BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 |
TRACKBREAD
#44 |
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
Went back and checked bc I couldnt remember exaclty. Before incentives and car trade we agreed to 30.1k (no destination fee), invoice was 31.4, msrp was 32.5, atleast that's what they showed me. The other 3 listed around me were all asking 33+ and only one of them had the sti short shifter.
The Following User Says Thank You to Vides990 For This Useful Post: | Yoshoobaroo (05-09-2020) |
#45 |
Drives: Civic Sport; seeking weekend car
Appreciate the info on numbers.
Just listed my 128i for sale, so one step closer to changing communities. Next up is to drive the tS. Driven the regular BRZ many times so I know I like the platform. |
#46 |
Drives: 2020 Subaru BRZ tS
#47 |
They only made 300 tS for the 2020 version - if you get a "steal" of a deal on a tS, then yes go for it but otherwise a BRZ limited with the PP package negotiated down is probably a more cost effective way of owning a new one. I have no proof but I wonder if they will drop the model for 2021 and release the 2.0 version in 2021 for the 2022 model...? COVID is a bitch and the BRZ sells terribly... even though Subaru makes just enough BRZ's to cover those numbers and the Toyota partnership is probably the only reason its still around in terms of cost sharing.
#48 | |
In hindsight I think the dealer may have known that red was getting canned for the next model year, but I also talked with another dealer about a silver BRZ and got a very similar treatment. I ended up walking away, but I also wasn’t quite as serious a buyer as I am now. |
#49 | |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
#50 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
#51 |
Drives: ZC6
This just came to my mind and wonder if anyone can provide confirmation and clarification. It is very much related to this topic so I didn't wanna make a new thread.
The USDM tS (and JDM's STi Sport/tS models) comes with the STi springs right? And said springs do provide a very subtle drop. It is to my understanding from research that this platform doesn't come with camber adjustments, and it is advised that you do install camber bolts/kits and an alignment after modifying any suspension components that alters ride height (mainly coilovers and lowering springs). So with all that said, does the tS have different alignment specs than the stock cars? Does this also mean that the tS have camber alignment? These questions came from my research that apparently, even if I install a mild lowering spring like the STi Pinks on a stock BRZ, camber bolts at the very minimum are required for proper alignment. Any info on this aspect would be greatly appreciated. Thank you! |
#52 |
Drives: '15 BRZ RA
I don't think they changed the alignment specs. All STI cars had a drop in the range of 10-15mm , which is not that much. At least I can confirm that the JDM tS models had same suspension bolts. There was no usage of a camber bolt.
The Following User Says Thank You to nikitopo For This Useful Post: | Seiryuu (05-15-2020) |
#53 | |
Drives: ZC6
So I guess it's safe to say that I can do a stock-spec alignment with no issue with just the STI Pinks. I know you might as well throw in the camber bolts while there though and give it a couple of degrees. Thanks for the confirmation! |
The Following User Says Thank You to Seiryuu For This Useful Post: | nikitopo (05-15-2020) |
#54 | |
Drives: 2020 BRZ tS 247/300, 1995 Miata
Getting the exact same highway gas mileage on my tS as on my 2020 86. |
AT vs MT WHP difference | JDM4E | Engine, Exhaust, Transmission | 48 | 04-06-2020 06:43 PM |
cat/no cat hp difference? | EN2_Squirrel | Engine, Exhaust, Transmission | 6 | 11-17-2013 09:32 PM |
Group Buy Limited Limited Limited Edition 57Xtremes in KY color | vividracing | Groupbuys | 0 | 10-14-2013 07:22 PM |
BRZ vs BRZ limited? what is the difference? | Bangduk | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-07-2012 03:36 PM |
