Old 05-09-2020, 04:19 PM   #43
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by Vides990 View Post
I got mine for 1500 under invoice, no complaints for sure.
What’s invoice for a tS?
Old 05-09-2020, 05:28 PM   #44
Vides990
Drives: 13 BRZ (sold) 20 BRZ TS (sold)
Went back and checked bc I couldnt remember exaclty. Before incentives and car trade we agreed to 30.1k (no destination fee), invoice was 31.4, msrp was 32.5, atleast that's what they showed me. The other 3 listed around me were all asking 33+ and only one of them had the sti short shifter.
Vides990 is offline   Reply With Quote
The Following User Says Thank You to Vides990 For This Useful Post:
Yoshoobaroo (05-09-2020)
Old 05-10-2020, 07:07 PM   #45
kaputt
Drives: Civic Sport; seeking weekend car
Appreciate the info on numbers.
Just listed my 128i for sale, so one step closer to changing communities. Next up is to drive the tS. Driven the regular BRZ many times so I know I like the platform.
kaputt is offline   Reply With Quote
Old 05-11-2020, 12:30 AM   #46
Alistia
Drives: 2020 Subaru BRZ tS
Originally Posted by kaputt View Post
Pretty good deal, did that $29.7k number include destination?
Yep, $29.7K was before TTT.
Alistia is offline   Reply With Quote
Old 05-11-2020, 12:32 AM   #47
Alistia
They only made 300 tS for the 2020 version - if you get a "steal" of a deal on a tS, then yes go for it but otherwise a BRZ limited with the PP package negotiated down is probably a more cost effective way of owning a new one. I have no proof but I wonder if they will drop the model for 2021 and release the 2.0 version in 2021 for the 2022 model...? COVID is a bitch and the BRZ sells terribly... even though Subaru makes just enough BRZ's to cover those numbers and the Toyota partnership is probably the only reason its still around in terms of cost sharing.
Old 05-11-2020, 02:28 PM   #48
kaputt
It will be interesting to see how dealers treat the BRZ now. Last year I tried to get a red BRZ and the dealers treated the car like it was a hot commodity special edition that I was lucky to be offered $500 off on. Was a really strange experience.
In hindsight I think the dealer may have known that red was getting canned for the next model year, but I also talked with another dealer about a silver BRZ and got a very similar treatment. I ended up walking away, but I also wasn’t quite as serious a buyer as I am now.
Old 05-11-2020, 10:55 PM   #49
Ernest72
Cars that sit on lots for long periods get deals. Less BRZs on lots less deals. But you never know when they need to make number. I got a fair deal even though I made the dealer find a 2016 silver AT. He traded a 2016 black MT premium to another dealer. If I bought the black one he would have made a better deal, they told me as much and tried to convince me. Turns out I paid on the lower end of fair value for my area.
Old 05-11-2020, 11:22 PM   #50
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
$29,700 was the invoice on mine with STi shifter, foglights, floorwell lighting and a few other minor add ons. Not sure if this matters but there are still 20% out in the wild to be purchased.
2020BRZtS is offline   Reply With Quote
Old 05-15-2020, 12:37 AM   #51
Seiryuu
Drives: ZC6
This just came to my mind and wonder if anyone can provide confirmation and clarification. It is very much related to this topic so I didn't wanna make a new thread.
The USDM tS (and JDM's STi Sport/tS models) comes with the STi springs right? And said springs do provide a very subtle drop. It is to my understanding from research that this platform doesn't come with camber adjustments, and it is advised that you do install camber bolts/kits and an alignment after modifying any suspension components that alters ride height (mainly coilovers and lowering springs). So with all that said, does the tS have different alignment specs than the stock cars? Does this also mean that the tS have camber alignment?
These questions came from my research that apparently, even if I install a mild lowering spring like the STi Pinks on a stock BRZ, camber bolts at the very minimum are required for proper alignment.
Any info on this aspect would be greatly appreciated. Thank you!
Seiryuu is offline   Reply With Quote
Old 05-15-2020, 04:45 AM   #52
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I don't think they changed the alignment specs. All STI cars had a drop in the range of 10-15mm , which is not that much. At least I can confirm that the JDM tS models had same suspension bolts. There was no usage of a camber bolt.
The Following User Says Thank You to nikitopo For This Useful Post:
Seiryuu (05-15-2020)
Old 05-15-2020, 01:57 PM   #53
Seiryuu
Drives: ZC6
So I guess it's safe to say that I can do a stock-spec alignment with no issue with just the STI Pinks. I know you might as well throw in the camber bolts while there though and give it a couple of degrees.
Thanks for the confirmation!
The Following User Says Thank You to Seiryuu For This Useful Post:
nikitopo (05-15-2020)
Old 06-25-2020, 10:32 AM   #54
nashcarr
Drives: 2020 BRZ tS 247/300, 1995 Miata
Originally Posted by nextcar View Post
Another thing to consider on the tS...
The 18 inch wheels supplied are heavy. Did you notice the tS is rated for 2MPG less than the limited with PP? Identical drivetrain and gearing... The lowered fuel economy is largely weight related - and the wheels are a significant contributor.
Getting the exact same highway gas mileage on my tS as on my 2020 86.
nashcarr is offline   Reply With Quote
AT vs MT WHP difference JDM4E Engine, Exhaust, Transmission 48 04-06-2020 07:43 PM
cat/no cat hp difference? EN2_Squirrel Engine, Exhaust, Transmission 6 11-17-2013 10:32 PM
Group Buy Limited Limited Limited Edition 57Xtremes in KY color vividracing Groupbuys 0 10-14-2013 08:22 PM
BRZ vs BRZ limited? what is the difference? Bangduk Scion FR-S / Toyota 86 GT86 General Forum 1 08-07-2012 04:36 PM
