Old 02-21-2018, 09:45 AM   #43
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I have repaired damage like this on a ton of doors, of all makes. something pressed against the door skin and the sheet metal formed around the crash bar, which is part of the door frame structure and foam glued to the door skin. The only time I have seen the door skin show the line of the crash bar from temperature change is when a body shop replaced the door skin and used a non flexible adhesive between the crash bar and skin
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
humfrz (02-21-2018), Spuds (02-21-2018), Tcoat (02-21-2018)
Old 02-21-2018, 09:50 AM   #44
Do they usually keep growing though? Totally see this happing but the strange part of this one is that it keeps getting worse but there is no indicator of impact from the outside.
Not disputing just don't see how it gets bigger.
Old 02-21-2018, 09:54 AM   #45
spitfire481
Drives: 2JZ FRS
A picture of the foam would make it a little clearer to see if there is a material problem which would allow a temp change to make the line change. it takes a minimal bump to make a crease around the bar. Can be easily done without leaving any mark whatsoever on the paint.
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Tcoat (02-21-2018)
Old 02-21-2018, 01:50 PM   #46
humfrz
Interesting.
So, what is the "fix" ..??
humfrz
Old 02-21-2018, 02:08 PM   #47
spitfire481
Drives: 2JZ FRS
Interesting.
humfrz
figure out if its from an impact, or a material failure from the factory (foam adhesive) first
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
humfrz (02-21-2018), Tcoat (02-21-2018)
Old 02-21-2018, 02:38 PM   #48
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
interesting, being from the same city as OP i sure hope i dont find myself anywhere near him lol i like my doors the way they are
JustSomeGuy is offline   Reply With Quote
Old 02-21-2018, 02:41 PM   #49
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Looks like the drivers side?
Has a snowplow been past and piled a load against it?
Old 02-21-2018, 04:06 PM   #50
Rustyspoon
Drives: FR-S, XJS, C10
I have it in the shop now. Many years ago they performed the window freeze fix. Could that be related?
Rustyspoon is offline   Reply With Quote
Old 02-21-2018, 04:06 PM   #51
Rustyspoon
Nothing like that has happened. Thankfully!
Old 02-21-2018, 04:07 PM   #52
Rustyspoon
Cold as ice you are!
The Following User Says Thank You to Rustyspoon For This Useful Post:
JustSomeGuy (02-21-2018)
Old 02-21-2018, 04:09 PM   #53
Don't see how.
Old 02-21-2018, 04:18 PM   #54
JustSomeGuy
A Nobody
Drives: FRS
Aha im just teasing lol hopefully its a cheap easy fix and isnt too much of a hassle though, good luck
Old 02-21-2018, 04:21 PM   #55
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
I once hauled a motorcycle in a Tacoma and the rear tire of the motorcycle was resting on the truck's tailgate. The tailgate did not sag or bend and the gaps and function were still perfect after the trip. That said I did have a slight protruding crease similar to this. I assumed there was enough flex in the tailgate to let the internal support come in contact with the backside of the skin.
SCQTT is offline   Reply With Quote
The Following User Says Thank You to SCQTT For This Useful Post:
Tcoat (02-21-2018)
Old 02-21-2018, 04:42 PM   #56
hichamaziz
Drives: subaru brz
Can you back the pics off a bit so we can tell what we are even looking at?
hichamaziz is offline   Reply With Quote
WTB BRZ Driver's Side Door, WRB ngabdala Cars for Sale/Trade 1 06-17-2015 11:18 PM
WTB BRZ Driver's Side Door, WRB ngabdala NY / NJ / CT / PA 0 06-16-2015 07:17 PM
WTB BRZ Driver's Side Door, WRB ngabdala New England 0 06-16-2015 07:16 PM
WTB BRZ Driver's Side Door, WRB ngabdala Want-To-Buy Requests 0 06-16-2015 07:12 PM
Driver-side door not responding ! Pish Issues | Warranty | Recalls / TSB 10 01-21-2015 01:42 PM
