Old 08-28-2012, 05:09 PM   #43
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by ABQautoxer View Post
Camber bolts from Subaru unless you don't care about stock class then you have more choices.
Entry speed push could be mainly from your stock camber and entry speeds that are simply too fast for that corner. Stiffer front springs don't automagically mean more understeer.
I don't care about stock class, planning ST.
On my STX MKV GTI (That I didn't set up, co-driver did it for me) I had slightly higher entry speeds on the same 245/40/17 R-S3s on the same concrete surface. The FR-S is killing that GTI from the center off it's not even funny.
The biggest thing is the FR-S is also my DD and I can't have camber that kills tires at an incredible rate.
I also just wanna say I'm very thankful to any help anyone can provide, I'm super new at chassis tuning.
Old 08-29-2012, 03:17 PM   #44
BlaineWasHere
Grip>Drift
Drives: FRS
The shop that's doing my install/alignment wants to know where I want to start with the ride hight. I told em 1.5" drop to be conservative. I don't want to rub at all under load. I'm running 245/40/17 on 17x9 et42. Any ride hight suggestions?
Old 08-29-2012, 03:18 PM   #45
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Who did you buy the coilovers from? Just curious since it sounds like you aren't asking for or getting help from them?
TomR
ABQautoxer is offline   Reply With Quote
Old 08-29-2012, 04:02 PM   #46
BlaineWasHere
Grip>Drift
Drives: FRS
I got them used (but still new) from someone who ordered them then his wife lost her job so to keep the car he sold all the mods he bought. So I saved some money and helped a guy out.
But no I didn't order from a guy like Sam and I don't have any support. I'm a young guy just looking for some simple assistance. With future products I see the value in that but not much I can do about that now...
Old 08-29-2012, 06:44 PM   #47
gmookher
subbing
gmookher is offline   Reply With Quote
Old 08-29-2012, 06:50 PM   #48
BlaineWasHere
Grip>Drift
Drives: FRS
It's not like I'm asking for what everyone knows/has learned about damping/rebound/spring rates.
But understand I'm just young dude without a garage or tools and I really wanna pay the shop to set the ride hight right the first time. I'm a pretty good driver but I'm exactly the opposite mechanically.
Old 08-29-2012, 07:04 PM   #49
blkwrxwag
Drives: DS FRS
When I'm not sure, I just go round and make sure it's an even two finger gap on all corners. It's a good place to start.
blkwrxwag is offline   Reply With Quote
Old 08-30-2012, 12:46 AM   #50
ABQautoxer
ABQautoxer's Avatar
Too easy Max, I'll let this one go.
I'm not answering because I've never seen a set on a FRS/BRZ to judge what the LCAs look like, shock travel, etc to begin to guess a starting point.
TomR
Old 08-30-2012, 01:06 AM   #51
BlaineWasHere
Grip>Drift
Drives: FRS
I'll be happy to post up what I've done with ride height and how it effects suspension geometry.
I'm not looking for it to be amazing right off the start, just looking to be decent. I went back and looked at Bill's build thread and he had a couple of notes about ride height. He also has the same spec wheel/tire set-up as me.
Old 08-30-2012, 12:34 PM   #52
-max-
Drives: Firestorm FRS
I have mine dropped at 1.25" from stock all around. I think much lower than that and you will mess with the LCA angle.
-max- is offline   Reply With Quote
Old 08-30-2012, 01:44 PM   #53
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Mine measures from the bottom of the rim to the arch in the fender...23" front 23 1/4" rear..
Scooby South is offline   Reply With Quote
Old 09-09-2012, 01:34 AM   #54
BRZranger
Right now, my rear is lowered about 44mm (1 3/4") and front 36mm (<1.5"). My front camber is -1.5 degrees and rear about -2.5 degrees (I think too much).
I think might be too low and may be hurting the suspension geometry. I think I want to raise it so that it is about a 30mm drop from stock.Right now it's corner balanced and aligned, so raising it will tweak it a bit (probably just camber, right? and some corner weights)
My driving is 95% daily driving and 5% autocross.
Just wanted to pick your guys' brains before I bring her in.
BRZranger is offline   Reply With Quote
Old 09-09-2012, 03:04 AM   #55
BRZranger
Smaller picture
Old 09-09-2012, 06:58 AM   #56
-max-
Seem to me you need a bunch more front camber and maybe a little less rear. Im running 2.7/2.2 fr/rr. I'm still dialing in, but 1.5 is not nearly enough IMO.
My BRZ ST* Autocross build Scooby South Tracking / Autocross / HPDE / Drifting 848 08-14-2018 11:20 AM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
1st Autocross w/ my FR-S MarkRacerX FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 24 06-24-2012 10:55 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
