Old 03-13-2019, 03:22 AM   #43
Ultramaroon
not playing cards
Ultramaroon's Avatar
Originally Posted by jaseow View Post
I figure the battery is worth a shot and even if it isnt the battery Ill have a spare for the future ? But only if it will maintain its charge for future use
If you get a decent little trickle charger it'll last practically forever.
Old 03-13-2019, 04:14 AM   #44
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This is what I go by:
"Battery Voltage and State of Charge:
12.66v . . . . . . . . . . 100%
12.45v . . . . . . . . . . 75%
12.24v . . . . . . . . . . 50%
12.06v . . . . . . . . . . 25%
11.89v . . . . . . . . . . 0%
(NOTE: these readings are at 80 degrees F. Battery voltage readings will drop with temperature roughly 0.01 volts for every 10 degrees F.)
(At 30 degrees F. a fully charged battery will measure about 12.588 volts, and at zero degrees F it will measure about 12.516 volts.)
CHECK BATTERY CHARGING VOLTAGE
After charging the battery or jump starting the car, connect the voltmeter to the battery the same as before and not the charging voltage. A charging system that is operating normally should produce about 13.8 to 14.3 or more volts at idle. If the charging voltage is less than 13.0 volts, the alternator is not putting out enough voltage and current to keep the battery charged."
End of quote.
(I scraped that off the Internet, so it must be true - )
humfrz
Damn it @humfrz. Making me prove my work/logic.
I go by voltage per cell. It should be 2.1-2.2 per cell and most battery 12v are 6 cell without a surface charge.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
humfrz (03-13-2019)
Old 03-13-2019, 08:53 PM   #45
humfrz
OK, we agree - depends on whether or not the battery was straight off a charger or it had "rested" for a few hours (12-24 hours) after being charged.
humfrz
NoHaveMSG (03-13-2019)
Old 03-14-2019, 09:00 PM   #46
jaseow
Drives: 2012 Toyota 86
I was looking up more on this issue online and came across this guy who had a similar problem
https://forums.edmunds.com/discussio...-buick-enclave
It was a different car but problem sounds exactly the same as mine. Random extended cranks that were hard to reproduce
Turns out he had to replace all the injectors.
“Well I got my car back from the dealership- they had to replace all of the injectors, 5 were out of spec and the 6th was borderline. Car runs and starts as it should, no more extended crank or surge under load. Hopefully if someone has the same problem this will help them. I thank all that have contributed to helping get to the bottom of this head scratcher.”
Sounds like itll be a costly job. Not familiar with the toyota engines and how easy / difficult it would be for a dealership/mechanic to replace the injectors?
jaseow is offline   Reply With Quote
Old 03-14-2019, 09:20 PM   #47
humfrz
Since you can't seem to "let this go", I suggest you take it to a dealership and pay them the $140 to do their diagnostics -
humfrz
Old 10-09-2022, 07:07 PM   #48
londonbell
Drives: GTS 86
I have the same problem here in Australia, and sadly there is no Subaru TSB or Toyota TSB in this country for both 86/BRZ. And I am pretty sure it’s not related to battery since I have random extended crank when battery is new. Tried method people talked about which I should BUILD FUEL PRESSURE before startup the engine. But problem still there. Went to one of the biggest Toyota dealer in Adelaide, let them check the ECU for me but they said no issues at all. This extended crank is not about 10s startup time, it just sometimes you can feel the shaking in your engine starts, which it’s abnormal. And besides these, the winter temperature in this country is not too low, normally 7-8°C. So I’m confused.
londonbell is offline   Reply With Quote
Long crank startup itzaustin Issues | Warranty | Recalls / TSB 12 03-23-2019 07:25 PM
Occasional high pitched squeak Midjetv8 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-28-2016 08:00 AM
RPM occasional drop with AC on Dboe Issues | Warranty | Recalls / TSB 5 08-15-2014 06:03 PM
Best kit for occasional track usage yomny Forced Induction 14 02-06-2014 09:10 AM
a lot of people like sports cars for looks and the occasional WOT autobrz Other Vehicles & General Automotive Discussions 4 09-17-2013 03:35 PM
