Old 09-03-2019, 12:36 PM   #43
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by qqzj View Post
Just want to make sure it can actually deliver.
They're round and hold air. They're the right size for the tires you mentioned running. They're lighter than OEM, and they're inexpensive. Sounds like they'll deliver just fine.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 09-03-2019, 04:53 PM   #44
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by bakerr6 View Post
I run motegi traklites and 225/50/16. They work well for dd and track.
Wheels are around 12lb each.
I wish they still made them
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
bakerr6 (09-27-2019), why? (09-04-2019)
Old 09-10-2019, 07:16 PM   #45
qqzj
Drives: MDX, Camry
Exactly. I spent quite some time looking for them w/o luck. The best wheels are Enkei RPF1 and OZ Ultraleggera for 16 inches as of now. The Sparco one I found is heavier by about 3 pounds. I am very curious why the Sparco in Rally Gold is about 1 pound lighter than other colors. This is what I see on tirerack.com. Typo?
qqzj is offline   Reply With Quote
Old 09-10-2019, 08:17 PM   #46
new2subaru
Weight Weenie
Drives: 15 FR-S
I wasn’t really looking at extreme weight saving when I got mine, just didn’t want to break the bank.
I have a set of these
https://pmctire.com/en/wheels/dai-al...t-40-73-1.tire
And these
https://www.motegiracing.com/product...achined-flange
Both were less weight than OEM just can’t remember by how much
Old 09-10-2019, 08:20 PM   #47
new2subaru
Weight Weenie
Drives: 15 FR-S
I’m looking at a set of these now
http://wedssport.jp/products/english/tc105x.html#
16x7 is 12lbs
Old 09-10-2019, 08:44 PM   #48
qqzj
Drives: MDX, Camry
And these
Both are pretty heavy. About 2 pounds more than the Sparco one. Also the OEM is a 17 inch wheel, these are 16 inch. With more tires, the combo might be heavier than OEM if you use these two wheels.
BTW, 215 50 16 is a really weird size. One two lack luster choices on tirerack.com. I finally realized why folks here tend to choose 205 55 16 instead. I probably will do the same.
Old 09-10-2019, 09:47 PM   #49
new2subaru
Weight Weenie
Drives: 15 FR-S
With tires they weighed in slightly less but not enough to make any difference. The 205/55 r16 is a great tire size imo
Old 09-13-2019, 12:48 PM   #50
venturaII
venturaII's Avatar
if you want to drop to a 50 series tire with a 16" wheel, then the size you want is 225/50, not 215/50. Plenty of choices in that size and it works very well with a 16x7.
The Following 3 Users Say Thank You to venturaII For This Useful Post:
bakerr6 (09-27-2019), new2subaru (09-13-2019), why? (09-13-2019)
Old 09-13-2019, 06:57 PM   #51
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
215 was simply never a size needed for 16". Most 15" wheels were 195, so the next size up was always 205.
Old 09-13-2019, 07:10 PM   #52
new2subaru
Weight Weenie
Drives: 15 FR-S
There are a few 215/45 but then you’re back to low profile tires again
The Following User Says Thank You to new2subaru For This Useful Post:
why? (09-14-2019)
Old 09-14-2019, 07:50 PM   #53
why?
why?'s Avatar
Drives: series.blue
and unless you are on perfectly smooth roads low profile tires are a disaster.
The Following User Says Thank You to why? For This Useful Post:
nikitopo (09-15-2019)
Old 09-14-2019, 09:03 PM   #54
new2subaru
Weight Weenie
Drives: 15 FR-S
I agree. Some suspensions can manage them but you the risk to break a belt or rim is compounded.
Recommend for me a good bad tyre :P Ganthrithor Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-14-2019 05:23 PM
Recommend any good auto shops? mick86 Arizona 3 08-11-2016 12:19 AM
Recommend me some cheap & good gloves Hanakuso Tracking / Autocross / HPDE / Drifting 24 01-02-2013 08:50 PM
Recommend a good tire shop in LA/OC Hanakuso Southern California 10 12-08-2012 06:15 PM
Can anyone recommend a good body shop? deucethemoose Northwest 14 11-02-2012 09:09 PM
