Old 09-10-2019, 05:35 PM   #43
GrantedTaken
Originally Posted by DandoX View Post
get two of these bolts. When it comes to take off your rotors you will be very thankful.
G]
Impact wrench on those 2 bolts ?
I guess if the bolt shears, you can just resort to the BFH
GrantedTaken is offline   Reply With Quote
Old 09-10-2019, 05:50 PM   #44
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Do not use an impact wrench, use a normal socket wrench and tighten both down equally slowly, rotor pops right off. Takes like a min or two, if the bolt sheers or worse the threads in the rotor are messed up then the it becomes more annoying to deal with. My rotors where totally sealed, I bashed at them and used pb blaster and they didnt even budge, when I finally went out and bought these bolts, it came off no sweat. Save yourself some time and effort. Any twin owner who plans on servicing their own brakes should spend the dollar or two and have these bolts lying around.
DandoX is offline   Reply With Quote
Old 09-10-2019, 06:16 PM   #45
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Worst design ever? Far from it.
Go this route if you want easy to see pad wear. Yabba dabba doo!
wolffbite is offline   Reply With Quote
Old 09-10-2019, 06:50 PM   #46
soundman98
ProCrastinationConsultant
soundman98's Avatar
the problem is never just having them. the problem is that i'll get them, and when i go to actually use them, they'll be off on a romantic retreat with my 10mm socket!
Old 09-10-2019, 07:00 PM   #47
Impureclient
Drives: 2015 FR-S
Hey, there are children in here reading this!
Impureclient is offline   Reply With Quote
Old 09-10-2019, 07:10 PM   #48
soundman98
soundman98's Avatar
unfortunately, they seem to be using protection, as i'm not getting more 10mm sockets or 8mm bolts out of the deal.
Old 09-10-2019, 09:13 PM   #49
Some members parents obviously should have used protection.
Oh and... https://www.ft86club.com/forums/show...4&postcount=23
Old 09-10-2019, 10:02 PM   #50
humfrz
You're spoiling our fun -
humfrz
Old 09-11-2019, 02:11 AM   #51
Impureclient
Drives: 2015 FR-S
Old 09-11-2019, 02:18 PM   #52
Submarinesonce
Drives: Frs
OP=Clownshoes
That is all.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 09-11-2019, 02:56 PM   #53
Dake
Dake's Avatar
And just for kicks - I had the front wheel off yesterday and snapped a couple pics.
Nope - can't see it at all.
Dake is offline   Reply With Quote
Old 09-11-2019, 04:38 PM   #54
humfrz
Back in the day, we wouldn't even be having this discussion -
Is it ma nap time? - I believe it is -
humfrz
Old 09-12-2019, 11:18 AM   #55
humfrz
Yep. Hum used to be able to walk through any parking lot and see the condition of all the brakes.
Old 09-12-2019, 01:38 PM   #56
humfrz
However, the discussions did go on.
What kind of wood was best, oak, hickory or pine?
Should the blocks be fire hardened or not?
Do the blocks stay cooler if they are hash marked?
Is the use of tar pitch against the racing rules?
What about dual block brakes?
How much are big block brake kits?
Of course you paint them, if you want them to be noticed!
humfrz
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
Wtb coilovers, brake pads, SS brake lines, engine dress up stuff IBill4You Want-To-Buy Requests 2 06-13-2015 03:02 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
