| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#43 |
Only users lose drugs.
Drives: All the time
They're round and hold air. They're the right size for the tires you mentioned running. They're lighter than OEM, and they're inexpensive. Sounds like they'll deliver just fine.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#44 |
Weight Weenie
Drives: 15 FR-S
#45 |
Drives: MDX, Camry
Exactly. I spent quite some time looking for them w/o luck. The best wheels are Enkei RPF1 and OZ Ultraleggera for 16 inches as of now. The Sparco one I found is heavier by about 3 pounds. I am very curious why the Sparco in Rally Gold is about 1 pound lighter than other colors. This is what I see on tirerack.com. Typo? |
#46 |
Weight Weenie
Drives: 15 FR-S
I wasn’t really looking at extreme weight saving when I got mine, just didn’t want to break the bank.
I have a set of these https://pmctire.com/en/wheels/dai-al...t-40-73-1.tire And these https://www.motegiracing.com/product...achined-flange Both were less weight than OEM just can’t remember by how much |
#47 |
Weight Weenie
Drives: 15 FR-S
#48 | |
Drives: MDX, Camry
Both are pretty heavy. About 2 pounds more than the Sparco one. Also the OEM is a 17 inch wheel, these are 16 inch. With more tires, the combo might be heavier than OEM if you use these two wheels. BTW, 215 50 16 is a really weird size. One two lack luster choices on tirerack.com. I finally realized why folks here tend to choose 205 55 16 instead. I probably will do the same. |
#49 | |
Weight Weenie
Drives: 15 FR-S
#50 |
if you want to drop to a 50 series tire with a 16" wheel, then the size you want is 225/50, not 215/50. Plenty of choices in that size and it works very well with a 16x7.
| The Following 3 Users Say Thank You to venturaII For This Useful Post: |
#51 |
Only happy when it rains.
Drives: series.blue
215 was simply never a size needed for 16". Most 15" wheels were 195, so the next size up was always 205.
#54 |
Weight Weenie
Drives: 15 FR-S
| Recommend for me a good bad tyre :P | Ganthrithor | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 01-14-2019 04:23 PM |
| Recommend any good auto shops? | mick86 | Arizona | 3 | 08-10-2016 11:19 PM |
| Recommend me some cheap & good gloves | Hanakuso | Tracking / Autocross / HPDE / Drifting | 24 | 01-02-2013 07:50 PM |
| Recommend a good tire shop in LA/OC | Hanakuso | Southern California | 10 | 12-08-2012 05:15 PM |
| Can anyone recommend a good body shop? | deucethemoose | Northwest | 14 | 11-02-2012 08:09 PM |
