Old 01-30-2020, 02:55 PM   #43
Joveen
Joveen's Avatar
Drives: Bone stock
How stock fans better than aftermarket spal fans? You're crazy my guy.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following User Says Thank You to Joveen For This Useful Post:
j_ros94 (01-30-2020)
Old 01-30-2020, 03:04 PM   #44
j_ros94
Drives: 2017 Subaru BRZ
Originally Posted by Sportsguy83 View Post
What fans are you running? Why did you get slim fans? Stock fans are better than aftermarket super slim fans. Did you get a shroud with the fans? Can you go back to stock fans?
It seems to me your only problem here is the fans are not pulling the amount of air needed in stop and go traffic to cool your engine down.
That or you have issues with your cooling system, air bubble/leak/stuck thermostat/bad water pump among others.
Apparently stock fans wont fit with my setup so he wanted me to get a 9 inch fans wasnt even sure why but yeah wouldve gotten an 11 inch
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 01-30-2020, 03:47 PM   #45
jflogerzi
jflogerzi's Avatar
Do you have a shroud? What is the model of the fan.
2013 Series 10 FRS #553
Old 01-30-2020, 04:01 PM   #46
86MLR
86MLR's Avatar
What is the flow rate comparison.
My experience is OEM fans are typically better than any "slim" fan.
But, check the flow rate.
http://www.ft86club.com/forums/showthread.php?t=114585
There is lots of info, I couldn't find the OEM fan flow rate in my 30 seconds of googling
What happens when you turn your AC on?
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
The Following User Says Thank You to 86MLR For This Useful Post:
Irace86.2.0 (01-30-2020), Sportsguy83 (02-04-2020)
Old 01-30-2020, 05:31 PM   #47
Joveen
Joveen's Avatar
Drives: Bone stock
I don't have any flow rates but the Versus Engineering who posted that built a radiator and slim fan combo that supersedes oem cooling. So
Old 01-30-2020, 05:53 PM   #48
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The guy says he has 9” fans. I don’t know what the stock fans are in diameter or the brand or if they have shrouds, but it is entirely plausible that he made a downgrade.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Stomachbuzz (02-08-2020)
Old 01-30-2020, 10:07 PM   #49
86MLR
86MLR's Avatar
This?
https://www.verus-engineering.com/sh...58?category=41
Note:
1. Designed for motorsport? Not stop start traffic
2. Car on website has bonnet vents
My take:
1. Whilst designed for motorsport may make it sound sporty, there is a huge difference when it comes to what works on a track and what works on the street when your stuck on traffic and not lapping at speed.
2. Op does not have bonnet vents.
My old R33 with a larger radiator and OEM clutch fan would still see much higher temps than what I liked on the street, track work was fine due to the airflow thru the radiator when at the track. I fitted a vented bonnet (pics are my old boat after I had just sold it) and my temps improved massively both on the street and on the track.
Old 01-30-2020, 10:09 PM   #50
Joveen
Joveen's Avatar
Drives: Bone stock
There's lost of people running them.without vents. Nobody will convince me that oem is better than spal fans.
Old 01-30-2020, 10:17 PM   #51
jflogerzi
jflogerzi's Avatar
Everyone is entitled to their own opinions..
Old 01-30-2020, 10:28 PM   #52
86MLR
86MLR's Avatar
9"?
Which one?
https://www.spalusa.com/search?q=9%22
https://www.spalautomotive.it/axial-fans
Just need to find OEM to prove me wrong.
When you do I will stand humbled, until then....
Old 01-30-2020, 10:45 PM   #53
Joveen
Joveen's Avatar
Drives: Bone stock
http://fullblownmotorsports.com/full...ubaru-brz-fa20
Includes two 12" Spal fans, each providing over 1150 CFM of airflow
-Fits FBM and Koyo Subaru BRZ / Scion FR-S radiators
-Slim profile with a maximum thickness of just 3"
-Includes all mounting hardware for installation
Old 01-30-2020, 10:49 PM   #54
86MLR
86MLR's Avatar
And what size does the OP have?
Old 01-30-2020, 11:03 PM   #55
Joveen
Joveen's Avatar
Drives: Bone stock
9" fans. Not sure if they are spal fans. If it's the mishimoto one I know those are 12" but not spal.
Old 02-04-2020, 04:15 PM   #56
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I'm talking from experience my dude.
Stock fans are able to cool down an LS swapped 86 which generates more heat than stock turbo engine. While the super slim Spals that are included in all of the slim fan/shroud packages for this car cannot keep up.
I actually have a swapped 86 and have experience with it. With my setup stock fans did not fit and I needed to upgrade the shitty slim spal fans (the ones included with the Fullbown slim fan shroud kit which they claim it 1100+ cfm and I had found them to be 900 cfm) to 1328 cfm Spal fans. Still, stock fans were able to cool down the engine better than the 1300 spals, but they did an acceptable job.
I have a friend with a swapped 86 and stock fans who moved the radiator forward in order to fit the stock fans, and has never had any issues with cooling on his swap.
Granted, of course, no all Spals are made equal. There are larger/more CFM Spals that will be better than OEM. But given the envelope of the usual slim fans/shroud kit used for this cars, they are not better than OEM. In order to fit my 1328 CFM spals, I needed to increase the fuse from 25-30A, becuase they used a bit more current than 25A. Getting any bigger Spal that could "beat" the OEM fans, would require a larger relay kit/wiring.
The Verus kit huge improvement is because they use a super efficient radiator and like a previous poster said, racing is not the same as stop and go traffic in high heat. stop and go traffic basically the fans are by themselves to remove heat, unlike racing you have forced air coming in and cooling the radiator.
The more you know....
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
DarkPira7e (02-07-2020), Irace86.2.0 (02-04-2020), Joveen (02-04-2020), Kiske (04-15-2020)
Wtb turbo / supercharger kit Sloyota Want-To-Buy Requests 0 02-28-2019 03:15 AM
HKS Supercharger V2 vs. Greddy Turbo Kit vs. Crawford Turbo Kit Ogremair Forced Induction 27 09-10-2015 05:39 AM
Looking for a turbo or supercharger kit!! Anthony7515 Want-To-Buy Requests 11 05-16-2014 09:25 AM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 12:50 PM
Looking for a Frs for R&D on a turbo and supercharger Toxic Forced Induction 38 10-23-2012 04:13 PM
