Old 11-08-2017, 04:24 PM   #43
runfrodorun
Drives: Red 2013 BRZ Premium 6MT
Don't blip on an up shift. I know it is tempting but it is backwards to what you want to achieve. When down shifting you are going from a gear with lower RPMs to one that is going to bring them up so you have to blip to rev match and speed up the engine closer to where you want to be. When up shifting you are going from a gear that is in high RPMs into one that will start out much lower. You actually want the RPMs to drop a bit in the up shift to be closer to the synchros speed in the higher gear.
Make sense?
I do not blip on upshifts, sorry if what I wrote was confusing. Was just talking about downshifts. I just let the RPM fall, and I engage when the time is right. Or if I'm single clutching, I just shift with a purpose. Not as fast as I can, just with a purpose, and I release the clutch when the RPM's match.
runfrodorun is offline   Reply With Quote
The Following User Says Thank You to runfrodorun For This Useful Post:
Tcoat (11-08-2017)
Old 11-08-2017, 04:28 PM   #44
runfrodorun
Oh, I wasn't suggesting the mod. Quite the opposite. Bring it back to stock and see if that doesn't first solve the issue.
Sorry. I can see how my post read that way.
I have your sig link opened in another tab, I hope I can get to doing the adjustment some time in the next week, otherwise it will have to be a thing for next year.
Old 11-08-2017, 04:28 PM   #45
Perfect. Just trying to work through all the possibilities since it is odd that one guy had the same issue with two trannys.
I seem to be blessed with a perfect tranny so I am always baffled when somebody has issues. They apparently were not all made the same.
Capt Spaulding (11-09-2017), runfrodorun (11-08-2017)
Old 11-08-2017, 04:31 PM   #46
runfrodorun
I agree its strange, but I just don't see how I could be driving this poorly after a million miles in manuals. I do appreciate your diligence though, if I'm doing something wrong I would want to know, since it's my wallet that gets punished for it. I'm going to try doing the clutch adjustment and see what happens with that. the symptoms do reek of a poorly adjusted clutch, and I thought that I ruled that out but in light of some of this new information, I'm going to go back to that. I could see somebody wanting to delay the travel if they tracked it, because then they would want more force in the fully engaged position to prevent slip under high stress situations.
Tcoat (11-08-2017)
Old 11-08-2017, 05:58 PM   #47
humfrz
I agree its strange, but I just don't see how I could be driving this poorly after a million miles in manuals. ...........
I think you should just get rid of that car ..........
humfrz
Old 11-08-2017, 06:05 PM   #48
At least you understand I am just trying to remove variables not critique your driving without having a clue how you drive. Too many would get all pissy instead of answering.
Now that we have remove technique for the list I have to go with Ultra on that it seems to be more clutch related than synchro. I can see one tranny being beat on with bad synchros but the new one should not be the same. The coincidence is more than my poor feeble mind can accept.
Old 11-08-2017, 07:33 PM   #49
runfrodorun
At least you understand I am just trying to remove variables not critique your driving with having a clue how you drive. To many would get all pissy instead of answering.
Now that we have remove technique for the list I have to go with Ultra on that it seems to be more clutch related than synchro. I can see one tranny being beat on with bad synchrs but the new one should not be the same. The coincidence is mare than my poor feeble mind can accept.
I agree.
I just met with a member, and we compared cars. His shifted /significantly/ nicer than mine with the original transmission in it. /S-i-g-n-i-f-i-c-a-n-t-l-y/.
If I push the clutch in extra hard and wait a long time, and then shift with a lot of force, it seems to go in without as many complaints, but it still chatters and grinds just a tad once in a while.
Will adjust next summer, and hope to god that that solves the problem. I will be a very happy guy if it does.
Old 11-08-2017, 07:35 PM   #50
runfrodorun
humfrz
If it comes to that it might just be LS2 time. But that depends where I live and if emissions will be a concern.
Old 11-08-2017, 08:07 PM   #51
humfrz
Well, I really believe, that sometimes a car and a driver are just incompatible.
Obviously, something is messed up in the drivetrain of that car and it may not be worth your time and aggravation to try to figure it out.
