Old 04-16-2018, 03:41 PM   #43
sid94
Drives: 2013 frs
Also any reason why I’m not getting a low fuel pressure code?
sid94 is offline   Reply With Quote
Old 04-22-2018, 04:11 AM   #44
sid94
Drives: 2013 frs
So I switched the tune and loaded both my tune from full blown and my stock tune and with both of them I had no maf sensor code.
As for my fuel pressure I have 2 high pressure pumps and a known good DI module. Low side fuel pressure is getting there confirmed with mechanical gauge but it doesn’t seem to be creating pressure. I disconnected the connector for the high pressure pump and checked with noid light to make sure it was receiving the signal and it is receiving it.
This is a issue that I had at times before the built engine too just now on a completely larger scale. My fuel presussure on high side would randomly just drop. Normally I would turn the car off and let it cool down a bit and it came right back.
I was thinking the fuel pressure sensor maybe? But again wouldn’t that throw a code? I bench tested as per service manual but from experience it doesn’t always mean it’s good even if you bench test it.
Still fighting this issue please any help is appreciated!!!
Old 04-27-2018, 09:16 PM   #45
sid94
Drives: 2013 frs
Alright people idk if any of you are still keeping up with this thread but I hope this will help people that have my same issue in the future
I had everything I needed to run. Compression, air coming in, spark, and fuel
Just didn’t have enough fuel pressure. My cylinder 1 and 4 spark plugs were sooty and cylinders 2 and 3 were looking good still. Car started but didn’t build fuel pressure nor idled properly
So after what seemed like endless fault tracing and swapping parts I so happened to comment on a post on the gulf coast 86 Facebook page and the homie @Frs300 replied to the comment saving my sanity
I was off timing on drivers side bank. Good thing is I was 180 off which then turned my compression to exhaust stroke and vise versa explaining why I had compression but the cam lobe was off for the high pressure pump so no pressure being built.
Can’t thank you guys enough for all your Yelp fault tracing, now it’s time to break in my engine and pray nothing else happens lol
The Following User Says Thank You to sid94 For This Useful Post:
Irace86.2.0 (04-27-2018)
Old 04-27-2018, 10:13 PM   #46
ermax
ermax's Avatar
That’s great news. I just started rebuilding mine today. Destroyed a rod bearing on the way to work yesterday doing a pull to redline in 4th on the interstate. Oil level is to the top dot. I got mine with 83k and I’ve always felt it had a faint rod knock. Everyone on this forum said it’s normal for them to sound like ass so after about three months of stressing out over it I accepted that it really was just normal.
Anyways, I think my plan right now is a short block. Tonight I started the engine pull. So far it’s been an easy project. All I have left is to unbolt the tranny and do the pull. I can’t wait to split the block and see if it’s seal material blocking flow to #4.
Old 04-27-2018, 10:17 PM   #47
sid94
Drives: 2013 frs
Go for it man I haven’t had my car for 7 months so the excitement I have right now is beyond explanation
Old 04-27-2018, 11:26 PM   #48
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
@sid94
So it was a tuning issue all along?
Old 04-27-2018, 11:37 PM   #49
sid94
Drives: 2013 frs
@sid94
No my timing was off my cams were 180 off so nothing got bent it just took off timing cover and re did my timing
Old 04-28-2018, 01:02 AM   #50
Irace86.2.0
Oh the whole camshaft was rotated 180 degrees? Both? Who did that one? You?
Old 04-28-2018, 01:50 PM   #51
sid94
Drives: 2013 frs
Both and yup it was me I got nobody to blame but I am happy it’s finally fixed
Irace86.2.0 (04-28-2018)
Old 04-28-2018, 03:59 PM   #52
Irace86.2.0
It happens. Just curious if a shop was at fault.
Building the engine for 400+hp Dogster70 Forced Induction 20 07-16-2017 10:59 AM
New motor - starting issue protpibe Engine Swaps 24 06-01-2015 01:01 AM
Starting issue? winsometang Issues | Warranty | Recalls / TSB 7 11-26-2014 06:25 PM
Starting issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 33 08-15-2013 08:40 AM
Van starting issue-need advice. LivingLegend Off-Topic Lounge [WARNING: NO POLITICS] 3 01-15-2013 11:48 PM
