts. Pass.
Old 06-08-2011, 09:54 PM   #46
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by PAImportTuner View Post
This is all a replacement list.. not a take away list. - I tried to stay at a reasonable cost.
Low profile lightweight speakers
Full titanium exhaust, bolts/nut throughout the chassis
Enkei RPF1s or lighter
Aluminum bodied shocks/struts
Aluminum control arms and links
Aluminum front and rear crossmembers
Aluminum uprights
Aluminum engine and trans mounts
Aluminum/Carbon drivershaft
Fiberglass/CF hood,trunk, and Sparco or Corbeau bucket seats, aluminum seat brackets.
I'm sure it will come with plastic intake manifold and valve covers like almost every Subaru these days come with.
O RLY?
heh...
List is good, though, just not sure I agree on the 'reasonable cost' part.
I would add, aluminum hat brakes, ATI crank damper (don't do lightweight crank pulleys people...), aluminum accessory pulleys, and power steering delete (with the low weight, and good distribution this shouldn't be half as bad as it was on my Supra).
Brake part isn't cheap, though.
Because titanium.
Old 06-08-2011, 10:14 PM   #47
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
+1.
Ever heard of Hotchkis bars? They are hollow and safe.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 06-08-2011, 10:23 PM   #48
Dimman
Kuruma Otaku
Dimman's Avatar
Hmm, missed the 'hollowing out' the anti-roll bar comment. Makes it sound like people are doing it themselves...
In torsion, the inside hardly does anything, it's wasted material.
Tanabe anti-roll bars are also hollow and chrome-moly.
Because titanium.
Old 06-08-2011, 10:26 PM   #49
PAImportTuner
Drives: U Mad?
Originally Posted by TomGT View Post
dreamer
Stfu. The last 4-5 posts you've made are irritating and sounds like an overstrung tween boy. you don't know what your talking about and obviously have a strong biased opinion of what the car should be. Btw this is a diet/lightweight thread, we are just shooting ideas of how to make lightweight post production.
You can leave now.
Old 06-08-2011, 11:10 PM   #50
ToyotaObsession
ToyotaObsession's Avatar
Drives: 2008 XRunner
You can leave now.
If you had read the rest of his posts. English isn't his native language. Him and the OP already discussed what he said.....
You don't need to police the board.
“From the beginning, the concept was to put the driver back in the driver’s seat, and to eliminate computers as much as possible today. Powerful sports cars use a lot of computer technology so that anyone can drive and handle them. We decided not to go down that road.” - Tetsuya Tada
ToyotaObsession is offline   Reply With Quote
Old 06-08-2011, 11:30 PM   #51
tranzformer
Drives: Zoom Zoom
Difference between buying something engineered and designed with that in mind vs a home project as the poster made it sound. Big difference don't you agree? It isn't about just drilling some holes here and there. I could have misread the post but they made it sound like a home job.
Old 06-08-2011, 11:35 PM   #52
Dimman
Kuruma Otaku
Dimman's Avatar
Looking at the original, I'm pretty sure he was using 'hollow' as an adjective, not a verb.
That being said, I would love to see someone try to hollow out their own, solid anti-roll bar. That would be hysterical. (For those that don't know, they're not straight...)
Because titanium.
Old 06-08-2011, 11:40 PM   #53
tranzformer
Drives: Zoom Zoom
Yeah that could very well be the case. The poster just included that after mentioning a few other things they would do themselves so this kinda flowed in. I probably just misread that as it would be dumb to even try this. But you never know on a forum.
Old 06-08-2011, 11:58 PM   #54
Random_Art
professional smartass
Random_Art's Avatar
Drives: 16 speed mountain bike...
Agreed. There are plenty of other roads throughout the north Georgia mountains and south east Tennessee that are a blast to drive, have very low traffic, and rarely patrolled to the point where on some of them I've never seen a cop.
The Tail of the Dragon became legendary for it's twists and turns to the point where it's a tourist trap.
Goodbye Celica, you served me well.
http://artsofrandomness.blogspot.com/
Random_Art is offline   Reply With Quote
Old 06-09-2011, 12:11 AM   #55
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
Originally Posted by bigbcraig View Post
perhaps an aftermarket head unit and speakers
You're forgetting the amp, if I'm not mistaken. I doubt this thing will have enough power draw for aftermarket speakers, even with a headunit.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 06-09-2011, 01:36 AM   #56
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
^ i agree, factory premium sound systems are pretty common but they also add weight. Which is why we see them in pretty average and heavy cars. If someone is looking to dump sounds into the FR-S, they might have to up the amperage of the alternator.
WingsofWar is offline   Reply With Quote
Photographer's thread Giccin Off-Topic Lounge [WARNING: NO POLITICS] 1169 04-01-2026 09:55 AM
Intoxicated thread #87 Off-Topic Lounge [WARNING: NO POLITICS] 46 04-27-2012 07:17 PM
Joke Thread VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 27 07-09-2011 12:44 AM
The Music Thread aliphian Off-Topic Lounge [WARNING: NO POLITICS] 13 03-28-2011 11:35 AM