I recall, back-in-the-day, I bought a new Austin Marina. I thought it would be a handy, practical little vehicle for my wife to drive.
I tried soooo hard to like that car .....
That car was nothing but a pain in the ass. You name it ...... it went wrong. Finally, the differential started grinding, so I opened it up, gad what a mess, so, I closed it back up and filled it up with axil grease.
I sold the car to this hot shot young man, that was a f _ _ _ ing know it all.
THE END
humfrz
PS @Tcoat ,have I told this story before ......
Old 11-08-2017, 08:28 PM   #52
THE END
humfrz
Nope. That is a new one. All clear.
humfrz (11-08-2017), Ultramaroon (11-08-2017)
Old 11-08-2017, 08:41 PM   #53
humfrz
That's a relief ....... I thought maybe that I was going to have to start making up some new ones .......
humfrz
Tcoat (11-08-2017)
Old 11-08-2017, 10:12 PM   #54
Ultramaroon
not playing cards
Ultramaroon's Avatar
I remembered the no-brainer while driving home tonight. Bleed your system to make sure it isn't just air taking up travel!
Old 11-09-2017, 11:00 AM   #55
runfrodorun
So I went out for a pretty long drive last night. After it was really warmed up, it was behaving pretty well, but it was just around town driving. May be a little different at freeway speeds. I also met up with a local FRS owner and drove his car, his transmission really felt perfect in comparison. His climate control wasn't behaving that differently from mine either. I may have just been remembering wrong; either that or mine has started working since. who knows.
I did some experiments with the clutch. I think it's totally disengaged anywhere less than 1.5inches from the floor, pretty generous amount of room. I could lift it up an inch, and slide it into first, then take it out without moving my foot, and then slide it back in and it would still be lined up and not spinning, meaning its still totally disengaged. so I think it's probably adjusted just fine. I think I could have gotten away with higher. if I wanted to move forward, it was about 1.5 inches that I had to be at to feel it start to grab. Just didn't see the sense in sitting there trying to grind my transmission in the parking lot, seemed silly. It was still skipping two or three teeth going into 5th almost every time, and once in a while it was still skipping a tooth or two going into 2nd, but it was significantly better.
So I guess the take away is this transmission is ridiculously cranky when its cold and still skips a few going in? I'll still try the clutch adjustment, maybe do a bleed in the spring but idk if anything will change. We'll just have to see.
The Following 2 Users Say Thank You to runfrodorun For This Useful Post:
humfrz (11-09-2017), Ultramaroon (11-09-2017)
Old 11-17-2017, 08:23 PM   #56
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Interesting reading. I'm another long time manual driver (European, never owned an automatic) and your transmission sounds very similar to mine. I'm on my second brz and they both are my least favorite gearboxes. Unpredictably stubborn and grindy some days, other days a slick delight to drive. Depends a bit on if I'm tired or not, but that doesn't explain it all - the other household car is an STi and that never grinds unless I really screw up the change. With the first brz I spent hours adjusting the clutch, changed to at least 5 different brands of oil, perrin transmission support, no better. With the 2nd brz I've changed the clutch slave as per ultramaroon's guide and the clutch feel is better for sure, but I've kept the original oil.
One thing I've noticed is the tranny is very sensitive to how I disengage the clutch - if I drop the clutch pedal after lifting off the gas to precisely where the car is coasting, no engine braking at all - then it usually slides easily into gear. If I lift off the gas a bit too much before pushing the clutch, so the car is engine braking, it almost always grinds or hesitates into the next gear.
jonboy99 is offline   Reply With Quote
Getting a new transmission from warranty, how long did it took? Terruko Scion FR-S / Toyota 86 GT86 General Forum 8 08-14-2017 10:58 AM
Transmission Warranty Anyone? bmacfrs Engine, Exhaust, Transmission 2 05-15-2017 11:13 PM
Which dealer to go for transmission warranty ironsurfer129 Southern California 17 02-21-2015 03:16 PM
Warranty Work With Mods + Extended Warranty Wyattkb Issues | Warranty | Recalls / TSB 3 01-20-2015 04:23 PM
Transmission warranty. Reaper Engine, Exhaust, Transmission 28 10-10-2014 06:29 PM
